DAYTON AUDIO DS315-PR Passive Radiator Paper 16.8 Hz Ø30cm
Significantly increase the performance of your speakers in low frequencies with a high quality passive radiator. These demotorized HPs are suitable for new construction or replacement to repair another already assembled speaker.
Reference : 12638
59,90 €tax incl.
49,92 € tax excl.
Shipping date: 15-09-2026.
Grantie 5 ans
Passive Radiator DS315-PR 12 Inches
Passive Radiator SD315-PR Dayton Audio
The passive radiator SD315-PR is useful accessory to enjoy a more powerful and richer sound in the low frequencies. A useful feature for extending the bandwidth of a pregnant and give a boost to your speakers to venture more readily in the bass.This model large diameter (12 inches / 30 cm) and excursion rates make it an ideal and economical solution to strengthen a subwoofer. Its size allows it to operate in simple installation (1 subwoofer radiator 1) with a loudspeaker of medium size.
It may also (and especially) use this radiator in more complex installations (several radiators 1 subwoofer). The SD315-PR-12 is an excellent candidate for this approach because its size and excursion rates allow much more massive facilities (2 radiators for 1 Subwoofer size and similar excursion)
Versatile installation
Speaker SD315 view from below
A location offers the possibility to install additional weight to vary the rendering of Audible SD315-PR radiator. We can reduce the resonance frequency and increase the QMS (mechanical Qualie).
SpEcficatIOns
Typepassive radiator
Nominal diameter12 inches
Resonant frequency16.8 Hz
Mechanical Q0.45
Compliance of the suspension0.45 mm / N
Diaphragm mass (air included)200.00g
ConePaper
EnclosureRubber
Total diameter3. 15 mm
Total Depth83 mm
Speaker Power (W RMS)NC
Speaker TypePassive Radiator
Impedance (Ω)NC
Loudspeaker diameter (mm)300.0
Diaphragm typePaper
Max Linear Excursion (Xmax) (mm)10.0
Lowest frequency (Hz)N/A
Highest frequency (Hz)N/A
Significantly increase the performance of your speakers in low frequencies with a high quality passive radiator. These demotorized HPs are suitable...
