Max cable diameter (mm)
Material
Diameter (mm)
Color
Number of conductors
Insulation material
Gilles G.
Pratique
Bastien P.
Epoustouflant !
C'était la première fois que j'achetais des enceintes sans les écouter auparavant, juste en me fiant aux mesures ......
Sherman M.
Great DAC!
I absolutely love this DAC because you can switch between the two chips while you are listening to music to hear the difference.
Nylon Sleeves
Discover all our nylon sleeves, allowing an ideal finishing of your DIY cables, having at the same time a protective and aesthetic role.
  • 8,00 € 6,67 €Ex.
    In Stock
  • Ref : 719
    In Stock
    This sheath from Viablue has a magnificent Red, Grey, White and Black colour. It will allow you to offer your cables an aesthetic covering while giving them greater protection for extended durability. The diameter of the sheath can be adjusted from 6 to 14mm.
    2,80 € 2,33 €Ex.
    In Stock
  • Ref : 5261
    In Stock
    This sheath from Viablue has a magnificent Red, Grey, White and Black colour. It will allow you to offer your cables an aesthetic covering while giving them greater protection for extended durability. The diameter of the sheath can be adjusted from 1.5 to 5.5mm.  When your cable measures 5mm, a reduction in the length of 30%.
    1,70 € 1,42 €Ex.
    In Stock
  • Ref : 7837
    In Stock
    This Viablue Stone braided sleeving accepts cables from 2mm to 6mm in diameter, providing effective protection against mechanical stress. Its fine braiding ensures a totally opaque finish.
    2,90 € 2,42 €Ex.
    In Stock
  • Ref : 7838
    In Stock
    This Viablue Stone braided sleeving accepts cables from 5mm to 13mm in diameter, providing effective protection against mechanical stress. Its fine braiding ensures a totally opaque finish.
    2,80 € 2,33 €Ex.
    In Stock
  • Ref : 4120
    In Stock
    This Viablue Stone braided sleeving accepts cable diameters ranging from 13mm to 26mm, providing effective protection against mechanical stress. Its fine braiding ensures a totally opaque finish.
    4,80 € 4,00 €Ex.
    In Stock
