BLUESOUND NODE 2i Multiroom Streamer 24bit 192kHz MQA
The Bluesound Node 2i Streamer connects very easily to your stereo system to open the doors of the streaming audio. With a wide range of analog and digital connectivity to satisfy the most demanding audiophiles, Node 2i connects your existing system to all your recorded music.
By buying this product you get 54 loyalty points
Reference : 13378
549,00 €tax incl.
457,50 € tax excl.
Shipping from France
Billing in France
Technical support in France
Ce modèle a été remplacé par la version Bluesound Node 3.
BLUESOUND NODE 2i
Multiroom Sreamer
Bluesound Node 2i Lecteur réseau multiroom
The Bluesound Node 2i streamer, successor of Node 2, takes up what made the success of its big brother by bringing technical improvements to make it an even more powerful network reader. As a result, its wireless connectivity capabilities are improved with a Bluetooth 4.2 version, providing more stable, fast and secure transmission. Similarly, Ethernet and Wifi modules have been improved to provide higher bandwidths.
The Node 2i connects very easily to your stereo system to open the doors of streaming audio. With a wide range of analog and digital connectivity to satisfy the most demanding audiophiles, Node 2i connects your existing system to all your recorded music. You have access to your favorite music streaming services, Internet radios, your own library of audio files stored on your computer / NAS, your smartphone or an external player.
Invent your HiFi system
Designed to provide wireless connectivity to traditional HiFi systems (including amplified speakers), Node 2i offers new horizons for your stereo system. Allowing you to enjoy your own files, favourite internet radios or streaming services, Node 2i is also very well designed to participate in high quality audio playback.
When HiFi rhymes with WiFi
Node 2i has improved its connectivity with WiFi dual-band which offers first-class performance even in a crowded environment. The device also offers the Bluetooth with support for aptX HD technology that improves transfer rate and stability. Thus, it is possible to stream files up to 24-bit from your smartphone or any other Bluetooth enabled device as well as to transmit your music to Bluetooth enabled headphones and speakers. In addition, each Bluesound player like the Node 2i has a high-end DAC to convert high quality files and even MQA files.
Your music at your fingertips
With a wide range of analog and digital inputs and outputs, Node 2i allows you to connect the vast majority of HiFi devices. Thus, if the Node 2i allows you to access streaming audio, it also allows you to connect an amplifier and a CD player to it, for example, to continue to enjoy your music on a physical medium. And even using a classic source, you can still play your music anywhere in your home.
Accédez à ; vos services préféférérés
With the integrated Airplay 2 protocol for easy communication with Apple devices, Node 2i is one of the most flexible streamers. Many music streaming services are available such as Qobuz, Spotify or Deezer but also internet radios via the BluOS Controller application. You can also access your downloads, iTunes library or files stored on your NAS without having to turn on a computer.
Your music throughout the house
As the Node 2i is a multiroom network player, it is very easy to play your music throughout your home. To control the entire connected system, everything is done via the BluOS application, which offers easy flow management.
Insérer texte alternatif ici
They talk about it....
