This small DD TC35Pro Mountain2 adapter, designed primarily for use with iPhone with Lightning connectivity only, features a male Lightning connector and a female Jack 3.5mm port. It incorporates both a CS41313 DAC capable of decoding PCM streams up to 32bit 384kHz and DSD up to DSD256, as well as an amplification section with independent ES9603Q AOPs. This means you'll be able to enjoy superb listening quality with your smartphone. What's more, its aluminum casing makes it particularly robust, making it ideal for use on the move.
Product type | Male Lightning to female Jack 3.5mm adapter Headphone amplifier DAC |
Connectors | 1* Male Lightning 1* Female Jack 3.5mm |
DAC chip | CS43131 |
OPA | ES9603Q |
Output power | 2x65mW @ 32 Ohm |
SNR | > 122dB (A-wt) |
Dynamic range | > 120dB (A-wt) |
THD | < 0.0004% @ 1kHz |
Frequency response | 20Hz-20kHz |
Supported sampling rates | PCM up to 32bit 384kHz Native DSD up to DSD256 |
LED indicator | Blue: PCM Green: DSD |
Shell material | Aluminum |
Dimensions (without contacts) | 28.5*17*10.4mm |
Weight | 8.5g |
Color | Silver |
Input | Lightning |
Output | Jack 3.5mm |
DAC / ADC Chip | CS43131 |
Max sampling rate | DSD256 |
Max sampling rate | 384kHz |
Color | Silver |
Class | N/A |
Networking | No |
Remote Control | No |
