YORK PICO ISO C Digital Interface USB-C to I2S
The York Pico ISO C is a USB audio interface designed to offer great flexibility of use beyond conventional USB to I2S applications. It combines a UAC2 interface for audio input and output with a HID interface for user control, such as I2C operations and GPIO control. The ISO version also incorporates galvanic isolation to ensure a perfectly unaltered signal.
Reference : 21094
71,00 €tax incl.
59,17 € tax excl.
York Pico ISO C Digital Interface USB-C to I2S 192kHz
York Pico B : Vue de haut
Key features:
  • Flexible configuration: device settings and firmware updates can be managed using a dedicated PC utility.
  • HID Interface: Service information and device configuration
  • Optional Serial Interface (virtual COM port)
  • Multiple Audio Output Options: Supports I2S, S/PDIF, TDM and interfaces for NOS DACs (e.g., AD1862, PCM63, TDA1541 etc).
  • Various Clocking Options: Includes module oscillators, external clock (slave mode), and internal PLL clocking.
  • I2C Integration with DSP: Allows simultaneous audio input/output and DSP programming, like ADAU1452/67
  • No drivers required for Windows 10/11, Linux, MacOS, Android, iOS.
  • Bootloader: Enables easy and fail safe firmware update.
York Pico ISO C: Audio capacity
This digital audio module supports up to eight input and output channels, with sampling frequencies up to 192kHz, extendable to 384kHz via an external clock. It is based on a PIC32MZ microcontroller with MIPS architecture, integrating a high-speed USB interface and a DSP instruction set enabling the implementation of embedded audio processing. The internal clock is provided by two low-noise oscillators of 22.5792MHz and 24.576MHz, dedicated to sampling rates of 44.1 and 48kHz, powered by an isolated LDO regulator. An external clock input is also available, compatible with ratios of 256/512/1024fs.
York Pico B : dimensions
Type of productDigital interface
InputUSB-C
OutputSoldering pads I2S
Sampling rate192kHz
384kHz with external clock
Output formatI2S
TDM
PCM
Clocks22.5792MHz clock
24.576MHz clock
OSNo drivers required for Windows 10/11, Linux, MacOS, Android, and iOS
Dimensions68.58 x 31.75mm
Hole spacing63.5 x 25mm
PackageSold by unit
OutputSolder pad
Max sampling rate384kHz
Max sampling rate192kHz
Interface chipUAC2
Download
YORK PICO ISO C Digital Interface USB-C to I2S 192kHz
The York Pico ISO C is a USB audio interface designed to offer great flexibility of use beyond conventional USB to I2S applications. It combines a...
