DAYTON AUDIO DAX88HUB Keypad Hub for DAX88
The DAX88 lets you connect up to eight control keyboards per device. With the DAX88HUB, you can connect all your keyboards to the DAX88 with a single Ethernet connection.
Reference : 20645
119,00 €tax incl.
99,17 € tax excl.
Grantie 5 ans
Dayton Audio DAX88HUBKeypad Hub for DAX88
Dayton Audio DAX88HUB picture
The DAX88 lets you connect up to eight control keyboards per device. With the Dayton Audio DAX88HUB, you can connect all your keyboards to the DAX88 with a single Ethernet connection. Each keyboard connects directly to the DAX88HUB via an Ethernet cable. The DAX88HUB then connects to the DAX88 with a single Ethernet cable to simplify installation and reduce cable clutter.
Dayton Audio DAX88HUB connection
Product typeKeyboard control hub
Connectors8x Ethernet RJ45 for keypad
1x Ethernet RJ45 to DAX88
Dimensions48.3 x 4.5 x 5.7cm
Package1x Dayton Audio DAX88HUB
The DAX88 lets you connect up to eight control keyboards per device. With the DAX88HUB, you can connect all your keyboards to the DAX88 with a...
