Q Acoustics 3020i Bookshelf speaker Walnut (Pair)
The Q 3020I inheritsthe qualities of its predecessors (Q3020, multiple award winner). This new version uses a 125mm bass motor and a 22mm treble motor to produce a rich sound that can fill a room while retaining rich, nuanced and deep. For convenience, they can be installed on surfaces, stand or wall mounted.
Reference : 12822
299,00 €tax incl.
249,17 € tax excl.
    Very compact speakers providing considerable soundstage
    Q-acoustic speakers 3020i
    Technology to improve the width of the sound stage
    Speakers Q3020i
    In its new version, the Q3020i cabinet incorporates a bracing point to point . The latter, as well as fasteners are extremely rigid and stable which promotes good development of the stereo image and precision in the soundstage.
    The tweeters are now decoupled from the low frequency circuit via a control unit in order to significantly reduce interference and to further increase the stability of restitution.
    A powerful and massive sound
    Q acoustics Q3020i
    If this model retains the acoustically optimal form fit for Q3 series, the camera body evolves in height and depth to earn almost 25% more space. Increased volume favoring the frequency response of bass and further strengthening the excellent size / power ratio which the series has become renowned. It is not uncommon to be surprised to discover that these speakers produce a considerable innatendu and sound, given their size.
    Strong and high compatibility connectors
    Connectors Q acoustics 3020 i
    The traditional terminal blocks were replaced with low profile brackets.
    This not only increases the strength and durability of connectors. These recessed fasteners also allow deep connections while leaving the possibility to position the speaker close to a wall (including with 4mm banana plugs).
    We can therefore use smooth banana plugs, pins or bare son at his convenience.
    Test des Q Acoustics 3020i par On-Mag
    " The Q Acoustics 3020i sends out big sound. They have a dynamic, cheerful and generous personality. Their stereophonic image has beautiful dimensions and with them, there is no boredom. "
    Type wellReflex 2-way
    low engine125mm
    acute motor22mm
    Frequency Response (+ 3dB, 6dB)64Hz - 30kHz
    nominal impedance6 Ω
    minimum impedance4 Ω
    Sensitivity (2.83 Vrms @ 1m)88 dB
    recommended power25-75W
    Transition Frequency2.4kHz
    Volume6.1 L (372 cu in)
    Dimensions170 x 278 x 282 mm
    Weight (for each speaker)5.5 kg
    ColorWalnut
    Impedance (Ω)6
    Impedance (Ω)4
    Efficiency / Sensitivity (dB)88.0
    Lowest frequency (Hz)64
    Highest frequency (Hz)30000
    Power (W)75.0
    Number of ways2
    Number of loudspeakers2
    Speaker typePassive
    Speaker form factorBookshelf speaker
    The Q 3020I inheritsthe qualities of its predecessors (Q3020, multiple award winner). This new version uses a...
