FIIO JA11 DAC Adapter
The FiiO JA11 is a portable USB DAC designed to handle digital-to-analogue conversion using a compact architecture capable of processing high-resolution audio streams up to 32-bit/384 kHz PCM and DSD128.
Reference : 21654
14,57 €tax incl.
12,14 € tax excl.
FiiO JA11 DAC Adapter USB-C Male to Jack 3.5mm Female 32bit 384kHz DSD128
FiiO JA11 : Front view
The FiiO JA11 is a portable USB DAC designed to handle digital-to-analogue conversion using a compact custom architecture capable of processing high-resolution audio streams up to 32-bit 384kHz PCM and DSD128.
Designed for use on the go with wired earphones, it features microphone signal management and inline controls, allowing you to use call and control functions without interrupting the audio stream.
This approach is based on a design that combines magnesium-aluminium alloy connectors with a palladium-plated OFC copper cable, ensuring signal integrity whilst minimising the stresses caused by repeated handling.
FiiO JA11 : PCM 32bit 384kHz / DSD128
Thanks to the built-in DSP and the FiiO Control app, available on Android and iOS, you can adjust the equalisation settings. This allows you to tailor your listening experience to suit your personal preferences and the frequency response of your earphones or headphones.
FiiO JA11 : EQ
Technical Specifications
Product typeDAC adapter with DSP
Input1x USB-C
Output1x Jack 3.5mm
DAC chipCustom
Supported sample ratesPCM up to 32bit 384khz
DSD128 DoP
PackageSold by unit
OutputJack 3.5mm
DAC / ADC ChipNC
Max sampling rate384kHz
Max sampling rateDSD128
FIIO JA11 DAC Adapter USB-C Male to Jack 3.5mm Female 32bit 384kHz DSD128
The FiiO JA11 is a portable USB DAC designed to handle digital-to-analogue conversion using a compact architecture capable of processing...
