ALLO DIGIONE SIGNATURE Network audio Player Raspberry 4 DigiOne interface Pre-installed DietPi Black
This ALLO DigiOne signature reader has no screen and no control interface. It can be remotely controlled from a mobile phone, a tablet or any device capable of running an internet browser.
By buying this product you get 42 loyalty points
Reference : 14867
429,00 €tax incl.
357,50 € tax excl.
Shipping date: 22-09-2026.
NETWORK PLAYER Digione SIGNATURE RASPBERRY PI 4 & SOFTWARE DietPi
High performance digital network drive
acrylic-case-for-digione-signature (3)sq
Access your audio files without a computer
This element is a digital player with network support. That is to say it is capable of playing audio tracks from a remote source. This source may be a hard drive located within the network or even an online streaming service.
Without any screen nor interface, Digione reader is controlled remotely with a mobile phone, tablet or any device capable of running a web browser. One can therefore enjoy a high quality audio playback without having to leave the couch or the bath.
Digione Interface Signature
The Allo Digione interfaces are currently the best digital SPDIF outputs to Raspberry Pi. They connect directly to a Raspberry Pi by GPIO and provide digital transfer while correcting jitter characteristic of a bare SBC.
This interface provides a BNC 75 Ohm output and RCA Coaxial Digital 24bit 192khz output. The rise time is 1 ns and the voltage completely meets the coaxial / BNC standards (550mV coaxial). This interface is capable of transforming a limited digital source such as Raspberry Pi into a true high-fidelity device with a remarkably low jitter of 400fs.
This is the latest version SIGNATURE Digione. The latter is divided into two parts isolated from each other (galvanic) operated with two power supplies to optimize the audio signal and avoid any pollution of the digital streams. It gets latest version of the NDK oscilateurs ultra low jitter noise . The audio circuitry also hosts a supercapacitor.
Raspberry Pi 4 SBC for a great network drive
This modernized version of the reader uses a SBC (single board computer / mini computer) Raspberry Pi version 4. This version benefits from USB-3 protocol and has increased transfert speed. Likewise, this new version has overall better specifications which improves boot speed as well as hardware stability.
Despite its small size, this device has every capability to play audio files of high quality, including the most demanding audiophile formats in terms of computing power and memory. This modernized version also benefits from bluetooth 5.0 support and increased computing speed.
Dedicated music player
Used in high fidelity chain, this type of network drive is extremely convenient since it is much more compact than a conventional computer and thus limits the space occupied. Wireless connectivity is also useful for the purpose of reducing congestion related to the accumulation of cables. Conversely, all of the computing power and its IT construction are mobilized in the service of audio quality. The sound quality will be multiplied compared to a smartphone or tablet classic.
So your devices dedicated to communication and work to avoid being solicités precarious audio use and are available for their other functions over the phone ringing in the middle of an opera or a computer that is updated during a guitar solo. The network drive for its part fulfills an audio function and will have no excuse to disturb listening.
DietPi Preinstalled
Unlike many network drives based on an SBC kind Raspberry Pi, this Digione drive is already equipped with a preinstalled audio software. It is not necessary to have expertise in installing Linux or micro-SD card flash. The device is ready for use, it will only connect to your network to enjoy the full extent of its capabilities.
DietPi is a very versatile distribution, including many software installable automatically by a menu. DietPi manages many software capable of transforming a Raspberry Pi into a real audio player. Among them we can mention: Kodi, LMS / Squeezelite, Shairport (Airplay), Roon Bridge, PD / YMPD - O! MPD - Mopidy, mediarender (DLNA), Spotify Connect Web / Raspotify
Digione Signature is also available in a version with preinstalled Volumio.
The tradition of the SBC is particularly articulated around the concept of open source. Devices and software solutions compatible with Raspberry Pi are no exception to the rule so you can easily change the software installed on your network drive if you happen to wish to experience other softwares or other functions.
This network drive will work just as well with Max2Play, DietPi or Picoreplayer suit your audio projects. It will suffice to extract the micro-SD card and flash the firmware image with your choice.
TypeNetwork Player
Version Raspberry Pi4
ProcessorBroadcom BCM2711, Quad Core Cortex-A72 (ARM v8) 64bit SoC @ 1.5GHz
Memory1GB
InputsMaterialized: 2x USB-3 / 2x USB-2 / 1x RJ45 / mini-HDMI
Dematerialized: WiFi IEEE 802.11b/g/n/ac 2.4GHz et 5GHz / Bluetooth 5
Digital interfaceAllo Digione SIGNATURE
OutputsS / PDIF Coaxial BNC &
Galvanic isolationYes
Noise50uV
oscillators2x NDK
jitterminimal 400fs
Power Supply5V (PI)
5-6V (Digione Signature) 100ma Min
2 power supplies are required
Only the DigiOne Signature's power supply is provided. The power supply for Raspberry Pi is to be purchased separately
HousingAcrylic
Accessories16Gb micro SD Card
Parts supplied
Raspberry Pi 4 1GBx1
Digione Signaturex1
Black acrylic Casex1
16GB microSDx1
5V power supplyx1
DC cable - USB-Cx2
InputMicro SD
OutputCoaxial SPDIF
OutputBNC
DAC / ADC ChipNC
Max sampling rate192kHz
Streaming services & Network protocolsWeb radios
Streaming services & Network protocolsRoon / Roon Bridge / Roon Ready
Streaming services & Network protocolsSpotify
Streaming services & Network protocolsDLNA
Streaming services & Network protocolsSpotify Connect
Fabuleux
En fait pour ce qui est des connaissances informatiques sur un mac avec Audirvana c'est complètement plug and play. Airplay est reconnu et upnp (gmediarender) sous Audirvana.
Je précise que j'utilise l'alimentation Shanti d'Allo (je n'ai pas de tests sans pour comparer....)
Par rapport à un mac en sortie usb sur cable Audioquest Carbon + Ifi IPurifier, c'est le jour et la nuit : tout est beaucoup plus net et propre, un rythme mieux maitrisé, tout est plus aéré...
Mais en fait cela ne s'arrête pas là : je voulais tester GentooPlayer suite aux excellents échos que j'en ai eu, là déconvenue : le son sous Gentooplayer est fabuleux mais mpd et upmpdcli sont instables avec Audirvana, c'est sans compter sans la tenacité homérique de son développeur qui fini par m'installer gmediarender et à me le compiler à distance via Teamviewer sur mon RPI !!!
Là c'est la claque de folie, Avec GentooPlayer le son est tellement analogique que c'est renversant !!! Je n'ai jamais entendu un tel son...
Tout est tellement naturel que j'en oublie que c'est de la hifi, je suis au concert. Cette distrib linux est une merveille, surtout si gmediarender est finalement intégré dans une prochaine version dans l'image...
Tout ce que je peux dire c'est que ce Digione signature avec le système qui va bien est absolument hors norme niveau qualité...
Pour Info mon Système :
Quellis 1 Optima + BC 362D + (connection XLR) Master 7 Singularity + (connection BNC) Digione Signature tout ça correctement cablé.
This review has been posted for ALLO DIGIONE SIGNATURE Network audio Player Raspberry 4 DigiOne interface Pre-installed DietPi Black
This ALLO DigiOne signature reader has no screen and no control interface. It can be remotely controlled from a mobile phone, a tablet or any...
