IFI AUDIO UP TRAVEL Portable Transmitter Receiver Bluetooth 5.2
The iFi Audio UP Travel is a portable Bluetooth receiver-transmitter designed to add wireless functionality to devices that do not have it built-in. It delivers 70mW of output power at 32Ω, utilizing a multi-stage architecture (DAC, amplifier, and Bluetooth module) to minimize internal interference and maintain signal stability during mobile use.
Reference : 21670
99,00 €tax incl.
82,50 € tax excl.
Last items in stock !
Shipping date: 27-11-2026.
iFi audio UP Travel Portable Transmitter Receiver Bluetooth 5.2 QCC1500 LDAC aptX Adaptive LHDC
iFi audio Up Travel
Designed for both mobile environments and in-vehicle installations, it combines extensive connectivity, instant TX/RX switching and simultaneous management of two Bluetooth headsets, enabling the modernisation of an analogue source or the integration of wireless reception into an existing system. This approach allows it to function as a versatile conversion interface within an audio chain, while maintaining consistent transmission suitable for both music and video content.
iFi Audio UP Travel: Audio architecture and performance
The UP Travel is based on a multi-stage architecture in which each component (Cirrus Logic MasterHiFi DAC, amplifier, Bluetooth module) is optimized independently to eliminate interference and preserve the signal. This design delivers 70 mW of output power into a 32-ohm load, which is sufficient to power a wide range of headphones and earbuds while maintaining signal stability even when on the go.
This approach allows you to turn any audio source into a high-fidelity wireless experience, whether in transmitter (TX) or receiver (RX) mode.
iFi Audio Up Travel : Audio architecture and performance
iFi Audio Up Travel : Connectivity and versatility
iFi Audio UP Travel: Connectivity and versatility
The UP Travel features a 3.5mm jack that serves as both an input in TX mode and an output in RX mode, supported by a USB-C input. The bidirectional Bluetooth 5.2 transmits or receives the signal depending on the active configuration, allowing you to pick up an audio signal from a wide range of sources. A physical switch allows instant switching between TX and RX modes, enabling immediate adaptation to the user’s needs.
In addition, the ability to connect two Bluetooth headphones simultaneously allows you to share audio without the need for manual synchronisation or any loss of signal quality. This approach removes technical constraints whilst maintaining consistent sound quality for both users. To ensure an optimal experience, the UP Travel supports a wide range of codecs, from LDAC to aptX Adaptive and aptX LL. Automatic selection of the best-performing codec based on the source and connection conditions ensures broad compatibility with most devices (smartphones, tablets, headphones), whilst maintaining a smooth listening experience even in congested environments.
iFi Audio UP Travel: Smart features and advanced control
The UP Travel features a microphone with Qualcomm cVc technology, which actively filters out ambient noise and echoes in real time, ensuring clear and crisp calls even in noisy environments. This feature is enhanced by Bluetooth 5.2 connectivity, which offers improved stability and extended range, enabling a hands-free experience free from interruptions or distortion.
With a battery life of 10 hours and an ultra-compact design (55x30x16.8mm and weighing 25.7 g), the UP Travel fits easily into a pocket or bag. Its USB-C charging makes it compatible with most chargers, making it easy to integrate into a mobile setup without the need for additional accessories.
For users looking to fine-tune their experience, the UP Travel is compatible with the iFi Nexis app, which allows you to customise settings, update the firmware and access advanced features.
iFi Audio Up Travel: Smart features and advanced control
Product typeBluetooth transmitter and receiver
ProcessorQualcomm QCC5100
Inputs1x Male 3.5mm Jack
1x USB-C
Bluetooth 5.2 (RX)
Outputs1x Male 3.5mm Jack
Bluetooth 5.2 (TX)
Supported Bluetooth codecsLDAC, LHDC/HWA, aptX Adaptive, aptX LL, aptX, AAC, SBC
Battery life≥ 10 heures
Battery400mAh
Load5V / ≥500mA
Power70mW/1.5V @ 32Ω
SNR≥ 120dB @ 32Ω
THD+N≤ 0.004% @ 1kHz, 32Ω
Dimensions55 x 30 x 16,8mm
Weight25,7g
Package1x iFi Audio UP Travel
1x USB-C to USB-C cable
1x USB-C to USB-A adapter
1x Aeroplane headphone adapter
IFI AUDIO UP TRAVEL Portable Transmitter Receiver Bluetooth 5.2 QCC1500 LDAC aptX Adaptive LHDC
The iFi Audio UP Travel is a portable Bluetooth receiver-transmitter designed to add wireless functionality to devices that do not have it...
