DD TC44CM2 Portable DAC Headphone Amplifier USB-C to Jack 4.4mm Female
DD Hifi, with its DDTC44CM2, unveils a USB-C to 4.4mm female jack adapter featuring an independent DAC and two ES9603Q headphone amplification chips. Thanks to this, the TC44CM2 supports high-resolution sampling rates up to PCM 32-bit 384kHz while delivering up to 330mW @ 32 ohms to drive headphones or in-ear monitors.
Reference : 20543
52,99 €tax incl.
44,16 € tax excl.
Shipping date: 16-12-2025.
DD TC44CM2 Portable DAC Headphone Amplifier 2x ES9603Q USB-C to 4.4mm female 32bit 384kHz
Photo du DD TC44CM2
DD Hifi, with its DDTC44CM2, unveils a USB-C to 4.4mm female jack DAC adapter featuring an independent DAC and two ES9603Q headphone amplification chips. Thanks to this, the TC44CM2 supports high-resolution sampling rates up to PCM 32-bit 384kHz while delivering up to 330mW under 32 ohms to drive headphones or in-ear monitors. The cable between the two connectors features pure OFC copper conductors and shielding for effective protection against interference.
If noise is audible when using this adapter with a specific phone or application, it means that the "USB only" mode is enabled on your device/application. Simply disable this feature for optimal listening.
Product typeDAC Headphone Amplifier Adapter
Connectors1x USB-C mâle
1x Jack 4.4mm symétrique
Independant DAC chip
Headphone amplifier chips2x ES9603Q
Supported sample ratesPCM 32bit 384kHz
Output power≥ 330mW (32 ohm / THD+N 1%)
SNR≥ 114dB (32 ohm de charge / A-WT)
Dynamic range>120dB
THD< 0.005% (32 ohm load)
Noise floor< 3uV (AWT)
Length9cm (with connectors)
Weight15g
Package1x DD TC44CM2
OutputJack 4.4mm
DAC / ADC ChipNC
Max sampling rate384kHz
ColorSilver
DD TC44CM2 Portable DAC Headphone Amplifier 2x ES9603Q USB-C to Jack 4.4mm Female 32bit 384kHz
DD Hifi, with its DDTC44CM2, unveils a USB-C to 4.4mm female jack adapter featuring an independent DAC and two ES9603Q headphone amplification...
