Reçu dans les temps ...
This power module allows a comfortable power in a volume of restricted space.
Ideal for powering an Amplifier.
Thanks to the use of 4 diodes FCU2040A, each mounted independently on a heat sink, this power supply indeed makes it possible to reach a rectified voltage of 63V .
On the filter side, there are no less than 4 Nippon Chemi-Con capacitors each 10000μF / 63V with automatic discharge which are used.
The output stage also benefits from first-order filtering with 2 VISHAY capacitors each of 0.33μF / 160V.
Characteristics :
Input | PCB Connector |
Output | PCB Connector |
Output voltage (V) | 63.0 |
Output current (A) | NC |
Input voltage (V) | N/A |
Power Supply | NC |
Average votes 5.0 / 5 4 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
michel m.
Sami S.
Pierre B.
