ALLO DIGIONE SIGNATURE Network audio Player Raspberry 4 DigiOne interface Pre-installed Volumio Black
This ALLO DigiOne signature reader has no screen and no control interface. It can be remotely controlled from a mobile phone, a tablet or any device capable of running an internet browser.
4.8 / 5
By buying this product you get 44 loyalty points
Reference : 14462
449,00 €tax incl.
374,17 € tax excl.
Shipping date: 30-09-2026.
NETWORK PLAYER Digione SIGNATURE RASPBERRY PI 4 & SOFTWARE VOLUMIO
High performance digital network drive
acrylic-case-for-digione-signature (3)sq
Access your audio files without a computer
This element is a digital player with network support. That is to say it is capable of playing audio tracks from a remote source. This source may be a hard drive located within the network or even an online streaming service.
Without any screen nor interface, Digione reader is controlled remotely with a mobile phone, tablet or any device capable of running a web browser. One can therefore enjoy a high quality audio playback without having to leave the couch or the bath.
Digione Interface Signature
The Allo Digione interfaces are currently the best digital SPDIF outputs to Raspberry Pi. They connect directly to a Raspberry Pi by GPIO and provide digital transfer while correcting jitter characteristic of a bare SBC.
This interface provides a BNC 75 Ohm output and RCA Coaxial Digital 24bit 192khz output. The rise time is 1 ns and the voltage completely meets the coaxial / BNC standards (550mV coaxial). This interface is capable of transforming a limited digital source such as Raspberry Pi into a true high-fidelity device with a remarkably low jitter of 400fs.
This is the latest version SIGNATURE Digione. The latter is divided into two parts isolated from each other (galvanic) operated with two power supplies to optimize the audio signal and avoid any pollution of the digital streams. It gets latest version of the NDK oscilateurs ultra low jitter noise . The audio circuitry also hosts a supercapacitor.
Raspberry Pi 4 SBC for a great network drive
This modernized version of the reader uses a SBC (single board computer / mini computer) Raspberry Pi version 4. This version benefits from USB-3 protocol and has increased transfert speed. Likewise, this new version has overall better specifications which improves boot speed as well as hardware stability.
Despite its small size, this device has every capability to play audio files of high quality, including the most demanding audiophile formats in terms of computing power and memory. This modernized version also benefits from bluetooth 5.0 support and increased computing speed.
Dedicated music player
Used in high fidelity chain, this type of network drive is extremely convenient since it is much more compact than a conventional computer and thus limits the space occupied. Wireless connectivity is also useful for the purpose of reducing congestion related to the accumulation of cables. Conversely, all of the computing power and its IT construction are mobilized in the service of audio quality. The sound quality will be multiplied compared to a smartphone or tablet classic.
So your devices dedicated to communication and work to avoid being solicités precarious audio use and are available for their other functions over the phone ringing in the middle of an opera or a computer that is updated during a guitar solo. The network drive for its part fulfills an audio function and will have no excuse to disturb listening.
VOLUMIO, preinstalled advanced software Audio.
Unlike many network drives based on an SBC kind Raspberry Pi, this Digione drive is already equipped with a preinstalled audio software. It is not necessary to have expertise in installing Linux or micro-SD card flash. The device is ready for use, it will only connect to your network to enjoy the full extent of its capabilities.
Volumio is a software developed in an effort to provide a high-performance audio interface while remaining as comfortable and intuitive point of view to use than any mainstream solution. This software exploits all the hardware capabilities of the Raspberry Pi, particularly its connectivity since it offers the possibility of controlling the drive from any device capable of connecting to a web browser (computer, smartphone, tablet or even another SBC ... etc). It is very simple to select music, change playback options, the volume from anywhere as long as the connection to the network exists.
To go even further and expand device capabilities, Volumio is also able to handle a wifi hotspot. That is to say, to establish an ad hoc network if fixed network is lacking. This means firstly that the device will still play your audio library even if your router / box fails. On the other hand, it also means that the network drive can be moved for use in private network places (spouse benefit to its small size).
Open source and free to choose
The tradition of the SBC is particularly articulated around the concept of open source. Devices and software solutions compatible with Raspberry Pi are no exception to the rule so you can easily change the software installed on your network drive if you happen to wish to experience other softwares or other functions.
