Portable Balanced DAC USB-C ES9038Q2M 32bit 768kHz DSD512 Silver
Whether you're using a next-generation smartphone with no analog audio output (compatible directly with your headphones) or simply want to upgrade the audio output of a consumer phone, the Shanling UA2 Plus is a portable and affordable solution for playing your high-resolution audio files anywhere without taking up more space than necessary.
This new version of the UA series is equipped with increased decoding capabilities with an independent amplifier stage also offering a balanced output now in 4.4mm jack format.
Although very compact, the Shanling UA2 Plus features a supercharged circuit built around an ESS ES9038Q2M chip, a reference component for high fidelity applications integrating both digital to analog conversion capabilities.
On the DAC side, the UA2 Plus is capable of playing high resolution audio files up to 32bit 768kHz and even DSD files up to DSD512 with native support.
The output stage is articulated around an RT6838 chip capable of developing a power up to 125mW under 32 Ohm with a minimal noise level, which represents an incomparable gain in comparison with the traditional audio outputs of mobile & consumer multimedia devices.
The integrated cable has high purity copper conductors & high section ensuring excellent conductivity for your audio streams. It is solidly protected by a robust sheath and has a cotton/silver insulation specially designed to limit the capture of high frequency waves, such as those specifically present near a smartphone.
| Specifications | |||
| Product type | Portable DAC | ||
| Inputs | 1x USB-C | ||
| Outputs | 1x Single-ended stereo Jack 3.5mm 1x Balanced stereo Jack 4.4mm | ||
| Output power | Balanced : 195mW @ 32Ω Single-ended : 125mW @ 32Ω | ||
| Frequency response | 20Hz - 50kHz (-0.5dB) | ||
| THD+N | 0.0008% @32Ω (A) | ||
| Dynamic range | Balanced : 120 dB @32Ω (A) Single-ended : 122 dB @32Ω (A) | ||
| SNR | Balanced : 116dB @32Ω (A) | ||
| Crosstalk | Balanced : 109dB @32Ω | ||
| Output impedance | Balanced : 1.6 Ohm Single-ended : 0.8 Ohm | ||
| Color | Silver | ||
| Input | USB |
| Output | Jack 4.4mm |
| Output | Jack 3.5mm |
| DAC / ADC Chip | ES9038Q2M |
| Color | Silver |
| Networking | No |
| Remote Control | No |
