MATRIX ELEMENT P Streamer / ICEpower Amplifier / DAC ES9028PRO XMOS 32bit 768kHz DSD1024 2x230W 4 Ohm
-50%
The Matrix Element P is presented as a high-end all-in-one device. Indeed, the latter is extremely versatile and takes on the roles of network drive, DAC and amplifier at the same time. All you need to do is combine a pair of passive speakers to enjoy a complete and extremely powerful HiFi system. Performance made possible by careful design but also by the integration of high-end components.
Reduced price!
Reference : 13696
2 795,00 €tax incl.
-50%
1 399,00 €tax incl.
1 165,83 € tax excl.
Last items in stock !
Shipping date: 17-03-2026.
Matrix Element P
xxx
The Core
At the core of the Element P is a powerful ARM Freescale i.MX6 Quad Core processor, responsible for data processing. Matrix has also developed a high-quality audio system based on the Linux operating system. Unlike the brand's previous products, Element P has the ability to read files stored on your network or locally, while performing a powerful D/A conversion.
New generation USB interface
With the rapid development of high quality audio formats and the new user requirements inherent in these developments, Element P had to support many high resolution formats. Its USB interface XMOS XU216 allows it to read PCM files up to 768kHz and DSD up to DSD512. This interface also supports MQA files, a high quality format that is becoming more and more popular.
xxx
xxx
DAC ES9028Pro & Femtosecond Clock
The Element P is equipped with a digital-to-analog conversion chip ESS ES9028Pro. This DAC provides excellent audio performance with high-precision playback. It is associated with an ultra-low phase noise CCHD-950 femtosecond clock from Crystek, guaranteeing an extremely low jitter. A MUSES73320 chip allows precise control of the volume and cleanliness of the analog section.
ICEpower Digital amplification module
The amplification stage of the Element P is left to an ICEpower 250ASX2 module. This Class D amplifier from Denmark allows to deliver a consistent power with no less than 2x230W under 4Ω. The Element P can therefore be easily combined with many speaker models.
xxx
A complete & efficient connection system
The Matrix Element P takes advantage of its extensive connectivity, allowing many devices to be connected to it to create a versatile and high-performance audio system. There are two Toslink Optics, two Coaxial S/PDIF, one I2S HDMI LVDS input, one USB-B connector, two USB-A for your storage devices, one Micro SD slot and of course one RJ45 port. On the output side, there are simply stereo speaker terminals. The rear panel also features two antennas to improve WiFi signal reception.
xxx
AirPlay & DLNA
Today, media streaming via a local network has become commonplace. As a result, Matrix Element P supports DLNA and AirPlay protocols to allow you to stream your music directly from your smartphone or other compatible mobile device.
xxx
xxx
Control playback from your smartphone with MA Remote
For a simple and intuitive control of the Element P, Matrix has specially developed an Android application. This allows you to browse and launch your audio files, whether they are stored on storage devices connected to the device or your local network. Matrix will also provide regular updates to improve the user experience. Tidal and Qobuz streaming services are already available on MA Remote.
MQA Support
MQA is a high-resolution audio coding method that allows you to obtain audio files with high sampling rates while reducing the size of these files. The Element P integrates the support of this technology, ideal for enjoying high quality audio streaming.
xxx
xxx
Strong linear power supply
Power supply is the entry point for all electrical / electronic devices and plays a major role, especially in the case of a high fidelity audio system. Matrix has therefore chosen to integrate in its Element P a linear power supply based on a Noratel custom toroidal transformer as well as Nichicon Audio Grade capacitors. There are also power separators and LDOs on a 4-layer PCB. This power supply provides the entire circuit with a clean electrical signal for a highly transparent sound.
Modern & minimalist design
The Element range from Matrix removes all unnecessary visual elements to offer a modern, minimalist and high-end aesthetic. The Element P thus presents simple lines in a CNC machined Aluminium casing. It will integrate seamlessly into a high-end HiFi system. The entire Matrix Element range has the same design, allowing an aesthetic combination of the different devices.
xxx
xxx
Shielded housing
As each material has its own resonance frequency, Element P was designed with a double structure. The inner shell uses galvanized metal folded with reinforcing ribs to ensure robustness in all conditions. The outer shell is made of 4mm thick Aluminium. The assembly of these two materials makes it possible to modify their resonance frequencies and reduce the negative impact of resonances on sound reproduction.
