TANCHJIM SPACE PRO Portable DAC Headphone Amplifier
The Tanchjim Space Pro is a DAC with a built-in headphone amplifier based on a dual Cirrus Logic CS43198 DAC architecture, designed to handle the conversion and playback of high-resolution audio streams. It supports PCM signals up to 32bit 768kHz as well as DSD256, whilst utilising a dual-mono topology that isolates the channels to improve separation and stabilise reproduction across the entire spectrum.
Reference : 21768
99,00 €tax incl.
82,50 € tax excl.
Shipping date: 01-12-2026.
Tanchjim Space Pro Portable DAC Headphone Amplifier CS43198 32bit 768kHz DSD256
Tanchjim Space Pro : Front view
It combines amplification delivering up to 618mW into a 26Ω load with software-controlled operating modes and signal processing, allowing the behaviour of the conversion/amplification system to be adapted to suit the listening conditions.
Tanchjim Space Pro: Cirrus Logic DAC
The Tanchjim Space Pro utilises a dual Cirrus Logic CS43198 DAC architecture, handling PCM streams up to 32bit 768kHz and DSD256, whilst employing a dual-mono topology that isolates the left and right channels. This structural separation limits crosstalk, thereby preserving the precision of the soundstage and the clarity of micro-details.
Tanchjim Space Pro : CS43198
Tanchjim Space Pro: Double OPA SGM8262
This conversion stage is followed by an amplification stage based on two SGM8262 operational amplifiers, delivering up to 618mW into 26Ω and 505mW into 32Ω, which provides a power supply capable of driving headphones with varying impedances whilst maintaining stable signal control.
Tanchjim Space Pro : Power measurement
Tanchjim Space Pro: Tanchjim app
Beyond sheer power, the amplifier’s performance can be customised via the Tanchjim app, which allows you to switch between Class AB and Class H modes to adapt the circuit’s response to the listening environment. This approach is extended by the inclusion of 5.1/7.1 surround sound simulation, broadening the spatialisation for multimedia use, whilst the 10-band equaliser, combined with the ability to import and export presets, allows for adjustment of the sound signature.
Tanchjim Space Pro : 3.5mm and 4.4mm jack outputs
Tanchjim Space Pro: Dual jack output
In line with this, the Space Pro features both a 3.5mm jack single-ended output and a 4.4mm jack balanced output; the latter utilises differential transmission, which improves channel separation and signal stability on compatible headphones. The inclusion of the CTIA microphone standard allows for the use of headphones with a microphone.
Tanchjim Space Pro: Silver-plated copper cable
The audio connection uses a supplied silver-plated copper cable, whose optimised conductivity minimises signal loss and distortion during transmission. This design ensures that the integrity of the audio data is maintained between the source and the DAC, resulting in a more stable playback experience when used on the move.
Tanchjim Space Pro : Silver-plated copper cable
Product typePortable DAC
Portable headphone amplifier
InputUSB-C
Outputs1x Single-ended Jack 3.5mm
1x Balanced Jack 4.4mm
DAC chips2x CS43198
Power567mW @ 16Ω
618mW @ 26Ω
505mW @ 32Ω
Frequency response8Hz-80kHz
Total harmonic distortion more noise (THD+N)0.000206%
Background noise≤ 1.14μVrms
Dynamic range131dB
Signal-to-noise ratio (SNR)≥ 131dB
SINAD113.7dB
Output levelSingle-ended : 2Vrms
Balanced : 4Vrms
ColorSilver
Package1x Tanchjim Space Pro
1x USB-C to USB-C cable
1x USB-A to USB-C adapter
OutputJack 3.5mm
OutputJack 4.4mm
DAC / ADC ChipCS43198
Max sampling rate768kHz
Max sampling rateDSD256
ColorSilver
ClassClass A / AB
ClassClass H
TANCHJIM SPACE PRO Portable DAC Headphone Amplifier CS43198 32bit 768kHz DSD256
The Tanchjim Space Pro is a DAC with a built-in headphone amplifier based on a dual Cirrus Logic CS43198 DAC architecture, designed to handle the...
