HIDIZS S3 PRO Adapter Portable DAC ES9281C OFC Copper / Silver MQA 32bit 384kHz DSD128 Black
Hidizs offers with its S3 Pro a powerful portable DAC to accompany you in all your travels. Ideal to work in association with a smartphone without a 3.5mm headphone output, it is equipped with an ESS ES9281C Pro digital/analog conversion chip ensuring an accurate reproduction and supporting high sampling rates as well as MQA files.
Reference : 15616
69,90 €tax incl.
58,25 € tax excl.
Shipping date: 16-05-2025.
Hidizs S3 Pro
Adaptateur DAC Portable ES9281C Cuivre OFC / Argent MQA 32bit 384Hz DSD128
Enjoy your music in high definition!
Although it is compact, the S3 Pro is no less powerful and versatile. Ideal companion for listening on your smartphone, it will allow you to enjoy your music in high quality, supporting PCM streams up to 32bit 38kHz, DSD Native up to DSD128 and even MQA. In addition, its careful design allows it to reveal a rich and musical sound reproduction.
ESS ES9281C Pro DAC
Based on an ESS ES9281C Pro DAC chip, the S3 Pro benefits from low power consumption, extremely low distortion and support for high sample rates and MQA.
MQA 8x Support
MQA (Master Quality Authenticated) technology is supported by the Hidizs S3 Pro, allowing these files to be played back to enjoy sound quality as close as possible to the original recordings.
An audio playback / streaming service supporting MQA must be installed on the source device (HiBy Music, TIDAL) to take advantage of MQA.
3 Filters for 3 Sound Signatures
The S3 Pro offers a choice of 3 predefined equalizers, to suit your listening and your headphones. The first one favors clear highs for a precise and detailed reproduction. The second develops balanced and neutral timbres. Finally, the last one emphasizes deep and powerful bass.
One sample rate, one color
The S3 Pro is equipped with a central LED, illuminating to indicate the sample rate of the file being played:
  • Red : 44.1kHz - 48kHz
  • Blue : 88.2kHz : 384kHz
  • Pink : MQA
An ultra-portable DAC
With its 20mm diameter, the S3 Pro is smaller than a one euro coin. It fits everywhere, in a pocket or in a bag, to accompany you without cluttering you.
Compatible with headphone controls
The Hidizs S3 Pro, designed for mobility, is compatible with the controls and microphones built into the cables of some headphones and earphones. This means that all controls are within easy reach, without having to take your phone out of your pocket.
Copper/Silver cable
No detail is left to chance for this S3 Pro. Thus, the cable making the link between the DAC itself and the USB-C connector benefits from a magnificent design, totally optimized for an optimal signal transmission. This one is composed of 4 braided conductors: two in pure silver and two in OFC copper!
Hidizs S3 Pro review by Audio Science Review (Amir)
The S3 Pro provides good objective performance. Combined with that you get a cute package at average price for premium dongles.  "
Test du Hidizs S3 Pro par Audio Science Review (Amir)
Product typePortable DAC
DAC ChipESS ES9281C Pro
Input1x Male USB-C
Output1x Female Jack 3.5mm
DSD up to DSD128
MQA 8x
THD+N0.0008%
SNR117dB
Channels separation70dB
Frequency response20Hz - 40kHz (±0.1dB)
Output power2x 55mW @ 32Ω
Compatible OSWindows 10, Mac OS, iPad OS, Android, iOS (With Lightning OTG cable, not included)
Dimensions20 x 10 x 90mm
Weight6g
OutputJack 3.5mm
DAC / ADC ChipES9281C Pro
Max sampling rateDSD128
Max sampling rate384kHz
Max sampling rateMQA
Hidizs offers with its S3 Pro a powerful portable DAC to accompany you in all your travels. Ideal to work in association with a smartphone without...
