EVERSOLO SE100 Passive 2-Way Bookshelf Speakers (Pair)
The Eversolo SE100 speakers are passive 2-way bookshelf speakers designed to deliver accurate and immersive sound reproduction while blending easily into modern spaces.
Reference : 21453
499,00 €tax incl.
415,83 € tax excl.
EverSolo SE100 Passive 2-Way Bookshelf Speakers 100W 4 Ohms 88dB 55Hz-20kHz (Pair)
EVERSOLO SE100 picture
The EverSolo SE100 speakers are passive 2-way bookshelf speakers designed to deliver accurate and immersive sound reproduction while blending easily into modern spaces. With a sensitivity of 88dB, a frequency response of 55Hz to 20kHz (±3dB), and a recommended power rating of 20W to 100W, they offer wide dynamics and rich musicality. Their square format (290 × 290 × 180 mm) is specially designed to fit perfectly on IKEA Kallax shelves, allowing for elegant integration into your audio furniture or modular system.
EverSolo SE100: A 2-way acoustic design
The SE100 is based on a two-way Blackedge Core architecture, ensuring precise time alignment and excellent phase coherence between the drivers. This approach ensures natural sound reproduction, with clear separation of registers and convincing musical depth. The speakers also feature the RTC Engine (Rapid Transient Coil), based on a high-purity oxygen-free copper voice coil, enabling extremely fast transient response and controlled power. This technology ensures instantaneous transitions between the most subtle nuances and the most dynamic passages, delivering powerful, clean, and perfectly controlled energy, both in wide dynamics and the finest rhythms. The use of a carefully configured tweeter and woofer assembly ensures consistent and detailed reproduction of every track, from subtle passages to powerful transients.
EVERSOLO SE100: a 2-way acoustic design
25 mm Premium Silk Dome Tweeter
25mm Premium Silk Dome Tweeter
At the heart of the high frequencies, the SE100s are equipped with a 25mm premium silk dome tweeter with a neodymium magnet. This component delivers highly refined treble reproduction with natural extension and no harshness, for a clear and transparent soundstage. The response at the top of the spectrum retains its definition even at high listening levels.
5.25
5.25" paper pulp cone speaker
For midrange and bass frequencies, a 5.25" paper pulp cone speaker has been selected. This material promotes natural damping, reducing resonance and delivering warm vocals and structured bass down to approximately 50Hz. The integration of an oxygen-free copper voice coil improves transient response and overall dynamics.
EverSolo SE100: Balanced audio spectrum
Thanks to its carefully crafted acoustic design, the EverSolo SE100 offers balanced audio spectrum reproduction, with a spacious soundstage and precise stereo imaging. Its frequency response of 55Hz to 20kHz (±3 dB) ensures faithful reproduction of every musical detail, while the cabinet architecture and woofer allow for bass extension down to 50Hz, delivering more present, articulate, and natural bass for a speaker of this size. With a sensitivity of 88 dB and a nominal impedance of 4Ω, the SE100 pairs easily with a wide range of hi-fi amplifiers, ensuring dynamic and controlled listening.
EVERSOLO SE100: balanced audio spectrum
EverSolo SE100: Modern, modular, and stylish speakers
Beyond their sound performance, the SE100 speakers stand out for their 1:1 square design and their format, which is specially designed to fit into modular units, including the famous IKEA Kallax shelves. Their high-density MDF cabinet with a matte PU star finish combines rigidity, excellent resonance control, and visual elegance. The speakers are equipped with a removable magnetic front grille made of low-diffraction acoustic fabric, which protects the drivers while preserving sound quality and offering a sleek aesthetic, whether the grille is in place or removed.
EVERSOLO SE100: modern, modular, and stylish speakers
Connecting the Eversolo SE100
Product typePassive speakers
Number of channels2
LoadBass reflex (front vent)
TweeterTweeter premium silk dome 25mm
Woofer5.25" paper pulp cone speaker
Crossover frequency2.6kHz
Body materialHigh-density MDF
FinishMate
Nominal impedance4 ohms
Minimum impedance3.2 ohm
Sensitivity (2.83V @ 1m)88dB
Maximum SPL96dB
Recommended amplifier power20-100W
Max. power180W
Frequency response55Hz-20kHz
Bass extension (-6 dB)50hz
Connection to speaker terminalsBanana plug 4mm
Bare wires
Forks
DimensionsL290mm × W180mm × H290mm
Weight~ 6kg/Speaker
Package1x Pair of EverSolo SE100 speakers
2x Magnetic grilles
Impedance (Ω)4
Efficiency / Sensitivity (dB)88.0
Lowest frequency (Hz)50
Highest frequency (Hz)20000
Power (W)100.0
Number of ways2
Number of loudspeakers2
Speaker typePassive
Speaker form factorBookshelf speaker
EVERSOLO SE100 Passive 2-Way Bookshelf Speakers 100W 4 Ohms 88dB 55Hz-20kHz (Pair)
The Eversolo SE100 speakers are passive 2-way bookshelf speakers designed to deliver accurate and immersive sound reproduction while blending...