" This is one of the most portable devices I've listened to in a long while and was a genuine pleasure to review. "
" There's a new leader in wireless multi-room music market - Bluesound combines high-res audio and ease of use in one impressive system. "
" When it comes to multi-room audio, it really doesn't get better than this "
Qobuzissime for the Bluesound Node 2
(Review by Qobuz)
" This Bluesound Node 2 network player, while perhaps requiring better support, is an excellent network player with a modern look and design, easily integrated and offering first-class sound performance on its analog outputs, including the headphone output. "
Test Qobuz et Qobuzissime
Spécifications audio
Supported file formatsMP3, AAC, WMA, OGG, WMA-L, ALAC, OPUS
High-res formats: FLAC, MQA, WAV, AIFF
Native sampling rates32 - 192kHz
Bit depths16 - 24bits
SNR-110dBA
Distortion, THD+N-0.005%
DAC32bits 192kHz
Supported OSWindows XP / 2000 / Vista / 7 / 8 / 10
Mac 7 - 10
Free internet radiosTuneIn Radio, iHeart Radio, Calm Radio, Radio Paradise, Slacker Radio
Supported cloud servicesQobuz, Spotify, Amazon Music, Tidal, Deezer, HighResAudio, Murfie, JUKE, Napster, KKBox, Bugs, Taihe Music ZONE, SoundMachine
Integration partnersControl4, RTI, Crestron, URC, Push, iPort, ELAN, Lutron, Roon, Amazon Alexa Skills*, Airplay 2*
Some services, features and technologies will be available soon with a firmware upgrade
Connectivity
NetworkWifi Gigabit 802.11ca dual band
Ethernet RJ45
USB1x USB-A (FAT32 or NTFS formated)
1x Mini USB-B (product servicing)
Audio inputsOptical Toslink / Jack 3.5mm Combo
Audio outputsStereo RCA
Coaxial
Optical Toslink
Jack 3.5mm
Subwoofer RCA output
Trigger 12V
Bluetooth version and technologyBluetooth 4.2 aptX HD
Bi-directionnal
User interfaceBluOS mobile app, available on Android and iOS
Pushbutton
Touch controls
IR Sensor
ProcessosARM Cortex A9 1GHz
Weight1.12kg
Dimensions220 x 46 x 146mm
Consumption6W
Accessories2x Power cable (Europe and US formats)
Ethernet cable
RCA cable
Optical Toslink / Jack 3.5mm Adapter
InputRJ45
InputJack 3.5mm
InputWiFi
OutputSubwoofer
OutputCoaxial SPDIF
DAC / ADC ChipPCM5122
Max sampling rate192kHz
4 reviews
Un streamer d'un bon rapport qualité-prix avec une excellente qualité sonore
J'ai acheté le Bluesound Node 2i pour remplacer un serveur de musique MacMini. C'est une très bonne solution ... une amélioration de la largeur et de la profondeur de la scène sonore avec d'excellents détails et une grande clarté. Et un bonus ... plus d'interface USB compromise pour mon système de musique. Le Node 2i est une unité conçue uniquement pour l'audio. Je l'ai connecté à un DAC Multibit Schiit Gungnir avec de bons résultats.
This review has been posted for BLUESOUND NODE 2i Multiroom Streamer 24bit 192kHz MQA
Top
Franchement pas déçu, mise en œuvre ultra simple même pour un ignorant comme moi. Le son est franchement bon, Qobuz fonctionne à merveille, l’accès aux radio web est d’une simplicité enfantine.
Super produit livré en 48h!
Merci audiophonics.
Version améliorée du bluesound 2
Le son toujours aussi magique. La version précédente est hs après 2 ans et...4 mois? d'écoute bien agréable. Le rapport qualité prix top fait que je récidive avec l'achat de la nouvelle mouture. Un gain sensible pour la lecture de fichiers HD Un son fluide moins numérique que son ancêtre.
Mais encore un sérieux bémol ! ! Toujours pas de bouton d'arrêt : Après une coupure de courant l'animal en veilleuse se réveille tout seul ainsi que votre disque dur. Penser à le mettre hors circuit après usage. (Je retire une étoile )
Lecteur Réseau plug and play !
N'étant pas très pointu dans les paramétrages et autres "bidouilles" informatique ou logiciel je recherchais un lecteur réseau simple à mettre en oeuvre et j'ai trouvé mon bonheur grâce au Node 2i , très simple de paramétrage et fonctionnant parfaitement sur mon disque dur de 2to remplit de fichiers Flac et tout aussi bien avec Tidal ou Deezer , le tout complété par une application BlueOs très sympa , rapide et sans aucuns bugs , bref que du bon.
Je suis aussi très agréablement surpris de la qualité du dac interne , branché à mon ampli en rca le résultat est tout simplement parfait !
Merci à Audiophonics qui comme à chaque commande ont étés parfaits ;)
The Bluesound Node 2i Streamer connects very easily to your stereo system to open the doors of the streaming audio. With a wide range of analog and...
