LHY AUDIO AS6 Network Switch Black
With the AS6, LHY Audio offers us a network switch, an evolution of the SW6-SFP model, including 5 RJ45 ports, one of which benefits from digital isolation, a fibre optic SFP port and a BNC input connected to the integrated 10mHz OCXO clock. All of this is housed in an elegant anodised aluminium enclosure machined from solid material and designed to separate AC current processing, DC current processing and audio signal processing.
By buying this product you get 77 loyalty points
Reference : 20752
779,00 €tax incl.
649,17 € tax excl.
Shipping date: 25-11-2026.
LHY Audio AS6 Network Switch 5x RJ45 1x Optical Fiber Black
LHY Audio AS6 : Front view
With the AS6, LHY Audio offers us a network switch, an evolution of the SW6-SFP model, including 5 RJ45 ports, one of which benefits from digital isolation, a fibre optic SFP port and a BNC input connected to the integrated 10MHz OCXO clock. All of this is housed in an elegant anodised aluminium enclosure machined from solid material and designed to separate AC current processing, DC current processing and audio signal processing.
LHY Audio AS6: Improved power supply
The AS6 differs most from its predecessor in terms of its power supply. Instead of the Talema 15VA encapsulated transformer, the AS6 uses a 30VA Multicomp transformer coupled to an RFI suppression filter. Once transformed, the current passes through a high-speed voltage rectifier, a 3-stage CLC filter circuit and, finally, a LT3042 + PNP linear voltage regulator. This multi-stage processing ensures a perfectly stable power supply without the slightest parasitic noise or artefact.
LHY Audio AS6: OCXO clock and connectivity
In terms of signal processing, the LHY Audio AS6 offers 5 RJ45 ports, one of which is digitally isolated, and an optical SFP port. But that's not all: the AS6 has a high-precision 10 MHz OCXO clock at its heart, itself connected to a 50Ω BNC input if you wish for your network switch to be synchronised to an external clock.
Product typeOptical Fiber Ethernet Network Switch
Interface4x RJ45 ethernet port
1x Isolated RJ45 ethernet port
1x SFP fiber optic connector
1x BNC input for 10MHz clock (input impedance 50Ω)
Power supply220V ~ 240V AC
Dimensions240 x 175 x 50mm
Weight2kg
Package1x LHY Audio AS6
1x Power supply cable
3 reviews
Excellent
Très satisfait de ce switch qui sonne juste avec une belle dynamique. Utilisé en amont d’un système d’écoute au casque hdg, le gain en silence permet à la musique de totalement s’épanouir .
Attention cependant à ne pas le placer dans un empilement d’appareils car le switch a tendance à chauffer, il faut donc l’installer dans un endroit correctement ventilé.
Imbattable dans cette gamme de prix .
This review has been posted for LHY AUDIO AS6 Network Switch 5x RJ45 1x Optical Fiber Black
excellent switch audiophile
Utilisé en amont d'un Streamer Naim ND555, ce switch est vraiment excellent en terme de musicalité et de recul du bruit de fond, encore meilleur que le très bon switch Silent Angel Bonn N8 et son alimentation Forest F1, que j'avais auparavant.
L'alimentation linéaire intégrée permet d'économiser une alimentation externe. Une belle réussite.
Excellent
The AS6 is a beautifully constructed piece of equipment, inside and out.
I used to use 2 Cisco 2960 switches modified for LPS. I first replaced the Cisco nearest my streamer with an AS6 and this brought a very nice increase in sound quality. Better timing. Better note definition. Better bass and better soundstage and imaging.
I then replaced the other Cisco with a second AS6 and this brought similar gains.
If your system is well sorted elsewhere and you stream music as your primary source, you need to try the AS6.
 (3)
With the AS6, LHY Audio offers us a network switch, an evolution of the SW6-SFP model, including 5 RJ45 ports, one of which benefits from digital...
