By buying this product you get 128 loyalty points
The e-TP80E is luxurious and sophisticated, it is a power distributor that eliminates common problems encountered with audio-video components and caused by polluted electrical current.
The waveform of the alternating current becomes severely twisted by various sounds, peaks of tension and sagging.
There are also devices that deform above and below the waveform of the current.
In addition, you are never alone; your residence shares with other apartments, houses, and businesses the same transformer.
That's why users who are keen on Audio and Video note that their systems are nicer at night or on weekends!
The AC waveform is severely distorted by voltage spikes, high frequencies, noise from other components of your own system, and high-frequency radiation from digital processors and interconnects.
The built-in phase tester is used to check that the phase is respected between the mains plug and the filter.
The special design of the aluminum chassis effectively protects against another common problem, RFI (Radio Frequency Interference)
Internal wiring is made from a FURUTECH μ-14 wire (14 AWG) wire which guarantees a low resistance.
The contacts of the Schuko and the connectorseur IEC input are phosphor bronze gold-plated 24k
Characteristics :
Review of the magazinePicture and sound :
