AUDIOPHONICS RaspDAC I-Sabre V3 - Kit DIY Streamer Raspberry Pi 2 / 3 & DAC
Our RaspDac allows you to enjoy your dematerialized high-definition music without limit. This model is equipped with an I-Sabre ES9023 DAC.
KEY POINTS:
  • DAC ES9023
  • Raspberry Pi
  • 24bits 192kHz
  • TCXO
  • Display OLED
Reference : 10384
199,00 €tax incl.
165,83 € tax excl.
This product is delivered in kit DIY to be assembled.
We also offer the mounted version here .
AUDIOPHONICS RASPDAC I-Sabre V3
DAC I-Sabre V3 Network Reader ES9023 and Raspberry Pi 3
Go to the high definition dematerialized with the RaspDAC. Housing 100% Aluminum, DAC ES9023 24bit 192Khz TCXO, Raspberry 2.0!
Here is an affordable solution of dematerialized reading assembled and tested in our workshops.
Ready-to-use network reader electronically, all you have to do is opt for the software solution of your choice (Volumio, Picoreplayer, Raspbmc, Openelec).
A high-end audio player ...
Simply get a high-end digital audio player with a 24bit / 192Khz Bit-Perfect resolution.
AUDIOPHONICS integrates the new DAC I-Sabre V3 ES9023 24 / 192Khz equipped with a TCXO precision clock and a revised and corrected mass circuit, and a new low regulation noise LDO capacitors OS Con, this DAC I-Sabre V3 is the heart of the RaspDAC.
In addition, its advanced ATX-type power management with different extinguishing modes offers a high level of ease of use.
It has all the inputs / outputs necessary for its connector, its power (jack DC 5.5 / 2.1mm), an HDMI port and an OLED display.
RaspDAC
Illustration withlinear regulated external power supply 5V 2A not provided
Your Raspberry Pi in a high quality Audio environment.
It has been designed with the aim of allowing you to have the effectiveness of your Raspberry Pi in a high quality Audio environment. Especially elegant and discreet, it offers you the possibility to have a powerful audio solution and achieved an excellent value for money.Here is the full version assembled and tested in our workshops of our latest Sabre family converter associated with a file player based on a Raspberry PI.
RaspDAC
Raspberry Pi 3Model B
DACAudiophonics I-Sabre V3 ES9023 TCXO
displayOLED
<inputs/ Td>1x RJ45 / 4x USA-A
Exits1x HDMI / 1x RCA stereo
FoodJack DC 5.5 / 2.1mm
Dimensions160 x 140 x 50mm
Display Size65 x 16mm
Weight0.9kg
Housing material100% Aluminum
Aluminum Case for I-Sabre DAC V3 & Raspberry Pi 2.0 B
This 100% Aluminum case is designed to accommodate the Raspberry Pi 2 Model B and Audiophonics DAC I-Sabre V3 ES9023.
RaspDAC housing
Supplied accessories:
To allow you to be directly operational, the player comes with an 8GB SDHC card, and also an external standard 6V 2A power supply on 5.5 / 2.1 connector.
Improve quality (back-up noise reduction) with optional AUDIOPHONICS lineaexternal regulated external double 2x 6V 2.9A 25VA.
Volumio
RaspDAC Package Contents
Our RaspDac allows you to enjoy your dematerialized high-definition music without limit. This model is equipped with an I-Sabre ES9023 DAC. KEY...
