HIFI2000 Perforated Inner Baseplate for Galaxy 245/248/285/288
The HIFI2000 Base Galaxy 245/248/285/288 is a perforated bottom panel designed for Galaxy 245, 248, 285, and 288 enclosures.
Reference : 22223
14,90 €tax incl.
12,42 € tax excl.
HIFI2000 Perforated Bottom Panel for Galaxy 245/248/285/288 (210 x 260mm)
HIFI2000 Fond de Boitier Perforé pour Galaxy
The HIFI2000 Base Galaxy 245/248/285/288 is a perforated bottom panel designed for Galaxy 245, 248, 285, and 288 enclosures. Made from 1.2mm thick pre-galvanized steel, it provides a sturdy internal mounting platform for electronic boards, transformers, and other components. Its perforated grid, featuring regularly spaced 4mm diameter holes, facilitates component installation while promoting efficient airflow inside the enclosure. Measuring 210 × 260mm, it fits perfectly into compatible chassis and installs easily on the dedicated internal guide rails. Weighing 0.6kg, this bottom panel is supplied with its mounting hardware, providing a simple and effective solution for organizing your DIY electronic and audio projects.
Technical Specifications
Product typePerforated Bottom Panel
MaterialGalvanized steel
Thickness1.2mm
Hole spacing4mm
Dimensions210 x 260mm
Weight0.6kg
Package contents1x HIFI2000 Perforated Bottom Panel for Galaxy 245/248/285/288
ColorSilver
MaterialMetal
Internal widthN/A
Internal depthN/A
Internal heightN/A
HIFI2000 Perforated Inner Baseplate for Galaxy 245/248/285/288 (210 x 260mm)
