By buying this product you get 378 loyalty points
Due to the nature of matte finishes, slight variations in gloss levels may occur depending on the production batch.
The AsciLab A6B are passive bookshelf speakers offering precise, powerful sound reproduction in a compact format. These 2-way speakers feature a 1“ alumina ceramic dome tweeter with custom waveguide and phase tapping, combined with a 6.5” Purifi aluminum woofer, all housed in an enclosure with two Purifi passive radiators. The Purifi 6.5" passive radiators provide a considerable boost at low frequencies. The frequency response of the A6B goes down to 32Hz (-6dB). Their design allows for lower crossover points and reduced distortion, for an extremely clear sound reproduction. The A6B feature a fourth-order crossover at 1kHz, optimized via Klippel NFS, and support up to 500W of amplification. These premium loudspeakers are ideal for demanding audiophile or professional studio use.
AsciLab A6B tweeters feature a waveguide and internal phase plug designed to precisely manage sound dispersion. These elements avoid phase interference, reduce internal resonance and improve off-axis dispersion. The advantages of this type of configuration translate into a more linear frequency response, reduced distortion and better spatialization of sound, offering a more coherent soundstage.
Despite their relatively compact size, the 6.5" Purifi woofers of the AsciLab A6B speakers are capable of sounding spaces of up to 25m², thanks to their powerful, well-defined bass. The aluminum cone ensures perfect low-frequency reproduction. It provides exceptional rigidity for faithful, distortion-free reproduction, even at high volume, thanks to a strong limitation of cone deformation at high sound pressure. Powerful and dynamic, these Purifi woofers deliver near-perfect performance.
AsciLab A6B speakers feature a passive radiator at the rear. These limit unwanted resonance while optimizing low-frequency reproduction. This solution also helps reduce distortion at high volumes, unlike a bass-reflex port, which can generate turbulence. AsciLab has also chosen to integrate two passive radiators to maintain a relatively compact speaker design.
The materials used in the A6B crossover system are non-magnetic, to avoid any hysteresis effects that could cause energy dissipation and distortion. Furthermore, each loudspeaker is tuned using a Klippel NFS system, for precise rendering.
"This is a speaker you have to experience. It will easily blow away any expectations you have. I would give the A6B a serious consideration for mixing and mastering in smaller rooms. Needless to say, I am going to recommend the Ascilab A6B speakers."
" The AsciLab A6B takes an extremely high‑tech Purifi bass/mid driver and pairs it with a very high‑performance tweeter loaded by a complex waveguide that enables the crossover frequency to be located not far off two octaves below where it would conventionally sit. The result is a nearfield monitor that’s almost unequalled in its tonal neutrality, lack of distortion and ability to reveal detail, not just in the mid band or high end but across the whole audio bandwidth. The A6B was without doubt the surprise monitor of the year. "
| Specifications | |
| Product type | Passive speakers |
| Channel number | 2-way |
| Tweeter | 1" alumina ceramic dome tweeter |
| Woofer | 6.5" aluminum cone woofer |
| Design | With two passive radiators |
| Enclosure material | MDF |
| Finish | Mate |
| Crossover frequency | 1kHz |
| Sensitivity | 82dB @ 2.83V / 1M |
| SPL Max. (Full-bandwidth) | 102dB SPL |
| SPL Max. (>100Hz) | 106dB SPL |
| Frequency response | -3dB @ 37Hz / -6dB @ 32Hz |
| Impedance | Nominal 4 ohm |
| Recommended amplification | 50W - 500W |
| Connection to speaker terminals | 4mm Banana Bare wires Spades |
| General | |
| Dimensions | 40.5 x 22 x 30cm |
| Weight | 12.3kg/speakers |
| Color | White |
| Package | 1x Pair of AsciLab A6B speakers |
| Color | White |
| Impedance (Ω) | 4 |
| Efficiency / Sensitivity (dB) | 82.0 |
| Lowest frequency (Hz) | N/A |
| Highest frequency (Hz) | N/A |
| Power (W) | 500.0 |
| Number of ways | 2 |
| Number of loudspeakers | 4 |
| Speaker type | Passive |
| Speaker form factor | Bookshelf speaker |
