KIWI EARS ALLEGRO MINI Portable DAC Headphone Amplifier
New
The Kiwi Ears Allegro Mini portable DAC / headphone amplifier is a small device that can support high-resolution streams up to PCM 32bit 384kHz and DSD128, and is capable of delivering up to 30mW under 32Ω. This means you can enjoy high-resolution files and drive a wide range of headphones and earphones available on the market.
Reference : 20677
24,90 €tax incl.
20,75 € tax excl.
Kiwi Ears Allegro MiniPortable DAC Headphone Amplifier 32bit 384kHz DSD128
KIWI EARS ALLEGRO picture
The Kiwi Ears Allegro Mini portable DAC / headphone amplifier is a small device that can support high-resolution streams up to PCM 32bit 384kHz and DSD128, and is capable of delivering up to 30mW under 32Ω. This means you can enjoy high-resolution files and drive a wide range of headphones and earphones available on the market. The sound reproduction offered by the Allegro Mini is clear and precise in the treble, with deep, immersive bass for a rich, pleasant listening experience. Source connection is via USB-C port and output via single-ended 3.5mm jack or balanced 4.4mm jack.
KIWI EARS ALLEGRO in action
Product typePortable DAC / Headphone Amplifier
Input1x USB-C
Outputs1x Jack 3.5mm
1x Balanced Jack 4.4mm
Supported sample ratesPCM 32bit 384kHz, DSD128
THD+N< 0.004% (@32 Ohms)
Output power2x30mW (32Ω, THD+N < 1%)
SNR≥ 114dB (@32 Ohms, A-Weighted)
Frequency response20Hz–20kHz (±0.2dB)
Background noise< 3μV (A-weighted)
ColorSilver
Package1x Kiwi Ears Allegro Mini
OutputJack 4.4mm
OutputJack 3.5mm
DAC / ADC ChipNC
Max sampling rateDSD128
Max sampling rate384kHz
ColorSilver
ClassN/A
KIWI EARS ALLEGRO MINI Portable DAC Headphone Amplifier 32bit 384kHz DSD128
The Kiwi Ears Allegro Mini portable DAC / headphone amplifier is a small device that can support high-resolution streams up to PCM 32bit 384kHz and...
