IFI AUDIO GO LINK MAX Portable USB DAC
iFi Audio's Go Link Max is the ideal accessory for connecting headphones or earphones to a device with no headphone jack output, such as a recent smartphone. The Max version is an evolution of the Go Link, with a symmetrical structure that enables it to offer a 4.4mm jack output in addition to the classic 3.5mm jack output. This portable DAC is based on two ESS ES9219 Sabre chips, supporting signals up to PCM 32bit 384kHz and DSD256.
Reference : 20424
89,00 €tax incl.
74,17 € tax excl.
iFi Audio Go Link Max Portable USB DAC 2xES9219 32bit 384kHz DSD256
Go Link Max : Front view
iFi Audio's Go Link Max portable DAC is the ideal accessory for connecting headphones or earphones to a device with no headphone jack output, such as a recent smartphone. The Max version is an evolution of the Go Link, with a symmetrical structure that enables it to offer a 4.4mm jack output in addition to the classic 3.5mm jack output. This portable DAC is based on two ESS ES9219 Sabre chips, supporting signals up to PCM 32bit 384kHz and DSD256.
Ifi Audio Go Link Max: Balanced DAC
The iFi Audio Go Link Max features a USB-C male input and two headphone outputs: a balanced 4.4mm jack and an S-Balanced 3.5mm jack. Each part is clad in a sturdy, lightweight magnesium alloy body. Between the two, a 6cm flexible cable allows convenient use while reducing the mechanical stress applied to connectors and connected peripherals. Moreover, it incorporates individually insulated, silver-plated copper conductors, ensuring excellent conductivity for perfect signal transmission.
Go Link Max: earphone connected to 4.4mm jack output
Go Link Max: connected to a telephone
Ifi Audio Go Link Max: Dual-chip DAC ESS ES9219 Sabre
The heart of Go Link Max is a pair of ESS ES9219 Sabre DAC chips. Moreover, this DAC offers signal conversion up to PCM 32bit 384kHz and DSD256, and makes use of Sabre DRE (Dynamic Range Enhancement) technology, providing a +6dB improvement in dynamic range for a total of 130dB.
Ifi Audio Go Link Max: 241mW output power
Computers and phones can sometimes be a little light on output power for effectively driving audiophile earphones or headphones. For example, the Go Link Max offers an output power of 241mW at 32Ω, which is 5 times greater than the audio output of a MacBook Pro, for example.
Go Link Max: connected to a phone and earphones
Go Link Max: Close-up of USB-C socket
Ifi Audio Go Link Max: iFi Audio technologies
This DAC is enhanced by Quad DAC+, Time Domain Jitter Eliminator and a dedicated clock circuit to achieve very low levels of distortion for clear, dynamic sound.
Product typePortable DAC
Input1x USB-C
Output1x Single-ended Jack 3.5mm headphone output
1x Balanced Jack 4.4mm headphone output
Native DSD up to DSD256
Output powerJack 3.5mm: ≥100mW @ 32Ω; ≥2V @ 300Ω
Jack 4.4mm: ≥241mW @ 32Ω; ≥4V @ 300Ω
Output impedanceJack 3.5mm: <0.35Ω
Jack 4.4mm: <0.7Ω
Signal-to-noise ratio (SNR)Jack 3.5mm: 125dB(A) (600Ω @ 20-20KHz)
Jack 4.4mm: 130dB(A) (600Ω @ 20-20KHz)
Dynamic rangeJack 3.5mm: 125dB(A) (600Ω @ 20-20KHz)
Total harmonic distortion more noise (THD+N)Jack 3.5mm: ≤0.0015% (1.27V @ 32Ω) @ (20-20KHz)
Jack 4.4mm: ≤0.0016% (2.4V @ 32Ω) @ (20-20KHz)
Frequency response10-80kHz(-3dB)
ConsumptionNo signal : ~0.6W
Max. signal : ~3.2W
Dimensions150 x 15 x 10mm
Weight14.5 g
Package1x iFi Audio
1x Adaptateur USB-A to USB-C
OutputJack 4.4mm
OutputJack 3.5mm
DAC / ADC ChipES9219MQ/Q
Max sampling rate384kHz
Max sampling rateDSD256
ColorGreen
IFI AUDIO GO LINK MAX Portable USB DAC 2xES9219 32bit 384kHz DSD256
iFi Audio's Go Link Max is the ideal accessory for connecting headphones or earphones to a device with no headphone jack output, such as a...
