IBASSO DC07PRO Balanced DAC Headphone Amplifier Silver
The DC07PRO is the new version of iBasso's portable DAC/headphone amplifier. This compact device is equipped with 4 CS43131 chips and a custom-built FPGA, enabling it to read files up to PCM 32bit 768kHz and DSD512. Its low power consumption and high output level of 430mW+430mW at 32Ω make it the perfect travel companion.
Reference : 19620
189,00 €tax incl.
157,50 € tax excl.
Shipping date: 14-05-2026.
iBasso DC07Pro Balanced DAC Headphone Amplifier 4x CS43131 32bit 768kHz DSD512 Silver
IBASSO DC07PRO : Front view
The DC07Pro is the new version of iBasso's portable DAC/headphone amplifier. This compact device is equipped with four CS43131 chips and a custom-built FPGA, enabling it to read files up to PCM 32bit 768kHz and DSD512. Its low power consumption and high output level of 2x430mW at 32Ω make it the perfect travel companion.
iBasso DC07PRO: Custom FPGA
The DC07Pro uses FPGA technology developed in-house by iBasso, integrating audio algorithms and controlling the DAC/preamplifier system. As the heart of the DC07Pro, the FPGA system plays an essential role in regenerating the signal and synchronising it to the internal clock. It should also be noted that the FPGA system also generates a low-jitter clock signal for the DAC and USB signal processing, effectively reducing the jitter caused by the USB port.
IBASSO DC07PRO : FPGA
IBASSO DC07PRO : CS43131 DAC Chips
iBasso DC07PRO: 4 DAC chips
To effectively complement iBasso's FPGA system, the DC07Pro is equipped with four Cirrus Logic CS43131 DAC chips, delivering truly impressive measurement performance. Indeed, the DC07Pro's harmonic distortion more noise figure is just 0.000098% for an output level of 2x430mW at 32Ω. Furthermore, thanks in part to the FPGA used, the DC07Pro supports DSD512 and 32bit 768kHz PCM.
iBasso DC07PRO: Quality power supply
The DC07Pro uses a synchronous DC/DC converter with an efficiency rate of 94%, ensuring minimal heat generation. Furthermore, the DC07Pro consumes just 80mA of power - 40% less than the DC04PRO - and delivers 82% more output. The DAC's power supply stage adopts a very low-noise voltage regulator dedicated to the analogue circuit with a PSRR (Power Supply Rejection Ratio) of up to 100dB, guaranteeing a perfectly clean power supply. Finally, it's also worth noting that the DC07Pro's low power consumption makes it de facto compatible with IPhones, as it does not trigger the latter's power consumption safety device.
IBASSO DC07PRO : Representation of the 94% efficiency rate
IBASSO DC07PRO : Macro view of the multifunction knob
iBasso DC07PRO: Intuitive navigation
The DC07PRO has a 0.96-inch OLED screen and is equipped with an ALPS encoder. The multifunction knob allows you to scroll through and make all the settings. Simply turn and press the multifunction knob to adjust volume, digital crossover and more. Furthermore, the DC07PRO also supports the iBasso UAC Android application, which allows you to control all settings using your Android device.
Product typeDAC and portable headphone amplifier
InputUSB-C
Outputs1x Single-ended 3.5 mm jack
1x Balanced 4.4mm jack
DAC chips4x CS43131
Supported sampling ratesPCM 32bit up to 768kHz
DSD up to DSD512
4.4MM BALANCED OUTPUT
Total harmonic distortion more noise (THD+N)-120.2dB (0.000098%) @ 1kHz 300Ω
Output voltageLow gain: 2.8Vrms
Medium gain: 3.5Vrms
High gain: 4Vrms
Output power510mW + 510mW @ 16Ω THD+N<0.1%
430mW + 430mW @ 32Ω THD+N<0.1%
Signal-to-noise ratio134dB
Dynamic range134dB
Crosstalk142dB
Frequency response10Hz - 80kHz (-0.5dB)
Noise floor0.85µV
3.5MM SINGLE-ENDED OUTPUT
Total harmonic distortion more noise (THD+N)-116dB (0.00017%) @ 1kHz 300Ω
Output voltageLow gain: 1.4Vrms
Medium gain: 1.73Vrms
High gain: 2Vrms
Output power210mW + 210mW @ 16Ω THD+N<0.1%
118mW + 118mW @ 32Ω THD+N<0.1%
Signal-to-noise ratio129dB
Dynamic range129dB
Crosstalk136dB
Frequency response10Hz - 75kHz (-0.5dB)
Noise floor0.76µV
Dimensions59 x 23.5 x 12.5mm
Weight23g
ColorSilver
Package1x iBasso DC07PRO
1x USB-C to USB-C cable
1x USB-C to Lightning cable
1x USB-C to USB-A adapter
OutputJack 4.4mm
OutputJack 3.5mm
DAC / ADC ChipCS43131
Max sampling rate768kHz
Max sampling rateDSD512
ColorSilver
le parfait voyageur
Bonjour
Déjà le contexte : casque focal Clear Mg sur Pixel 10 / usage avec Cobuz
Je suis passé d'un téléphone possédant une sortie caque filaire , disparue sur le Pixel 10 , je cherchais donc un dispositif complémentaire mais léger et sans contraintes en utilisant les ressources du téléphone , le tout , si possible avec une bonne qualité
déjà l'autonomie est très bonne , la faible conso n'entame pas la batterie de la source ( 5% par heure , pas plus ) c'est une très bonne chose , et cela à été un critère de choix
Coté pratique c'est pas mal , bien que j'aurais aimé avec une vraie notice en français ( on est en France tout de même ) afin d'exploiter correctement les réglages disponibles , et c'est franchement pénible cette mode du " démerde toi " que l'on retrouve de plus en plus sur tous les produits
Très compact et léger , parfait en voyage pour glisser le tout avec le casque
Coté musical , c'est vraiment bon , gros bon en avant par rapport à ma lecture directe via smartphone , rien a voir
Un grave beaucoup plus présent , une scène sonore qui s'ouvre un peu plus et surtout se place plus en avant , moins fixée sur chaque oreille , cela rend l'écoute au casque plus aérée , plus agréable
Les détails sont parfaits , le revers c'est que l'on distingue les défaut de l'enregistrement, mais c'est très bon
Je me suis amusé à comparer avec une sortie casque de mon ampli Technics sug 700 , et c'est identique
c'est un très bon choix , pour la qualité sonore , pour l'autonomie , et pour un prix encore contenu malgré tout
This review has been posted for IBASSO DC07PRO Balanced DAC Headphone Amplifier 4x CS43131 32bit 768kHz DSD512 Silver
The DC07PRO is the new version of iBasso's portable DAC/headphone amplifier. This compact device is equipped with 4 CS43131 chips and a...
