SparkDIGI LTE I2S Kali - KALI Reclocked Network Player I2S LVDS HDMI
Reference : 12132
219,00 €tax incl.
182,50 € tax excl.
To place an order, please specify the brand and model of the DAC you want to use in the "Product Customization" tab of this page. Depending on the type of compatibilty DAC, two KALI reclocker exist: 22/24MHZ or 44/48MHZ
In case of doubt about the compatibility and / or operation of this product, do not hesitate to contact us.
Audiophonics SparkDIGI KALI
Streamer I2S LVDS HDMI Kali Reclocked
sparkdigi Lecteur Réseau I2S LVDS HDMI
Audiophonics expands its line-up with a brand new network drive, based on a Kali controlled SBC and an I2S LVDS digital interface via HDMI port. A solution that is therefore Audio-GD compatible and certainly audiophile.
The dematerialized world has never been so close
With SparkDIGI, you can simply enjoy your entire dematerialized high definition audio library, without limits! Remotely controllable from your Volumio interface, you can access files on your server intuitively and efficiently. So you can enjoy your music from the couch.
Volumio: A more than complete DAP
volumio
Audiophile Quality
This high fidelity DAP is a true audiophile solution tailored to deliver bit-perfect playback and uncompromising audio quality.
Sans limite
Volumio lets you play all your music: MP3, FLAC, WAV, AAC, ALAC, DSD and more. You can also enjoy the UPNP/DLNA, Airplay, Spotify and web radios in the same place.
Open Source
This player also proves to be open source, developed by a talented team and an active community.
interface volumio
I2S LVDS + Reclocking: The ultimate in audio quality
sparkdigi es9028q2m kali
Instead of using the usual signals, this SparkDIGI lets you enjoy an extremely clean I2S LVDS signal via a dedicated Audio-GD digital interface. The latter is responsible for symmetrizing the signal. All you have to do is plug the SparkDIGI into your DAC with an HDMI I2S LVDS port to enjoy your music and exceptional sound reproduction.
In addition, an I2S FIFO 44 / 48MHz Allo Kali I2S reclocker allows you to process Sparky's I2S signal thanks to an Ultra Low Jitter clock powered by LDO and an ultra-quiet power supply, providing high accuracy. Your system's performance is increased tenfold: your music "opens", the sound scene expands and you can now see sounds that were previously unheard.
Attention: the HDMI output is only I2S balanced and is therefore not usable for video.
Various compatible DACs
To enjoy your SparkDIGI turntable, simply choose your HDMI I2S LVDS HDMI DAC, like for example the Audio-GD DAC-19 or the Audio-GD NOS-19. Of course many other models exist. Here is the list of brands by proposing (not exhaustive) :
  • Matrix
  • Astin Trew
  • Audio Byte
  • Rockna
  • Javs
  • K&K Audio
  • Love Harmony
  • PS Audio
  • Sonore
  • Stahl Tec Optus DAC
  • Wired 4 Sound
sparkdigi audio-gd
The SparkDigi is also compatible with our Matrix DACs with I2S LVDS Matrix inputs: Matrix X-Sabre Pro.
matrix x-sabre pro
Sober and elegant design
The SparkDIGI, assembled in a 100% aluminium housing, has a sober yet elegant design that will fit seamlessly into your Hifi system. Designed in our workshops in France, this case will protect the system components from shock and dust.
sparkdigi
Connectors
Inputs2x USB-A
1x Ethernet RJ45
1x Slot Micro SD
Output1x HDMI (I2S LVDS)
Sparky
CPUARM Cortex A9 Quad Core 1.1GHz
Mémory1Go RAM DDR3L
GPUPowerVR SGX544 / 500MHz
Kali
ClockMulti-frequency with automatic switching
Voltage regulatorWith ultra low noise
FIFO CircuitWith FPGA
FIFO MemorySRAM 4MB
Global
Dimensions102 x 169 x 58mm
Weight580g
Power SupplyJack DC 5.5/2.1mm - 5V 2A
Accessories5V 3A Power Supply
If you have any doubts about the compatibility and/or functioning of this product, please do not hesitate to contact us.
Mapping I2S / LVDS
A synthesis of main IIS on LVDS pinouts mapping is available here.
OutputI2S LVDS via HDMI
Product customization
After saving your customized product, remember to add it to your cart.
Text
loader
* required fields
