Elevating FM Radio: Integrating Teac PD-301-X with Topping E70 Velvet & B200 for Audiophile Sound I have a Teac PD-301-x FM tuner with excellent sound but only an analog RCA output from the FM Radio. So, to have its sound in...
This female 3.5mm jack to dual male 3.5mm jack splitter lets you connect headphones or headphones with a microphone to your computer's headphone and microphone sockets. The conductors are made of copper to ensure excellent conductivity and the connectors are gold-plated to offer unfailing protection against oxidation.
This USB mains adapter has an EU mains plug and a USB-C connector at the end of a 50cm cable. It accepts 100-240V AC and provides a voltage and current output of 5V 4A. It's ideal for powering a wide range of audio devices.
The RT-5000 from Roseselsa is a DAC and amplifier for headphones using a pair of SABRE ES9038Pro chips and JRC MUSES01 transistors for digital/analogue conversion up to PCM 32bit 384kHz and DSD256 and an output power of 1600mW at 32Ω. These top-of-the-range components ensure quality sound reproduction that's both warm and soft, all housed in a...
Roseselsa's Distant Mountain are retro-looking headphones featuring a dynamic 40mm driver for rich, full-bodied reproduction with good treble extension. Moreover, the headphones are pleasant to wear thanks to their solid, skin-friendly materials and adjustment options.
This USB power adapter has an EU plug and a USB-A connector output. It accepts 100-240V AC and provides a voltage and current output of 5V 2A. It's ideal for powering a wide range of audio devices.
The Douk Audio ST-01-Plus is a powerful and versatile phono amplifier. It's based on a TPA3255 amplifier chip for output power of up to 2x 120W under 4 ohm with the supplied 48V 5A power supply. It also features Bluetooth 5.2 functionality, with support for high-definition SBC, aptX, aptX-LL, aptX-HD codecs thanks to a QCC304X chip.
With the RSV, Softears presents in-ear earphones featuring 5 balanced armature drivers and a complex crossover network to deliver a reference sound for the brand, with enveloping low frequencies and a natural timbre. The earphones feature a magnificent aesthetic, combining carbon fibre and gold foil.
Softears Volumes S are hybrid in-ear monitors combining two dynamic drivers and two balanced armature drivers to deliver a natural sound reproduction with powerful, punchy bass. Softears has put all its design expertise into solving the technical challenges of multi-driver earphones, delivering sound reproduction of rare coherence in an aesthetically...
With the Studio4, Softears presents in-ear monitors specially developed for professional use. Relying on 4 Balanced Armature drivers, these earphones offer the most neutral sound possible, making them ideal for monitoring or in a recording studio.
With the Twilight, Softears presents top-of-the-range dynamic in-ear earphones whose lightweight, high comfort fit is only equalled by the quality of their sound reproduction. They have benefited from intensive research and development work to perfect a dynamic driver and associated acoustic cavity offering the most striking sound possible.
The Douk Audio MC303 is a passive XLR selector with 3 inputs and 3 outputs. The contacts of the XLR connectors are gold-plated for perfect signal transmission and increased resistance to corrosion and oxidation.
The Little Bear MC3 is an XLR/RCA converter switch. It has one RCA and two XLR inputs, and the same applies to its outputs. It can therefore be used as a passive switch or as a symmetrizer / desymmetrizer, depending on the user's application. Input and output are selected via two potentiometers on the front panel.
The Ampapa A1 is a phono preamplifier specially designed for compatibility with MM cells, based on the use of two JAN5654 tubes for a warm, vintage sound, no less clear and precise.
The iEast AMP80 V2 is a versatile, high-performance Class D connected amplifier. It's based on a TDA7498E amplifier chip and an ESS ES9023 DAC chip, enabling it to support up to 24bit 192kHz and deliver up to 2x80W of power under a 4 ohm load. This compact little gem of technology supports WiFi, Ethernet and Bluetooth 5.0 (SBC) connections, so you can...
With the Robin, Moondrop presents wireless in-ear monitors developed in collaboration with the game Honkai: Star Rail. These are based on a pair of drivers combining dynamic and planar magnetic technology to provide effective coverage of the entire frequency band. The Robin have been designed to be extremely ergonomic, with a shape that makes them...
The Douk Audio K5 is a DAC headphones amplifier based on an audiophile chipset for excellent performance. Its chipset comprises an ES9038Q2M DAC chip, a SA9312 DSP, an OPA1678 OPA and an SGM8262 amplifier chip. It is therefore able to support high-resolution sampling rates up to PCM 32 bit 384kHz and DSD256, while delivering up to 560mW of power under 32...