Comparaison of Matrix Devices
Spec DeviceElement XElement PElement MElement IMini-i 3Mini-i Pro 3
DAC chipES9038 PRO + ES9311ES9028 PROES9038Q2M
DAC ChipXMOS U216XMOS U208XMOS U216
PCM : 16-24Bit 768kHz
DSD : 11.2MHz (DoP)
DSD : 22.4MHz (Native)
PCM : 16-24Bit 384kHz
DSD : 5.6MHz (DoP)
DSD : 11.2MHz (Native)
DSD : 11.2MHz (DoP)
MQA : 24bit 384kHz
DSD : 11.2MHz (DoP)
ClocksCrystek CCHD-950
Ultra Low Phase Noise
Femtosecond
SiTime Low Phase NoiseCrystek CCHD-950
Femtosecond
Digital InputsOptiquex2x1
Coaxialx2x1
I2S (LVDS)x1
Bluetooth
Réseau
USBx1 USB-Bx1 USB-C
Line InRCAx2
Line OutRCAx1x1
XLRx1x1
Amplified output2×230W@4Ω
Headphone OutXLR4 & Dual XLR3x1
Single-Ended 6.35mmx1x1
Balanced 4.4mmx1
NetworkLAN10BASE-T/100BASE-TX
WLAN2.4GHz/5GHz
IEEE 802.11
a/b/g/n/ac
2.4GHz
IEEE 802.11
a/b/g/n
Non2.4GHz/5GHz
IEEE 802.11
a/b/g/n/ac
MA Remote compatibilityQobuz, Tidal support
Volume controlHyper-Control
Relay + Digital Volume
MUSES 72320
Volume resistor network
Digital volume
Storage DeviceTF Card
USB HOST X2
USB HOST X2
NAS SupportSMB V1.0 & V2.0
ARMQuad-CoreDual-CoreSingle-Core
DriveLocal filesMP3 , WMA , WAV , AIF, AIFC, AIFF, AAC, FLAC, OGG, APE, ALAC, M4A, DSF, DFF
AirplayAirplay 1Airplay 2
DLNA
Roon Ready
MQADecoder + RendererDecoder + Renderer
IR remote
Power SupplyLinear Noratel
40W
Linear Noratel
25W
Linear
30W
External AC Adapter
20W
Linear Noratel
20W
Dimensions340×281×60mm275×281×60mm240×220×55mm223x205x48mm
Weight4.2Kg4.7Kg3.7Kg1.5Kg1.7Kg
Product typeStreamer / Amplifier
Inputs2x Coaxial S/PDIF
2x Optical Toslink
2x USB-A
1x I2S HDMI LVDS
1x USB-B
1x Micro SD slot
1x Ethernet RJ45
WiFi
OutputSpeaker terminals
Supported sampling rateCoaxial, Optical : PCM up to 24bit 192kHz / DoP DSD64
I2S HDMI LVDS : PCM up to 32bit 768kHz / Native DSD up to DSD1024 / DoP DSD256
USB : PCM up to 24bit 768kHz / Native DSD up to DSD512 / DoP DSD256
SNR (speaker output)> -121dB
THD+N (speaker output)< 0.008% @ 1W (8Ω, 1k)
Frequency response (speaker output)20Hz-20kHz ±0.25 -3dB @ 85kHz
Output impedance (speaker output)< 25mΩ
Ouput power (speaker output) (THD+N = 1%)230W @ 4Ω
110W @ Ω
Gain (speaker output)+40dB
WLAN2.4GHz/5GHz, IEEE 802.11 a/b/g/n/ac
Supported file formatsMP3, WMA, WAV, AIF, AIFC, AIFF, AAC, FLAC, OGG, APE, ALAC, M4A, DSF, DFF
Voltage supplyAC220-240V 50/60Hz
AC100-120V 50/60Hz
Dimensions340 x 281 x 60mm
Weight4.7kg
Package1x Matrix Element P
1x RM3 Remote control
1x USB Cable
2x WiFi antennas
1x Power cable
InputMicro SD
InputI2S via HDMI
InputRJ45
InputWiFi
DAC / ADC ChipES9028PRO
Max sampling rateDSD1024
Max sampling rate768kHz
ColorSilver
Channel2 (Stereo)
Amplifier chipICEpower 250ASX2
Power (W)230.0
Remote ControlYes
Streaming services & Network protocolsQobuz
Streaming services & Network protocolsDLNA
Streaming services & Network protocolsRoon / Roon Bridge / Roon Ready
Streaming services & Network protocolsTidal
The Matrix Element P is presented as a high-end all-in-one device. Indeed, the latter is extremely versatile and takes on the roles of network...
