Filters
Categories level 1
Brand
In stock
Stian L.
Very impressive A7 stereo power amplifier
I must say I'm really impressed by this small power amplifier from 3e audio. It comes standard with OPA1656 op amps and...
Franck B.
Une petite erreur à l'expédition vite réparée
Rapidité de la livraison et écoute du SAV suite à une petite erreur sur la quantité expédiée. Expédition du complément sans...
François P.
Mérite 6 étoiles
Super produit : Roon Core, streamer, SSD et alim linéaire dans une même boîte design. Grande facilité d’utilisation pour une...
New products
  • Ref : 21074
    In Stock
    The Svetlana 12AX7-EH-SV tube is a dual triode tube offering good performance. It is ideal for DIY projects or replacing a defective tube.
    24,90 € 20,75 €Ex.
    In Stock
  • Ref : 21077
    In Stock
    The Svetlana EL34SV tube is a high-voltage power pentode tube with a traditional brown base. It is a faithful reissue of the original Russian EL34. Preferred by many guitarists for its brighter and more punchy sound in the midrange. Also highly sought after by hi-fi enthusiasts. It is ideal for DIY projects or replacing a defective tube.
    79,90 € 66,58 €Ex.
    In Stock
  • Ref : 21081
    In Stock
    The Svetlana 6N1-P is a dual triode tube with equipotential cathodes, designed to amplify low-frequency voltage in the output stages of HI-FI audio systems. It is ideal for DIY projects or replacing a defective tube.
    19,90 € 16,58 €Ex.
    In Stock
  • Ref : 21080
    In Stock
    The Svetlana KT88 tube is a glass-enclosed power tetrode tube. It is designed for power amplification. Its high dissipation, strict manufacturing tolerances, and meticulous processing give it increased reliability and superior sound performance.
    129,00 € 107,50 €Ex.
    In Stock
  • Ref : 21086
    In Stock
    An evolution of the famous Dawn Pro, the Moondrop Dawn Pro 2 balanced portable DAC headphone amplifier benefits from numerous improvements. In particular, it features two new CS32198 DAC chips and a HiFi USB interface that supports high-definition sampling rates up to PCM 32Bit 384kHz and DSD256.
    59,90 € 49,92 €Ex.
    In Stock
  • Ref : 21094
    In Stock
    The York Pico ISO C is a USB audio interface designed to offer great flexibility of use beyond conventional USB to I2S applications. It combines a UAC2 interface for audio input and output with a HID interface for user control, such as I2C operations and GPIO control. The ISO version also incorporates galvanic isolation to ensure a perfectly unaltered...
    71,00 € 59,17 €Ex.
    In Stock
  • Ref : 21096
    In Stock
    The Fountek NeoS1.0 ribbon tweeter is a high-quality speaker. It can handle up to 17Wrms of power with a peak of up to 30W. Its nominal impedance is 6 ohms and its frequency response ranges from 1500Hz to 40kHz. Its sensitivity of 92dB makes it very efficient, allowing it to produce sound without requiring high power.
    149,00 € 124,17 €Ex.
    In Stock
  • Ref : 21097
    In Stock
    The Sivga Peng Sivga Peng headphones are closed-back dynamic headphones that combine technology and craftsmanship. They feature 50mm diameter transducers with dynamic diaphragms for high-fidelity sound. Their clear and precise sound reproduction is also immersive thanks to their circumaural design. Their high-end audiophile components are complemented by...
    499,00 € 415,83 €Ex.
    In Stock
  • Ref : 21140
    This Mundorf VL300 coil is build from massive copper wires specially developed to help improve the audio quality when it comes to speaker filtering. This format belongs to Mundorf 's family of high-fidelity components the series of which is made for professional studio use.
    109,00 € 90,83 €Ex.
    In Stock
  • Ref : 21141
    125,00 € 104,17 €Ex.
    In Stock
  • Ref : 21142
    139,00 € 115,83 €Ex.
    In Stock
  • Ref : 21143
    159,00 € 132,50 €Ex.
    In Stock
  • Ref : 21144
    179,00 € 149,17 €Ex.
    In Stock
  • Ref : 21145
    This Mundorf VL300 coil is build from OFC copper wires specially developed to help improve the audio quality when it comes to speaker filtering. This format belongs to Mundorf 's family of high-fidelity components the series of which is made for professional studio use.
    219,00 € 182,50 €Ex.