The Douk Audio DAC-Q11 is a unique device featuring two switchable DAC chips. It features an ESS ES9038Q2M chip and an AKM AK4493 chip. Each of these chips supports high-resolution sampling rates up to PCM 32bit 384kHz and DSD256. Users can therefore enjoy both the renowned dynamics of ESS chips and the refined tones of AKM chips.
Sommercable's Epilogue cables feature two Neutrik XLR connectors, male on one side and female on the other. The cables are of high quality design and are based on four copper conductors with a cross-section of 0.14mm². Each of these conductors is covered with a thin layer of carbon before being wrapped in insulation. This layer of carbon not only...
Viablue's 24k gold-plated T8 banana plug contacts allow you to make your own cables by soldering the contact directly to the conductor. You can also screw these plugs to the body of Viablue T8 banana plugs, allowing you to replace faulty connectors, for example.
This LHY Audio 3.3V 1.5A low-noise voltage regulator module uses the recommended integration method of the Analog Devices LT3042 + PNP high-end regulator. This provides near-zero noise voltage regulation and a high output current of 1.5A. It can therefore deliver a pure power supply for DACs, high-precision measuring instruments, noise-sensitive RF...
The 7Hz Artemis39 is a compact portable DAC, equipped with an ESS ES9039Q2M chip offering rich, detailed sound and supporting high-resolution audio streams up to PCM 32bit 384kHz and DSD256. What's more, this DAC ensures low power consumption, which combined with an 1100mAh battery, provides comfortable autonomy with up to 10 hours of continuous playback.
LAiV Audio Harmony GaNM power amplifiers represent excellence in power amplification, coming in the form of two mono blocks exploiting gallium nitride (GaN) transistors for 200W of amplification at 8Ω per block, offering uncompromising sound quality. The meticulous attention paid to every aspect of the Harmony GaNM, from its ultra-low-noise power...
This low-noise DNR resistor from Dayton Audio is mainly used in L-PAD loudspeaker crossovers and attenuators. This 20 Ohm resistor has a high thermal conductivity ceramic core, internal solder assembly, OFC copper wires and a low inductance wirewound, making it perfectly suited to DIY assembly.
This IEC C13 Neotech NC-P303II connector will enable you to design your own high-performance cables. It incorporates G-UPOCC composite contacts, a combination of OCC copper and graphene. This new conductor marks a significant advance, both in terms of research and industrial applications. The addition of graphene improves the stability of electrical...
This low-noise DNR resistor from Dayton Audio is mainly used in L-PAD loudspeaker crossovers and attenuators. This 4 Ohm resistor has a high thermal conductivity ceramic core, internal solder assembly, OFC copper wires and a low inductance wirewound, making it perfectly suited to DIY assembly.
The Keces Ebravo is a versatile audio streamer designed to deliver a high-quality music listening experience. Compatible with many popular streaming services such as Spotify, Tidal and Qobuz, as well as UPnP and DLNA network protocols, it gives you easy access to your favorite music. It can handle audio signals up to PCM 24bit 192kHz. The Ebravo supports...
The SMSL VMV A1 Pro is an innovative amplifier that uses Gallium Nitride (GaN) transistors to deliver 2x160W of amplification at 4Ω. Its versatility also allows it to operate in pure mono mode, delivering an impressive 400W into 4Ω. Every component of the VMV A1 Pro has been meticulously selected to achieve exceptional audio performance, with...
This low-noise DNR resistor from Dayton Audio is mainly used in L-PAD loudspeaker crossovers and attenuators. This 2.4 Ohm resistor has a high thermal conductivity ceramic core, internal solder assembly, OFC copper wires and a low inductance wirewound, making it perfectly suited to DIY assembly.
This WIMA MKP 10 capacitor has good filtering capacity, making it suitable for a wide range of applications. It also benefits from a quality design ensuring a long service life, even at high temperatures.
The Douk Audio A5 Pro integrated amplifier, big brother of the A5, is a small amplifier based on audiophile components with a singular aesthetic. It's based on a TPA3255 amplifier chip and OPA NE5532, enabling it to deliver output power levels of up to 2x 120W under 4 ohm with the supplied power supply. Its PFFB circuit reduces distortion and greatly...
The Douk Audio A5 integrated amplifier is a small amplifier based on audiophile components with a singular aesthetic. It relies on a TPA3255 amplifier chip and OPA NE5532 to deliver up to 2x120W under 4 ohm with the supplied power supply. Its PFFB circuit reduces distortion and greatly improves frequency response for accurate, authentic sound...
With the UP6, Shanling presents a portable balanced headphone DAC and amplifier based on two ESS ES9069Q chips and two SGM8262 OPAs to offer conversion up to PCM 32bit 768kHz and DSD512 and an output power of 195mW at 32Ω single-ended and 626mW at 32Ω balanced.