Max2Play dietpi
This network drive will work just as well with Max2Play, DietPi or Picoreplayer suit your audio projects. It will suffice to extract the micro-SD card and flash the firmware image with your choice.
TypeNetwork Player
Version Raspberry Pi4
ProcessorBroadcom BCM2711, Quad Core Cortex-A72 (ARM v8) 64bit SoC @ 1.5GHz
Memory1GB
InputsMaterialized: 2x USB-3 / 2x USB-2 / 1x RJ45 / mini-HDMI
Dematerialized: WiFi IEEE 802.11b/g/n/ac 2.4GHz et 5GHz / Bluetooth 5
Digital interfaceAllo Digione SIGNATURE
OutputsS / PDIF Coaxial BNC &
Galvanic isolationYes
Noise50uV
oscillators2x NDK
jitterminimal 400fs
Power Supply5V (PI)
5-6V (Digione Signature) 100ma Min
2 power supplies are required
Power supply are to be purchased separately
HousingAcrylic
Accessories16Gb micro SD Card
Parts supplied
Raspberry Pi 4 1GBx1
Digione Signaturex1
Black acrylic Casex1
16GB microSDx1
InputMicro SD
OutputBNC
OutputCoaxial SPDIF
DAC / ADC ChipNC
Max sampling rate192kHz
Streaming services & Network protocolsTidal Connect
Streaming services & Network protocolsSpotify
Streaming services & Network protocolsDLNA
Streaming services & Network protocolsSpotify Connect
Streaming services & Network protocolsQobuz
Streaming services & Network protocolsWeb radios
4 reviews
Thank you Audiophonics for offering this product!
I'm really glad I bought the Allo DigiOne Signature!
Paired with a good DAC (I have the Topping E50), the sound is amazing.
Wonderful voices, generally excellent precision. - Fantastic!
I use a very good and very low-noise power supply (Allo Nirvana SMPS) for the streamer and the DAC. I assume the Allo Shanti, for example, could bring further improvements.
The speakers seem to exist even less to me, the spatial image has more depth. Everything seems more realistic. Fantastic even for live recordings.
I also have the predecessor (without signature, unfortunately no longer available). This already has amazing qualities. With signature it is actually even better.
The Allo DigiOne Signature is, in my opinion, a fantastic product and definitely worth every cent!
This review has been posted for ALLO DIGIONE SIGNATURE Network audio Player Raspberry 4 DigiOne interface Pre-installed Volumio Black
wonderful streamer
I really wanted to ear the difference from my PC to a real streamer, and I wanted that every euro I spent for a streamer was on the streamer performance (so no DAC attached, no bells and whistles). This IS it. I usually struggle to ear differences between DACs so I was so surprised when I played the first track through the digione sig. The staging, clarity, less fatiguing sound was a huge step forward. I am totally happy.
One CONS: the preinstalled volumio was not original, so not up-gradable, so I had to buy extra hardware to flash the drive again and the extra money spent for the volumio version was a waste. You are better off choosing the roopie version and flash whatever on your own. I bought it with Nirvana, for me the result is already super satisfying, I don't feel the need to go with shanti, but I don't even know what I may be still missing, only that I am fine like this.
Allo Digione SIgnature - RP4 version
Prompt service and delivery. I am using my Allo DS with a ADI-2 DAC FS and a set of Meze Empyrean headphones. Very satisfied with the pairing and the sound quality of the Allo DS.
I have previously used a RP4 and purchased a separate DAC hat, downloading Volumio and installing it, which is easy enough. This is an important point as my Allo DS arrived well packaged, but with no instructions what so ever. If I had no prior RP4 experience, it would have been a bit of a struggle.
Svolge egregiamente il suo lavoro.
In realtà le stelle dovrebbero essere 4,5....nella mia configurazione il lettore meccanico Cyrus è ancora superiore come risultato sonoro, anche se non di molto. Può dipendere da molti fattori ed anche dal software installato(volumio) che d'altra parte è un' interfaccia molto intuitivo e facile da usare. Rapporto qualità prezzo comunque eccezionale ed ottimo apparecchio.
This ALLO DigiOne signature reader has no screen and no control interface. It can be remotely controlled from a mobile phone, a tablet or any...
