DD TC35I DAC Adapter Male Lightning to Female Jack 3.5mm 32bit 384kHz
This TC35I adapter consists of a female 3.5mm jack connector and a Lightning male connector. It will allow you to connect a 3.5mm Jack to an Apple device with only a Lightning connector, as it is the case on the latest iPhone. The components are integrated in a compact and robust 316 stainless steel case.
Reference : 14571
36,90 €tax incl.
30,75 € tax excl.
This product has been replaced by the new version, the DD TC35I 2021 DAC Adapter Male Lightning to Female Jack 3.5mm.
TC35I
TC35I Adaptateur DAC Lightning vers Jack 3.5mm Femelle CTIA 32bit 384kHz
This TC35I adapter consists of a female 3.5mm jack connector and a Lightning male connector. It will allow you to connect a 3.5mm Jack to an Apple device with only a Lightning connector, as it is the case on the latest iPhone. The components are integrated in a compact and robust 316 stainless steel case. The TC35I automatically detects and activates when a headset is connected to it. The adapter can also be used with headphones/headsets with built-in controls and microphones.
Product typeJack 3.5mm / Lightning adapter
ConnectorsJack 3.5mm femelle
Lightning
THD+N< -92dB
DNR> 110dB
SNR> 120dB
Output power30mW @ 32Ω
Recommended headphone impedance16-200Ω
Case materialStainless Steel 316
ColorSilver
InputLightning
OutputJack 3.5mm
DAC / ADC ChipNC
Max sampling rate384kHz
ColorSilver
This TC35I adapter consists of a female 3.5mm jack connector and a Lightning male connector. It will allow you to connect a 3.5mm Jack to an Apple...
