AUDIOPHONICS RaspDAC I-Sabre V4 - Kit DIY Network player Raspberry Pi 3.0 & DAC
AUDIOPHONICS RaspDAC Kit DIY Network player Raspberry Pi 3.0 & DAC Sabre V3
The Audiophonics RaspDAC is supplied as a complete kit, so you can mount your DIY network drive yourself. This model is based on a Raspberry Pi and DAC Audiophonics I-Sabre V4 ES9023 TCXO.
4.6 / 5
Reference : 11136
219,00 €tax incl.
182,50 € tax excl.
Available
Shipping date: 21-01-2019.
Orders placed before 1pm (GMT+1) will be shipped the same day (working day).
This product is delivered as a DIY kit to mount yourself.
We also offer the mounted version: RaspDAC Raspberry Pi 3B+ & DAC I-Sabre V4 .
AUDIOPHONICS RASPDAC
Audiophonics I-Sabre V4 ES9023 and Raspberry Pi 3 Network Player
RaspDAC
Reach high definition dematerialized with RaspDAC. Case 100% Aluminum, DAC ES9023 24bit 192Khz TCXO, and Raspberry 3B+!
This is the most recent updated version, it benefits from the following upgrades :
  • Pre-made socket for infrared receptor
  • Micro-SD card slot
  • Version 3B+ Raspberry Pi
  • I-Sabre 4th generation
Everything hardware-related is included and operationnal. The only prerequisite before playing music is deciding which software you like the most (Max2Play, piCorePLayer...) and installing the latter on RaspDAC
A high-end digital audio player ...
This evolution of our RaspDAC is now much faster thanks to the implementation of Raspberry Pi 3 B+, has a hole for an infrared receiver, and a micro SD card reader offset, when it was difficult to access to the first version.
OptAUDIOPHONICS integrates the famous DAC I-Sabre V4 24 / 192Khz equipped with a TCXO precision clock as well as a circuit of masses reviewed and corrected, and a low noise regulation LDO capacitors OS Con, this DAC I-Sabre V4 is the heart of the RaspDAC.
OfPlus, its advanced ATX power management with different possible shutdown modes offer a high level of ease of use.
It has all the inputs / outputs required for its connection, its(DC Jack 5.5 / 2.1mm), an HDMI port, a micro SD card port and an OLED display.
RaspDAC
Le software
Announcing itself as a free system, RaspDAC is delivered with without operating system installed . You are free to choose and install the one that best suits your needs. Some features require the installation of custom scripts to work if you do not choose a pre-installed image :
  • The power management functions use a Python script to install (or manual plugin available in Volumio).
  • The OLED screen works with a dedicated script that only works under Volumio and LMS (DietPi).
  • IR reception requires the installation of LIRC, the power management of its dedicated script.
  • The hardware volume requires the use of the dedicated driver (native in DietPi, manual plugin in Volumio).
Volumio
Currently we recommend using Volumio which offers both very good audio performance but also a simple, intuitive and above all accessible interface from any device connected via a web interface.
Volumio allows you to read from a NAS on the network, from a UPnP source or from a local storage such as a hard disk or USB key. It also provides access to web radios and has a Spotify plugin. It also manages the DLNA protocol allowing to control the player from an application like Bubble UPnP, which itself is able to read many streams and has a Qobuz plugin. The AirPlay is also managed.
Volumio
To make it a ready-to-use product and to be able to use the product as soon as it is received, we propose an SD card including a pre-configured Volumio image with the plugins necessary for the functions present on the RaspDAC. We strongly recommend it to beginners. Indeed, the installation and configuration of this type of solution requires a good knowledge of Linux and the hardware used.
Buy Volumio SD Card
Vous pouvez cependant opter pour d'autres solutions comme par exemple Max2Play et son interface soignée et sa compatibilité ou encore DietPi et sa grande modularité.
Max2Play
DietPi
Discover and download RaspDAC Image
Your Raspberry Pi in a high quality Audio environment.
It has been designed with the aim of allowing you to have the effectiveness of your Raspberry Pi in a high quality Audio environment. Especially elegant and discreet, it offers you the possibility to have a powerful audio solution and achieved an unbeatable value for money.
Raspberry Pi 3Model B+
DACI-Sabre V4 ES9023 TCXO
displayOLED
Inputs1x RJ45 / 4x USA-A / 1x Micro-SD Port
Outputs1x RCA Stereo
Power SupplyJack DC 5.5 / 2.1mm
Dimensions160 x 140 x 50mm
Display Size65 x 16mm
Weight0.9kg
Housing material100% Aluminum
Aluminum Case for I-Sabre DAC V4 & Raspberry Pi 2 / 3 / 3B+
This 100% Aluminum case is designed to accommodate the Raspberry Pi 2/3/3B+ & Audiophonics DAC I-Sabre V4 ES9023.
RaspDAC housing
The kit contains:
  • 1x Aluminum housing for I-Sabre DAC
  • 1x DAC Audiophonics I-Sabre V4 ES9023 TCXO
  • 1x Raspberry Pi 3 Model B
  • 1x Winstar OLED 16x2 Screen White HD44780
  • 1x Pushbutton Aluminum with pre-welded wires
  • 1x HDMI Male to HDMI Partition Wall
  • 1x 1GB Sandisk 8GB Micro SD Memory Card
  • 1x Tablecloth interconnect with dual XHP 2.54mm 6PIN
  • 1x power adapter 7V 3A
DAC ChipES9023
Max sampling rate192kHz
Components / ChipES9023
MaterialMetal
StructureAluminium
Channel2 channels (Stereo)
Colissimo - TNT - SoColissimo
5 reviews
Very nice dac
The kit is complete and easy to assemble, for this reason there are no instructions.
