2-Way Bookshelf Speakers 100W 4-8 Ohm 90dB 44Hz-22kHz Black Oak (Pair)
The Indiana Line Nota 260 X bookshelf speaker is a bass-reflex, rear ported model that offers great design quality and sound performance at an affordable price. It is the largest model in the Nota line and is an excellent choice for medium-sized rooms up to 20m², both in a stereo system and in a home theater system.
The timeless shapes of the Indiana Line Nota 260 X emphasize Italian design expertise. The elegantly contoured side panels are finished with a durable and aesthetic vinyl coating. The technical solutions used for the Nota 260 X allow them to deliver an engaging sound with incredibly high dynamics.
The Indiana Line Nota 260 X are two-way speakers, benefiting from the complementary use of two high quality drivers. They integrate a 26mm dome tweeter and a 166mm diameter bass-midrange driver. The bass-reflex port of this model, placed at the rear, allows these speakers to provide deep and punchy bass.
The polypropylene diaphragm of the woofer provides a soft and warm reproduction of the midrange while ensuring a very good reproduction of the low frequencies. The dome tweeter, combined with a neodymium magnet and a radial rear chamber, is located in a specially shaped front panel, improving the dispersion of the high frequencies. The tweeter's crossover only uses air coils and film capacitors, allowing the speaker to deliver clear and accurate high frequencies.
| Specifications | |
| Product type | Bookshelf speakers |
| Number of ways | 2 |
| Number of loudspeakers | 2 |
| Bass-Reflex | Rear |
| Loudspeakers | 1* Bass-midrange speaker Ø16.6cm, polypropylene cone 1* Tweeter Ø26mm, fabric dome |
| Frequency response | 44Hz - 22kHz |
| Sensitivity (2.8V/1m) | 90dB |
| Crossover frequency | 2600Hz |
| Amplification load impedance | 4-8Ω |
| Recommended amplification power | 30 - 100W |
| Recommended room size | < 20m² |
| General | |
| Dimensions (L*H*P) | 205*325*290mm |
| Weight | 5.2kg |
| Color | Black oak |
| Quantity | Pair (2 speakers) |
| Color | Black |
| Color | Wood |
| Impedance (Ω) | 4 |
| Impedance (Ω) | 8 |
| Efficiency / Sensitivity (dB) | 90.0 |
| Lowest frequency (Hz) | 44 |
| Highest frequency (Hz) | 22000 |
| Power (W) | 100.0 |
| Speaker type | Passive |
| Speaker form factor | Bookshelf speaker |
