IBASSO MACARON DAC Portable
New
The iBasso Macaron is a portable DAC designed to provide direct digital-to-analogue conversion between a mobile source and headphones. It features a dual CS43131 DAC architecture, capable of decoding up to 384 kHz PCM and DSD256, combined with a KDS femtosecond oscillator to stabilise the digital signal and improve its temporal accuracy.
Reference : 21827
54,90 €tax incl.
45,75 € tax excl.
iBasso Macaron Portable DAC 2x CS43131 32bit 384kHz DSD256 Black
iBasso Macaron : Front view
The iBasso Macaron is a portable DAC designed to provide direct digital-to-analogue conversion between a mobile source and headphones. It features a dual CS43131 DAC architecture, capable of decoding up to 32bit 384kHz PCM and DSD256, combined with a KDS femtosecond oscillator to stabilise the digital signal and improve its temporal accuracy.
iBasso Macaron: Dual CS43131 DAC
The iBasso Macaron utilises a dual CS43131 DAC architecture, enabling decoding up to 32bit 384kHz PCM and DSD256 to preserve the integrity of high-resolution audio streams whilst ensuring stable conversion across the entire audible spectrum. This foundation is further enhanced by the integration of a KDS femtosecond crystal oscillator, which reduces jitter and timing errors in the digital signal, resulting in a more coherent reproduction and improved clarity of subtle details.
iBasso Macaron : CS43131 DAC chips
iBasso Macaron : 80mA
iBasso Macaron: Limited consumption
In addition to its conversion performance, the device features efficient power management with power consumption limited to 80mA, thereby minimising the impact on the smartphone’s battery life whilst preventing power protection mechanisms from being triggered on certain devices, particularly within the Apple ecosystem.
iBasso Macaron: Ease of use
This focus on functional simplicity is complemented by dual headphone outputs – 3.5mm and 4.4mm jacks – allowing the Macaron to be used with both balanced and single-ended configurations. The operating status is indicated by a coloured LED: red when on standby, blue for DSD, and green for PCM, allowing immediate identification of the current audio stream, whilst the iBasso UAC app on Android enables adjustment of gain, digital filters and stereo balance, thus allowing the sound reproduction to be adapted to listening conditions.
iBasso Macaron : 3.5mm and 4.4mm jack outputs
iBasso Macaron : view of each colour
iBasso Macaron: Aluminium housing and tempered glass
The unit is housed in a CNC-machined aluminium frame, which ensures efficient heat dissipation. This design is further enhanced by the incorporation of tempered glass panels on each side, creating a contrast in textures between the metallic surfaces and the smooth finishes.
Product typePortable DAC
InputUSB-C
Outputs1x Single-ended Jack 3.5mm
1x Balanced Jack 4.4mm
DAC2x CS43131
Supported sampling ratePCM up to 32bit 384kHz
DSD up to DSD256
Total harmonic distortion more noise (THD+N)Jack 4.4mm : 0.00013% @300Ω
Jack 3.5mm : 0.00016% @300Ω
Signal-to-noise ratio (SNR)Jack 4.4mm : -132dB
Jack 3.5mm : -128dB
Output voltageJack 4.4mm : 2.6Vrms
Jack 3.5mm : 1.65Vrms
Frequency response20Hz-40kHz
Output impedanceJack 4.4mm : 0.2Ω
Jack 3.5mm : 0.1Ω
Weight16g
Dimensions41.7 x 24 x 12.3mm
Package1x iBasso Macaron
1x USB-C to USB-C cable
OutputJack 4.4mm
OutputJack 3.5mm
DAC / ADC ChipCS43131
Max sampling rateDSD256
Max sampling rate384kHz
IBASSO MACARON Portable DAC 2x CS43131 32bit 384kHz DSD256 Black
The iBasso Macaron is a portable DAC designed to provide direct digital-to-analogue conversion between a mobile source and headphones. It features...
