By buying this product you get 149 loyalty points
The Triangle Borea BR10 floorstanding speakers are the most imposing and powerful model in the BOREA range. They feature 21cm bass drivers to extend frequency response and increase power handling, while maintaining a high level of sound quality.
The BR10 benefits from a 3-way construction. It features a 25mm EFS tweeter, a 16cm midrange driver with a natural cellulose pulp cone, and two 21cm glass-fiber cone drivers with powerful motorization for deep, smooth and perfectly controlled bass.
What's more, this model introduces a completely new architecture. It incorporates a separate filtering system and a double terminal block, allowing bi-wiring or bi-amplification.
With a high sensitivity of 92dB, the Triangle BR10 can easily be combined with the vast majority of amplifiers on the market. Their excellent low-frequency performance and 200W power handling means they are suitable for a 30m² listening room. They can also be used in both HiFi and home-cinema installations.
BR10 loudspeakers benefit from the technological and acoustic innovations of the Esprit Ez series, including cabinetry and driver diaphragms.
EFS Tweeter:
The tweeter used in Borea range loudspeakers benefits from a new-generation system called EFS (Efficient Flow System). This is based on the combination of a 25mm silk dome renowned for its neutrality, and a phasing element specifically developed to homogenize high-frequency diffusion. This system drastically reduces the directivity factor, whatever your listening position in the room. The loudspeaker's membrane is placed inside a horn, limiting edge effects for clear, limpid high-frequency reproduction. The transducer is powered by a neodymium magnet motor, capable of generating high magnetic power in a compact package. It is combined with a heatsink to guarantee better power handling.
Natural cellulose midrange:
The speakers in the Borea range use a midrange driver with a 100% natural cellulose pulp cone, untreated. This avoids any coloration of the midrange frequencies, to reproduce voices realistically, while offering a characteristic grain of the finest effect. The diaphragm profile has been reworked to increase rigidity and improve frequency response.
New generation of woofers:
Unlike all Borea loudspeakers, the BR10 is equipped with 21cm transducers for low-frequency reproduction. These use a fiberglass membrane and a large motorization, perfectly adapted to the load volume. Developed by Triangle, this loudspeaker model is also equipped with a new bowl for optimum ventilation and excellent power handling. A new half-roll suspension is also integrated to perfectly control diaphragm excursion. Low frequencies are reproduced forcefully without drowning out the rest of the spectrum.
Optimized filtering and dual terminals:
Triangle Borea BR10 loudspeakers are the first to feature an architecture with a separate crossover system. This allows bi-wiring or bi-amplification, in conjunction with the on-board dual terminal blocks.
DVAS system:
Following extensive research into ways of reducing internal cabinet vibrations, the Borea range of loudspeakers incorporates perforated internal panels made of MDF and EVA foam, to stiffen the transducer and cabinet assembly. This process reduces structural vibrations, while absorbing those generated by low frequencies.
This proprietary system, developed by Triangle and called DVAS (Driver Vibration Absorption System), uses a high-density EVA foam gasket at the end of each internal bracing, ensuring perfect contact between the driver and the bracing, and greatly attenuating the vibrations generated by the driver, which transfers only a small amount of vibration to the cabinet. When you listen to it, this DVAS system ensures great neutrality and clarity, without sound coloration.
Magnetic cover:
All speakers in the Borea range benefit from a magnetic protective cover, revealing no screws or inserts.
| Specifications | |
| Product type | Floorstanding speakers |
| Number of drivers | 4 |
| Number of ways | 3 |
| Power handling | 200W |
| Sensitivity | 92dB/W/m |
| Frequency response (+/-3dB) | 30Hz-22kHz |
| Treble cut-off frequency | 3900Hz |
| Bass cut-off frequency | 310Hz |
| Nominal impedance (min/max) | 3 / 8Ω |
| Recommended room area | > 30m² |
| General | |
| Dimensions | 265 x 1110 x 380mm |
| Unit weight | 29.5kg |
| Color | Light oak |
| Quantity | Pair |
| Color | Light Oak |
| Color | Wood |
| Impedance (Ω) | 4 |
| Impedance (Ω) | 3 |
| Impedance (Ω) | 8 |
| Loudspeaker diameter (mm) | N/A |
| Efficiency / Sensitivity (dB) | 92.0 |
| Lowest frequency (Hz) | 30 |
| Highest frequency (Hz) | 22000 |
| Power (W) | 200.0 |
| Number of loudspeakers | 4 |
| Speaker type | Passive |
| Speaker form factor | Tower speaker |
