COVID-19 Virus information. Find the latest regularly updated information about the status of our services.
AUDIOPHONICS RaspDAC I-Sabre ES9028Q2M - Streamer Raspberry Pi 3 & DAC
AUDIOPHONICS RaspDAC I-Sabre ES9028Q2M - Streamer Raspberry Pi & DAC
The RaspDAC is a network player based on a Raspberry Pi 3 B+. With its display, it will allow you to enjoy simply your dematerialized music High Definition. It is proposed here in its version with a DAC ES9038Q2M 32bit 384KHZ.
Reference : 12315
290,83 €tax excl.
This product is no longer in stock
AUDIOPHONICS RASPDAC
DAC network player Audiophonics I-Sabre ES9038Q2M and Raspberry Pi 3 B+
Switch to high resolution dematerialization with the RaspDAC32 bit. Case 100% Aluminum, DAC ES9038Q2M 32bit 384Khz, and Raspberry 3 B+!
This new version now offers a dedicated hole for an infrared receiver, a micro SD card port, and of course the new Raspberry Pi 3 B+.
A complete streamer, ready to use electronically, all you have to do is install a software solution. The Volumio system is particularly well suited for this purpose, allowing a simple installation with an intuitive and fluid interface, while ensuring high quality sound reproduction. It can be controlled via any connected device thanks to the web interface, it will perfectly match your RaspDAC. In addition, to work it is necessary to select under Volumio the corresponding driver, available in the "Downloads" tab of this page.
logo volumio
audiophonics electronics
A high-end digital audio player ...
This evolution of our RaspDAC is now much faster thanks to the implementation of Raspberry Pi 3 B+, which supports WiFi and has an infrared receiver slot (option), as well as an offset of micro SD card reader, when the latter was difficult to access on the first version.
opAUDIOPHONICS integrates the famous DAC I-Sabre ES9038Q2M 32 / 384Khz equipped with a precision clock of 100 Mhz as well as a circuit of masses reviewed and corrected, a low noise regulation LDO polymer capacitors, the addition of an Altera FIFO processor, this DAC I-Sabre is the heart of the RaspDAC.
From its advanced ATX power management with different possible shutdown modes offer a high level of ease of use.
It has all the inputs / outputs necessary for its connection, its power (Jack DC 5.5 / 2.1mm), an HDMI port, a micro SD card port and an OLED display.
RaspDAC
Your Raspberry Pi in a high quality Audio environment.
It has been designed with the aim of allowing you to have the effectiveness of your Raspberry Pi in a high quality Audio environment. Especially elegant and discreet, it offers you the possibility to have a powerful audio solution and achieved an unbeatable value for money.
Raspberry Pi 3Model B +
DACI-Sabre ES9038Q2M
displayOLED
<inputs/ Td>1x RJ45 / 4x USA-A / 1x Micro-SD Port
Exits1x RCA Stereo
FoodJack DC 5.5 / 2.1mm
Dimensions160 x 140 x 50mm
Display Size65 x 16mm
Weight0.9kg
Housing material100% Aluminum
Aluminum Case for I-Sabre DAC V3, Es9038Q2M & Raspberry Pi 2/3/3B+
This 100% Aluminum case is designed to accommodate the Raspberry Pi 2/3 & Audiophonics DAC I-Sabre V3 ES9023 , ES9028 and ES9038Q2M.
RaspDAC housing
Supplied accessories:
To enable you to be directly operational, the player comes with an 8GB SDHC card, and its 7-9V / 2A power adapter.
Components / ChipES9028 Q2M
MaterialMetal
StructureAluminium
Channel2 channels (Stereo)
Colissimo - TNT - SoColissimo
The RaspDAC is a network player based on a Raspberry Pi 3 B+. With its display, it will allow you to enjoy simply your dematerialized music High...