The audio quality is very good for the price.
I rewrote the python driver for the 16x2 LCD, link for download:
https://volumio.org/forum/audiophonics-sabre-pulsante-display-t6070-20.html
Bye
This review has been posted for AUDIOPHONICS RaspDAC I-Sabre V4 - Kit DIY Network player Raspberry Pi 3.0 & DAC
Ce DAC est un killer !
Je précise que je n'ai pas d'actions audiophonics de toute façon c'est une SASU :-) mais il faut reconnaitre que selon moi c'est le meilleur DAC/streamer du marché français à ce prix et je suis audiophile depuis... 30 ans, oups ça ne me rajeunit pas. Donc j'en ai essayé des DACs ! La seule chose que l'on peut regretter c'est que ce Kit n'existe pas en produit fini, car autour de 249€ ce serait le meilleur Steamer audiophile du marché. Certes il existe le Rasptouch à 349€, mais finalement avec Max2Play l'écran est inutile puisque tout se fait à partir d'un navigateur et la carte est même reconnu par Max2Play. Il semble que Max2Play ait particulièrement flashé tout comme moi sur la carte I-Sabre ES9023 en disant que c'est la meilleur carte Rpi du marché, moi je vais plus loin en disant clairement que c'est le meilleur DAC wifi du marché. Reconnu en Squeezbox ou airport express et avec un bien meilleur Jiiter et clocking que l'airport express (bon ça c'est quand même du à moitié au Rpi, mais je suppose que Audiophonics a bien clocké la carte également). Je suis extrèment surpris des 4/5 étoiles des deux autres membres. Apparement ils se sont focusé sur la difficulté de montage. Moi je monte des cartes mères de PC depuis le même temps que je suis audiophile, mais comme j'aurais aussi eu les moyens de me payer le produit fini, à choisir j'aurais préféré 50€ de plus et le produit monté. Certes on serait proche du Rasptouch en prix, mais j'ai aussi un écran 7 pouces Rpi et je m'en sert jamais et le peu de fois où je m'en suis servi c'était un peu galère avec mes grosses paluches :-) Y'a beau avoir de super belles puces ES9028 et ES9038 sur le papier, j'ai trouvé mon bonheur avec cette ES9023 à la sauce Audiophonics. Une très belle découverte. Je vais en plus pouvoir revendre mes deux autres serveurs Airplay.
Audiophonics conseille plus l'univers Squeezelite, mais la qualité Airplay même si en 44/16 (après tout y'a des lecteurs CD 44/16 à 50 000€ !!!) me satisfait amplement et pourtant je pense avoir des oreilles assez exercées :-)
Bon produit
Correspond à mes attentes, utilisé avec OSMC en tant que mediacenter et pour écouter ma musique numérique sur chaine HiFi (la qualité est au rendez vous)
Relativement facile à installer (il faut chercher un peu sur les forum-merci à fengalin pour la programmation écran + bouton) même pour un débutant en programmation comme moi. Boitier de très bonne qualité, se marie très bien avec mes éléments HiFi
Une étoile en moins pour:
- pas doc de montage du kit et vidéo youtube avec des pièces différentes
- le passe cloison hdmi qui a un faux contact et est inutilisable (j'ai fait une réclamation)
Parfait mais manque d'infos au montage
--> livraison : rapide
--> assemblage : tout d'abord à savoir qu'il n'y aucune notice de montage. Au départ, rien de compliqué, il suffit de suivre la vidéo. Ça se complique lors de la connexion sur la carte du Dac (afficheur et bouton) car sur la vidéo on explique le cablage avec la generation 1 du Dac or celui vendu est de génération 2. En fouillant un peu sur le site on trouve le lien pour la cablage : http://www.audiophonics.fr/fr/dac-diy/audiophonics-i-sabre-dac-es9023-v3-tcxo-raspberry-pi-20-a-b-i2s-p-10657.html
--> Partie Software : là encore il faut chercher les infos (merci Google). Lorsqu'on installe RuneAudio téléchargé sur le site RuneAudio, ni le bouton et ni l'afficheur fonctionne (normal !) et le lien proposé sur le site Audiophonics est mort pour avoir un RuneAudio compatible au RaspDac. En cherchant sur divers forum, on trouve l'image à télécharger : http://forum.audiophonics.fr/viewtopic.php?f=4&t=1777
--> Le produit final : le produit dans le boîtier métal est vraiment bien fini. ll démarre rapidement, est très réactif avec une application installée sur SmartPhone Android. Je ne suis pas un pro audiophile mais la qualité du son me convient largement, même avec l'alimentation de base fournie avec le RaspDac. Autre point sympa : les webradios et la gestion du volume sur tablette ou SmartPhone.
Je mets 4 étoiles et non 5 à cause des infos sur l'assemblage qui pourraient être réactualisées et regroupées sur une même page.
Excellent DAC, Ajoutez de brèves instructions!
Facile à assembler malgré le manque total d'instructions. Il faudrait au moins ajouter quelques notes à la vidéo d'assemblage pour ce qui est des branchements du panneau d'affichage et du bouton poussoir. Aussi quelques mots pour aider le branchement au réseau Wi-Fi (Il faut le brancher avec fil d'abord et configurer le logiciel, dans mon cas Rune). J'aurais aimé des instructions claire mais merci pour l'assistance technique qui m'a guidé à bon port. Une page d'instruction simplifierais le travail.
Une fois le tout fonctionnel, c'est fantastique de pouvoir tout écouter mes cd convertis en FLAC.
The Audiophonics RaspDAC is supplied as a complete kit, so you can mount your DIY network drive yourself. This model is based on a Raspberry Pi and...
