COVID-19 Virus information. Find the latest regularly updated information about the status of our services.
AUDIOPHONICS RaspDAC - Kit DIY Network player for Raspberry Pi 2 / 3 & DAC
AUDIOPHONICS RaspDAC Kit DIY Network player for Raspberry Pi 2.0 & DAC
Discover this kit to make your own RaspDAC DIY. This contains the case, display, buttons, hardware and HDMI extension. All you have to do is add a Raspberry Pi and a compatible DAC of your choice (not included)
Reference : 10511
74,17 €tax excl.
This product is no longer in stock
This product is supplied as a DIY kit (Raspberry Pi & DAC not included). This kit does not require any welding on your part. The button and the screen are already there, you just have to plug and screw.
AUDIOPHONICS RASPDAC
Audiophonics DAC Network Player for Raspberry Pi 3
RaspDAC
Designed around a 100% Aluminum housing to accommodate the modules of your choice as well as all the necessary components, the RaspDac is developed directly in our workshops.
Kit Complete network reader with only the Raspberry Pi, the DAC and the software solution of your choice (Volumio, Picoreplayer, Raspbmc, Openelec).
A high-end audio player kit ...
It will allow you to get very simply a high-end Audio or Audio / Video player. It has all the inputs / outputs necessary for its connector, its power (jack DC 5.5 / 2.1mm), an HDMI port and an OLED display.
RaspDAC
Your Raspberry Pi in a high quality Audio environment.
He wasdesigned to allow you to have the effectiveness of your Raspberry Pi in a high quality Audio environment. Especially elegant and discreet, it offers you the possibility to have a powerful audio solution and achieved an excellent value for money.
RaspDAC
displayOLED
Holes for1x RJ45 / 4x Port USB-A / 1x Port HDMI / 1x Port Analog Output RCA Stereo / 1x Input Jack DC 5.5 / 2.1mm
Dimensions160 x 140 x 50mm
Display Size65 x 16mm
Weight0.9kg
Housing material100% Aluminum
Aluminum Case for I-Saber DAC V3 & Raspberry Pi 2.0 B
This 100% Aluminum case has been designed to receive the Raspberry Pi 2 Model B coupled with an I-Saber DAC V3.
It will however be necessary to provide mains power to 5V with USB A 2A connector (or connect it to a computer).
RaspDAC housing
content kit raspdac
Contents of the kit
StructureAluminium
Colissimo - TNT - SoColissimo
Discover this kit to make your own RaspDAC DIY. This contains the case, display, buttons, hardware and HDMI extension. All you have to do is add a...
