Lockable Banana Plugs Gold Plated Ø6mm (Set x4)
These gold-plated copper alloy banana plugs accept cable diameters up to 6 mm. They feature a screw locking system: when the screw is tightened, the pin advances into the slotted tip, the banana plug opens and locks completely into the terminal block. This ensures very low contact resistance and high pull-out resistance. In addition, the tightening screw has the special feature of receiving a second banana plug in order to chain the connectors together.
Reference : 21113
29,95 €tax incl.
24,96 € tax excl.
Shipping date: 25-11-2026.
Lockable Banana Plugs : Front view
These gold-plated copper alloy banana plugs accept cable diameters up to 6mm. They feature a screw locking system: when the screw is tightened, the pin advances into the slotted tip, the banana plug opens and locks completely into the terminal block. This ensures very low contact resistance and high pull-out resistance. In addition, the tightening screw has the special feature of receiving a second banana plug in order to chain the connectors together.
Product typeBanana plugs
Max. cable diameterØ6mm
Contact materialCopper alloy
Contact platingGold
Mounting typeTo screw
Dimensions48 x 28mm
Weight22g / connector
PackageSold by 4 (2 black, 2 red)
Max cable diameter (mm)6.0
ConnecticMale & Female
ConnectorBanana
Une petite erreur à l'expédition vite réparée
Rapidité de la livraison et écoute du SAV suite à une petite erreur sur la quantité expédiée. Expédition du complément sans frais.
Je suis très satisfait du service offert par la boutique en ligne.
Je recommande.
This review has been posted for Lockable Banana Plugs Gold Plated Ø6mm (Set x4)
These gold-plated copper alloy banana plugs accept cable diameters up to 6 mm. They feature a screw locking system: when the screw is tightened,...
