IBASSO DC04U Ultra Portable USB DAC Headphone Amplifier
The iBasso DC04U Ultra is a portable USB DAC with integrated headphone amplifier in a dongle format, designed to deliver audiophile-grade performance on smartphones, tablets, or computers. It is based on a dual Cirrus Logic CS43198 DAC architecture operating in a true 4-channel balanced configuration, combined with advanced digital processing via a proprietary FPGA and femtosecond oscillators for optimal timing accuracy. Hi-Res Audio compatible, it supports streams up to PCM 32bit 768kHz and native DSD512, ensuring extremely detailed sound reproduction.
Reference : 21828
119,00 €tax incl.
99,17 € tax excl.
iBasso DC04U Ultra Portable USB DAC Headphone Amplifier 2xCS43198 32bit 768kHz DSD512
Photo of the IBASSO DC04U Ultra
On the amplification side, it delivers a maximum power output of up to 980mW per channel at 32Ω via the 4.4mm balanced output, and 280mW per channel via the 3.5mm single-ended output, allowing it to drive both sensitive IEMs and more demanding headphones. Connectivity includes a USB-C input, a 4.4mm balanced headphone output, a 3.5mm jack output (headphone + CTIA microphone), as well as a coaxial S/PDIF output via the 3.5mm jack.
The DC04U Ultra features a 0.96" color display showing real-time information (volume, gain, sampling rate), along with three physical buttons for direct control of volume, gain, digital filters, and balance without relying on an app. It is also compatible with a dedicated Android app (UAC), providing access to advanced DSP including a 10-band parametric equalizer (PEQ), multiple presets, and fine-tuning options. The whole unit is housed in a CNC-machined stainless steel chassis with tempered glass, offering a robust and premium build, and is compatible with many systems (Android, iOS, Windows, macOS, Linux, consoles) via USB Audio.
iBasso DC04U Ultra: Dual CS43198 DAC for high-end conversion
The DC04U Ultra relies on two Cirrus Logic CS43198 chips, renowned for their excellent signal-to-noise ratio and musicality. This configuration enables a fully balanced architecture, improving channel separation, reducing distortion, and delivering a wider and more precise soundstage.
Combined with FPGA-based digital processing and femtosecond oscillators, the signal benefits from an انتہائی stable clock, minimizing jitter and ensuring accurate reproduction, even with high-resolution files up to PCM 32bit 768kHz and DSD512.
IBASSO DC04U Ultra: Dual CS43198 DAC for high-end conversion
IBASSO DC04U Ultra: high power up to 980mW in balanced mode
iBasso DC04U Ultra: High power up to 980mW in balanced mode
One of the key strengths of the DC04U Ultra is its amplification capability. It delivers up to 980mW per channel at 32 ohms via the 4.4mm output, which is particularly high for a portable dongle DAC.
In 3.5mm single-ended output, power reaches 280mW per channel, ensuring excellent compatibility with both in-ear monitors and portable headphones.
This power reserve allows for dynamic playback, with better driver control and greater headroom during complex passages.
iBasso DC04U Ultra: Built-in display and direct control without app
Unlike many portable DACs, the DC04U Ultra features a 0.96-inch color display showing essential information: volume, gain, audio format, and sampling rate.
The three physical buttons provide direct access to main settings: volume, gain selection, digital filters, and channel balance. This approach allows fully standalone use without systematically requiring a mobile app.
IBASSO DC04U Ultra: built-in display and direct control without app
IBASSO DC04U Ultra: advanced DSP and 10-band parametric equalizer
iBasso DC04U Ultra: Advanced DSP and 10-band parametric equalizer
For users looking to go further in sound customization, a dedicated Android app provides access to a full DSP. It includes a 10-band parametric equalizer (PEQ), multiple presets, as well as fine adjustment of digital filters.
This flexibility allows precise tuning of the sound signature depending on the headphones used or listening preferences, turning the DC04U Ultra into a true portable audio optimization tool.
iBasso DC04U Ultra: Complete connectivity and wide compatibility
The DC04U Ultra offers highly versatile connectivity with a USB-C input compatible with smartphones, tablets, and computers. It features two headphone outputs: a 4.4mm balanced output for maximum performance and a 3.5mm output compatible with headsets including microphone (CTIA standard).
The presence of a coaxial S/PDIF output via the 3.5mm jack also allows use as a digital transport to an external DAC. Compatible with many systems (Android, iOS, Windows, macOS, Linux, or consoles), it easily adapts to all use cases.
IBASSO DC04U Ultra: complete connectivity and wide compatibility
Technical specifications
Product typePortable DAC / Headphone amplifier
DAC chip2x CS43198
Input1x USB-C
Output1x 3.5mm single-ended jack
1x 4.4mm balanced jack
Supported sampling ratesPCM up to 32bit 768kHz
DSD up to DSD512
Display0.96 inch
3.5mm jack output specifications
THD+N-113dB (0.00022%) @1kHz, 300Ω
Output voltageLow gain : 0.76Vrms
Mid gain : 2.1Vrms
High gain : 3.0Vrms
Output power280+280Vrms @ 32Ω
Frequency response5Hz-75kHz -0.5dB
SNR129dB
Dynamic range129dB
Output impedance<0.1Ω
Crosstalk136dB
CTIA mic compatibility
Coaxial SPDIF compatibility
4.4mm jack output specifications
THD+N-119dB (0.00011%) @1kHz, 300Ω
Output voltageLow gain : 1.5Vrms
Mid gain : 4.2Vrms
High gain : 6.1Vrms
Output power980+980Vrms @ 32Ω
Frequency response10Hz-80kHz -0.5dB
SNR132dB
Dynamic range132dB
Crosstalk148dB
Dimensions58 x 23.5 x 13.1mm
Weight37.2g
ColorSilver
Package1x iBasso DC04U Ultra
1x USB-C cable
1x USB-C to USB-A adapter
OutputJack 4.4mm
OutputJack 3.5mm
DAC / ADC ChipCS43198
Max sampling rate768kHz
Max sampling rateDSD512
ColorSilver
IBASSO DC04U ULTRA Portable USB DAC Headphone Amplifier 2xCS43198 32bit 768kHz DSD512
The iBasso DC04U Ultra is a portable USB DAC with integrated headphone amplifier in a dongle format, designed to deliver audiophile-grade...
