By buying this product you get 37 loyalty points
Streamer, DAC and amplifier
Audiophonics unveils its RaspTouch Amp ES9023, a brand new version of its ready-to-use RaspTouch. In fact, it incorporates an I-Sabre Amp DAC ES9023, with the particularity of combining both an ES9023 converter and a Class D 2x30W TPA3118 Class D amplifier. Simply plug in your speakers and enjoy the music stored on your server or locally.
With the RaspTouch Amp 9023 you are completely free to choose the operating system that best suits your preferences and needs.
Ready to use electronically, many software solutions exist to meet all your expectations: piCorePlayer, Max2Play, OSMC...
Do you want to enjoy your music throughout your home? The Rasptouch offers you an efficient multiroom system, allowing you to stream your files on any turntable connected to your network and control them.
With its I-Sabre ES9023 converter, the RaspTouch Amp is capable of playing high-resolution audio files, up to 24bit 192kHz. A clock complements this one to reduce the jitter drastically, to offer you an excellent sound reproduction.
The DAC ES9023 is backed by a Class D TPA3118 amplifier from Texas Instrument, which delivers 2x30W power at 8 Ohms with a high efficiency of over 90%. The TPA3118 incorporates an advanced oscillator/PLL using frequency switching technology to avoid AM interference. In addition, the amplifier incorporates numerous protections against short circuits, excessive temperatures and over/undervoltages. This prevents damage to the equipment.
Raspberry Pi
Version 3 Model B+
ESS DAC
ES9023
Texas Instrument Amplifier
TPA3118
Featuring a 7"touch screen, it allows you to easily and intuitively control your audio library via a graphical interface.
Mounted in a 100% CNC-machined aluminium housing in France, its black colour and matt appearance give it a modern and contemporary design. A device that will fit perfectly into your high-end audio system.
Connectors | |
Raspberry Pi Inputs | 4x USB-A 1x Ethernet RJ45 1x Micro SD |
Raspberry Pi Outputs | 1x HDMI |
ES9023 Outputs | 1x Stereo RCA |
Raspberry Pi 3 B+ | |
SoC | Broadcom BCM2837B0 |
CPU | ARM Cortex-A53 1.4GHz 64bit |
Wifi | 802.11n |
Bluetooth | 4.2 |
GPU | Multimédia IV Videocore Coprocessor Dual Core |
RAM | LPDDR2 1Go |
ES9023 DAC | |
Clock | 1x |
Sampling rate | 24bit 192kHz |
Capacitors | 2x Condensateurs électrolytique 50V |
TPA3118 Amplifier | |
Type | Class D |
Ouput power | 2x30W @ 8 Ohm |
Efficiency | > 90% |
Protections | Short circuit Temperature Surge |
Screen | 7" Capacitive tactil |
Screen resolution | 800 x 400px |
Case color | Black |
Case material | Aluminium |
Accessories | Power supply DC 5.5 / 2.5mm 24V 4A |
Input | RJ45 |
Input | Micro SD |
Output | Speaker terminal |
Output | RCA |
Output | HDMI |
DAC / ADC Chip | ES9023 |
Max sampling rate | 192kHz |
Color | Black |
