RASPTOUCH LVDS Streamer I2S HDMI Audio-GD Compatible IIS
AUDIOPHONICS RaspTouch Network Player I2S LVDS HDMI Audio-GD Compatible Black
Audiophonics is back with a brand new version of its RaspTouch, designed for experienced audiophiles. It includes a Raspberry Pi 4, an Allo Kali reclocker and an I2S output module for HDMI Audio-GD. So you can enjoy a true HiFi I2S signal and the resulting sound quality.
4.7 / 5
By buying this product you get 36 loyalty points
Reference : 12030
369,00 €tax incl.
307,50 € tax excl.
Shipping from France
Billing in France
Technical support in France
If you have any doubts about the compatibility and/or operation of this product, please do not hesitate to contact us.
Computer skills are required for the installation of an OS. Once the latter is installed, choose the RPI DAC output. To use the power controller it is necessary to make changes to the chosen software solution.
RASPTOUCH I2S LVDS HDMI
Open Source Raspberry 4 Streamer I2S LVDS HDMI
Rasptouch I2S LVDS HDMI
piCorePlayer
max2play
OSMC
Complete compatibility
Supplied with a Micro SD card for the OS installation, there are many operating system options to choose from, depending on your preferences and needs.
Ready to use electronically, many software solutions exist to meet all your expectations: piCorePlayer, Max2Play, OpenElec...
Multiroom without limits
Do you want to enjoy your music throughout your home? The Rasptouch offers you an efficient multiroom system, allowing you to stream your files on any turntable connected to your network and control them.
I2S LVDS: The ultimate in audio quality
Instead of using the usual signals, this RaspTouch lets you enjoy a clean I2S signal. For example, an I2S FIFO 44 / 48MHz Allo Kali reclocker allows the Raspberry Pi's I2S signal to be processed thanks to an Ultra Low Jitter clock fed by LDO and an ultra-quiet power supply, providing high precision. Your system's performance is fast: your music "opens", your sound scene expands, and you can now see sounds that were previously unheard.
This signal is then routed to an Audio-GD I2S module to HDMI, symmetricating the signal. Just plug in your DAC and enjoy.
Many compatible DACs
To take advantage of your RaspTouch player, simply choose your HDMI DAC, such as AUDIO-GD D-27.28 or AUDIO-GD R-1. Of course many other models exist. Here is the list of brands by proposing (not exhaustive) :
  • Astin Trew
  • Audio Byte
  • Rockna
  • Javs
  • K&K Audio
  • Love Harmony
  • PS Audio
  • Sonore
  • Stahl Tec Optus DAC
  • Wired 4 Sound
Ergonomic and Design
Featuring a 7"touch screen, it allows you to easily and intuitively control your audio library via a graphical interface..
Mounted in a 100% CNC-machined aluminium housing in France, its black colour and matt appearance give it a modern and contemporary design. A device that will fit perfectly into your high-end audio system.
Connectors
Inputs4x USB-A
1x Ethernet RJ45
1x Micro SD
Outputs1x HDMI I2S LVDS
1x HDMI Vidéo
Raspberry Pi 4
SoCBroadcom BCM2711
CPUARM Cortex-A72 1.5GHz Quad Core
WiFi802.11ac
Bluetooth5.0 BLE
GPUBroadcom VideoCore VI, Open GL ES 3.0
RAM2Go
Allo Kali
FIFO CircuitWith FPGA
FIFO MemorySRAM 4MB
ClockMulti-frequency clock with automatic comutation and high performances
Voltage regulatorUltra low noise regulator
ScreenCapacitive tactil 7"
Screen resolution800 x 400px
Case colorNoir
Case materialAluminium
Dimensions200 x 95 x 230mm
Weight1440g
Supply :DC 5.5/2.1 - 7 to 9V DC
If you have any doubts about the compatibility and/or functioning of this product, please do not hesitate to contact us.
Mapping I2S / LVDS
A synthesis of main IIS on LVDS pinouts mapping is available here.
InputMicro SD
InputRJ45
OutputI2S LVDS via HDMI
OutputHDMI
DAC / ADC ChipNC
Max sampling rate384kHz
3 reviews
The Definitive Squeezebox Touch Replacement?
Both my SBT and my DAC, a Geek Pulse, recently died. I tried a Volumio Primo, but the HDMI touch screen I added was much too slow, the functionality of Volumio software not up to the task of dealing with my large music library, and the Squeezelite plug-in problematic. I came to Audiophimics for a new DAC (the impressive Guatard A18) and found this by happenstance. Lucky day. The RaspTouch is fantastic. A better screen that is very responsive. A simple but well-built case. Setting it up with PiCorePlayer was far easier than the Volumio Primo, especially with the help of David, who was incredibly patient and helpful. Combined with the Gustard it sounds truly fantastic. I recommend both the hardware and Audiophonics without reservation.
This review has been posted for RASPTOUCH LVDS Streamer I2S HDMI Audio-GD Compatible IIS
au top
Comparer a mon pc/foobar non optimisé audio c"est déjà bon ,mais avec son alim linéaire c'est vraiment excellent et on monte de plusieurs crans en qualité .Meilleurs timbres et placement des instruments sur tous les plans , plus de transparence.Et surtout il n'y a plus ou presque plus cette dureté "numérique".La musique coule avec douceur, c'est un vrai plaisir.Un petit mot sur les équipes audiophonics avant que j'oublie , expédition, emballage et suremballage au top. Ca fait plaisir de voir que son matériel a voyager en toute sécurité.
Great!
Sounds great...only at 512 it stutters. Have you tips?
Audiophonics is back with a brand new version of its RaspTouch, designed for experienced audiophiles. It includes a Raspberry Pi 4, an Allo Kali...
