IBASSO MACCHIATO DAC Portable DAC Headphone Amplifier
The iBasso Macchiato is a portable DAC with a built-in headphone amplifier, designed to convert and amplify digital sources in a mobile setting. It features a dual CS43131 DAC architecture capable of decoding up to 32bit 384kHz PCM and DSD256, whilst delivering 2x 580mW of power into a 32Ω load.
Reference : 21811
74,91 €tax incl.
62,42 € tax excl.
iBasso Macchiato Portable DAC Headphone Amplifier 2x CS43131 32bit 384kHz DSD256 Black
iBasso Macchiato : Front view
iBasso Macchiato: Dual CS43131 DAC
The iBasso Macchiato utilises a dual CS43131 DAC architecture, enabling decoding up to 32bit 384kHz PCM and DSD256 to preserve the integrity of high-resolution audio streams whilst ensuring stable conversion across the entire audible spectrum. This conversion stage is complemented by an amplifier stage delivering 580mW + 580mW into 32Ω, enabling it to efficiently drive low and medium impedance headphones.
iBasso Macchiato : CS43131 chips
iBasso Macchiato on a keyboard
iBasso Macchiato: Maximum compatibility
In addition to conversion, the device includes compatibility features, with microphone support via the 3.5 mm jack output, allowing the use of headphones with a built-in microphone. This is complemented by a UAC 1.0 mode, ensuring compatibility with older systems, whilst the SPDIF mode allows the Macchiato to be used as a digital transport, enabling the signal to be routed to an external DAC.
iBasso Macchiato : Customize your listening experience
This versatility is complemented by direct control via physical buttons and a 0.96-inch OLED screen, providing clear feedback on key settings whilst reducing reliance on the source device. For finer tuning, the iBasso UAC app for Android allows you to adjust an 8-band equaliser, select digital filters and adjust the stereo balance, enabling you to tailor the sound to the headphones’ characteristics and your listening preferences.
iBasso Macchiato : iBasso UAC app
Product typePortable DAC
Portable headphone amplifier
InputUSB-C
Outputs1x Single-ended Jack 3.5mm
1x Balanced Jack 4.4mm
DAC2x CS43131
Supported sampling ratePCM up to 32bit 384kHz
DSD up to DSD256
Frequency response5Hz-80kHz
Total harmonic distortion more noise (THD+N)Jack 4.4mm : -118dB
Jack 3.5mm : -115dB
Signal-to-noise ratio (SNR)Jack 4.4mm : 131dB
Jack 3.5mm : 127dB
Dynamic rangeJack 4.4mm : 132dB
Jack 3.5mm : 128dB
Output voltageJack 4.4mm : 5Vrms
Jack 3.5mm : 2.5Vrms
Output powerJack 4.4mm : 580mW+580mW @32Ω
Jack 3.5mm : 195mW+195mW @32Ω
Output impedance≤0.05Ω
CrosstalkJack 4.4mm : 145dB
Jack 3.5mm : 136dB
Weight21g
Dimensions49.6 x 27.6 x 12.9mm
Package1x iBasso Macchiato
1x USB-C to USB-C cable
OutputJack 4.4mm
OutputJack 3.5mm
DAC / ADC ChipCS43131
Max sampling rate384kHz
Max sampling rateDSD256
IBASSO MACCHIATO Portable DAC Headphone Amplifier 2x CS43131 32bit 384kHz DSD256 Black
The iBasso Macchiato is a portable DAC with a built-in headphone amplifier, designed to convert and amplify digital sources in a mobile setting. It...