    In Stock
  • Ref : 21146
    249,00 € 207,50 €Ex.
    In Stock
  • Ref : 21147
    279,00 € 232,50 €Ex.
    In Stock
  • Ref : 21148
    315,00 € 262,50 €Ex.
    In Stock
  • Ref : 21149
    389,00 € 324,17 €Ex.
    In Stock
  • Ref : 21150
    429,00 € 357,50 €Ex.
    In Stock
  • Ref : 21151
    469,00 € 390,83 €Ex.
    In Stock
  • Ref : 21152
    519,00 € 432,50 €Ex.
    In Stock
  • Ref : 21153
    579,00 € 482,50 €Ex.
    In Stock
  • Ref : 21154
    659,00 € 549,17 €Ex.
    In Stock
  • Ref : 21155
    749,00 € 624,17 €Ex.
    In Stock
  • Ref : 21156
    849,00 € 707,50 €Ex.
    In Stock
  • Ref : 21089
    In Stock
    The Ian Canada CmChoker is a two-stage, high-current, wide-voltage common mode filter that effectively suppresses common mode noise introduced by AC power transformers. The CmChoker is specially optimized for audio applications.
    49,00 € 40,83 €Ex.
    In Stock
  • Ref : 21071
    These Oyaide INS-BS insulating feet are machined from brass, a material renowned for its mechanical rigidity and vibration dissipation properties. They are designed to limit unwanted resonance while maintaining the structural stability of the devices they support. A carbon composite (FRP) plate is integrated on one side to optimise vibration transmission...
    99,00 € 82,50 €Ex.
    In Stock
  • Ref : 21072
    In Stock
    The Electro-Harmonix Gold 12AT7EH is a dual triod tube with gold-plated contacts and equipotential cathodes. It is an excellent choice for preamplification.
    25,90 € 21,58 €Ex.
    In Stock
  • Ref : 21073
    In Stock
    The Electro-Harmonix Gold 12AU7EH is a dual triode tube with gold-plated contacts. Its excellent linearity makes it an ideal choice for preamplification.
    26,90 € 22,42 €Ex.
    In Stock
  • Ref : 21079
    In Stock
    The Electro-Harmonix 12AX7EH Gold is a short-plate dual triode tube with gold-plated pins, designed to deliver high gain and extremely low noise thanks to its spiral filament. This tube is a suitable replacement for ECC83 or 7025 tubes.
    34,90 € 29,08 €Ex.
    In Stock
  • Ref : 21082
    In Stock
    The Electro-Harmonix 12BH7EH Gold is a medium-gain dual triode tube capable of dissipating 3.5 watts per plate, featuring gold-plated pins for optimal conductivity.
    38,90 € 32,42 €Ex.
    In Stock
  • Ref : 21085
    In Stock
    The Electro-Harmonix 12BH7EH Gold is a dual triode tube with gold-plated contacts and equipotential cathodes. Designed for Hi-Fi applications, this tube is a great replacement for the 6DJ8, ECC88, 6922, E88CC and 7308 models.
    37,90 € 31,58 €Ex.
    In Stock
  • Ref : 21075
    In Stock
    The Moondrop Pill are OWS (Open Wearable Stereo) clip-on earbuds with a futuristic design and a transparent capsule-shaped charging case. The clip-on design is ideal for comfortable wear and a secure fit, perfect for listening on the go or during a workout.
    44,90 € 37,42 €Ex.
    In Stock
  • Ref : 21076
    In Stock
    44,90 € 37,42 €Ex.
    In Stock
  • Ref : 21078
    In Stock
    The Moondrop Space Travel 2 Ultra wireless in-ear monitors, an improved version of the Space Travel 2, offer excellent sound performance while maintaining an affordable price. They feature a 13mm planar magnetic driver, Bluetooth 6.0 with LDAC support, improved noise cancellation, and a highly customizable equalizer via the Moondrop app.
    39,90 € 33,25 €Ex.
    In Stock
  • Ref : 21133
    49,90 € 41,58 €Ex.
    In Stock
  • Ref : 21134
    64,90 € 54,08 €Ex.
    In Stock
  • Ref : 21135
    59,90 € 49,92 €Ex.
    In Stock
  • Ref : 21136
    69,90 € 58,25 €Ex.
    In Stock
  • Ref : 21137
    79,90 € 66,58 €Ex.
    In Stock
