TONEWINNER TY-i2PRO Streamer DAC Black
The Tonewinner TY-i2PRO is an audiophile audio streamer designed to centralize local playback, network streaming and digital-to-analog conversion within a single high-fidelity device. A true home audio hub, it combines a streaming platform running on Android 12, a reference DAC, an audiophile linear power supply and a fully balanced architecture to deliver exceptional sound reproduction.
By buying this product you get 221 loyalty points
Reference : 21709
2 219,00 €tax incl.
1 849,17 € tax excl.
Tonewinner TY-i2PRO Streamer DAC AK4191EQ + AK4499EXEQ WiFi6 DLNA Airplay 32bit 768kHz Black
Photo of the Tonewinner TY-i2PRO
At the heart of the device is the AK4191EQ + AK4499EXEQ combination, a pair of high-end conversion chips renowned for their level of detail, musicality and dynamics. The analog stage uses 3 OPA1612 operational amplifiers, known for their ultra-low noise and minimal distortion, while the power supply relies on 7 ultra low-noise LDO regulators (<0.8µVrms) ensuring stable and perfectly clean voltage for sensitive circuits. The TY-i2PRO also benefits from a precision clock system with dual femtosecond oscillators featuring ultra-low phase noise to drastically reduce jitter, as well as a dual-rail linear power supply with magnetically shielded transformer.
Compatible with high-resolution audio streams up to PCM 32bit 768kHz, it offers particularly comprehensive connectivity with dual-band WiFi 6, Gigabit RJ45 Ethernet, USB 3.0, USB 2.0 OTG, Micro SD reader, internal 3.5" HDD bay, stereo RCA outputs, balanced XLR output, coaxial, optical Toslink and HDMI. Its technical performance reaches THD ≤ 0.000063%, SNR ≥ 129dB, channel separation greater than 124dB, with an output level of 2Vrms.
Key features of the Tonewinner TY-i2PRO
Tonewinner TY-i2PRO: Modern streaming & high-speed network
Designed for current uses, the device offers complete network connectivity:
  • Fast and stable dual-band WiFi 6
  • Gigabit RJ45 for optimal wired connection
  • Control via mobile application
  • Local network file management
WiFi 6 improves speeds, stability and resistance to interference, particularly useful for Hi-Res streaming.
TONEWINNER TY-i2PRO: modern streaming & high-speed network
TONEWINNER TY-i2PRO: advanced local playback & massive storage
Tonewinner TY-i2PRO: Advanced local playback & massive storage
The TY-i2PRO is not limited to streaming. It can also become a true home music server thanks to its many storage options:
  • Internal bay for 3.5" hard drive
  • USB 3.0 port
  • USB 2.0 OTG port
  • Micro SD reader
  • File management and copying via network or USB
This makes the TY-i2PRO an ideal solution for large music libraries.
Tonewinner TY-i2PRO: Modern interface & ease of use
The Tonewinner TY-i2PRO features a 5-inch HD color touchscreen offering smooth and intuitive navigation through the user interface. It allows display of album covers, system menus, currently playing audio formats, the music library and various network settings. Designed for comfortable daily use, the device also comes with a multifunction remote control combining Bluetooth, infrared and Air Mouse technologies, enabling precise and convenient control from the sofa or listening position.
TONEWINNER TY-i2PRO: modern interface & ease of use
Tonewinner TY-i2PRO: Control App
The Tonewinner control app gives you access to a control center for streaming audio tracks from your local library (USB device, Micro SD card, etc.) or via streaming services.
Tonewinner TY-i2PRO: A Control App
Overview of the Tonewinner TY-i2PRO
Overview of the TONEWINNER TY-i2PRO
12x RCA line output
2XLR line output
3Coaxial output
4Optical Toslink output
5Link port
6Trigger out
7Antenna 2
8RJ45 LAN Ethernet port
9USB-A 3.0 input
10USB-A 2.0 input
11HDMI output
12Memory card slot
13Antenna 1
14HDD slot
15AC power input
Technical specifications
Product typeStreamer
DAC
DAC chipAK4191EQ + AK4499EXEQ
USB interfaceXMOS XU316
Op-amps3x OPA1612
ProcessorRK3568
Memory4GB (DDR4)+64GB (eMMC)
Input1x USB-A 3.0
1x USB-A 2.0
1x TF card slot
1x HDD slot 4TB
WiFi
Output2x Single-ended RCA
1x Balanced XLR
1x Coaxial
1x Optical
1x HDMI
Other connectivityRJ45
WiFiDual-band (2.4GHz+5.8GHz)
Supported formatsMOA, MP3, APE, WAV, FLAC, AIF, AIFF, CUE
Supported streaming protocolsDLNA, Airplay, Apple Music, QQ Music, Spotify, etc.
Supported sample ratesXLR/RCA output: PCM up to 32bit 768kHz
Coaxial/Toslink output: PCM up to 24bit 192kHz
MQA
DisplayLCD 5"
SNR> 129 dB
THD≤ 0.000063%(1kHz/2Vrms, balanced output)
Output level2 Vrms +/-1.5 dB
Crosstalk> 124dB (balanced output)
Power supply110-230V AC
Power consumptionMax : 50W
Standby: 0.5W
Dimensions444 x 410 x 118mm
Weight9.3kg
Package contents1x Tonewinner TY-i2PRO
1x AC power cable
1x Optical cable
1x Remote control
1x Antenna cable
TONEWINNER TY-i2PRO Streamer DAC AK4191EQ + AK4499EXEQ WiFi6 DLNA AirPlay 32bit 768kHz Black
The Tonewinner TY-i2PRO is an audiophile audio streamer designed to centralize local playback, network streaming and digital-to-analog conversion...
