TANCHJIM STARGATE II Portable DAC / Headphone Amplifier
The Tanchjim Stargate 2 is a portable DAC and headphone amplifier with USB-C male and Jack 3.5mm female connectors. It's ideal for enjoying high-quality listening on a smartphone without a 3.5mm headphone output.
Reference : 20655
39,00 €tax incl.
32,50 € tax excl.
Shipping date: 10-06-2025.
Tanchjim Stargate II Portable DAC / Headphone Amplifier CS43131 USB-C Jack 3.5mm 32bit 384kHz DSD256
Photo of Tanchjim Stargate II
What's more, it integrates seamlessly with the Tanchjim mobile application. It provides access to a DSP with eight-band parametric equalizer for easy adaptation of sound reproduction.
Thanks to its integrated DAC chip, it supports high-resolution audio streams up to PCM 32bit 384kHz and DSD256. It offers excellent sonic performance with high SNR and DNR, as well as very low distortion, for clear, precise sound.
Key features of the Tanchjim Stargate II
Tanchjim Stargate II CS43131 control chip
Tanchjim Stargate II: CS43131 control chip
The Tanchjim Stargate II features a high-performance Cirrus Logic CS43131 DAC and headphone amplifier chip. It supports high-resolution audio streams up to PCM 32bit 384kHz and DSD256, while ensuring high SNR and DNR and very low distortion for rich, clear and precise sound reproduction.
Tanchjim Stargate II: Crystal-clear voice calls
The Tanchjim Stargate II makes it easy to take calls with your headphones or earphones. It features a high-resolution 24bit 48kHz ADC chip, with a signal-to-noise ratio of 84dB, for crystal-clear calls.
Photo of Tanchjim Stargate II and SNR ADC
Tanchjim Stargate II: Compact and ultra-lightweight
Using metal-bodied connectors and a braided sheath, the Tanchjim Stargate II is tough but extremely lightweight, weighing just 4.3g.
Tanchjim Stargate II: Integration with Tanchjim mobile application
The Tanchjim Stargate II integrates with the Tanchjim mobile app (Android and iOS). It provides access to the DSP with an eight-band parametric equalizer for fine-tuning sound reproduction.
Download Tanchjim Mobile App
Tanchjim Stargate II: High dynamic range and SNR
Thanks to high-quality design and components, the Stargate II offers a dynamic range (DNR) of 127.5dB and a signal-to-noise ratio (SNR) of 127.4dB.
DNR and SNR measurements on the Tanchjim Stargate II
Tanchjim Stargate II: Very low distortion
The Tanchjim Stargate II ensures very low harmonic distortion of 0.0002%, and its SINAD reaches an impressive 113dB.
Tanchjim Stargate II distortion measurements
Product typePortable DAC and headphone amplifier
USB-C to Jack 3.5mm adapter
Connectors1x Male USB-C
1x female Jack 3.5mm
Native DSD up to DSD256
THD0.00023%
Dynamic range127.4dB
SNR127.4dB
SINAD113dB
Output level2Vrms
Crosstalk-75dB
Output power82mW @ 16Ω, THD+N <1%
75mW @ 32Ω, THD+N <1%
ColorSilver
Package1x Tanchjim Stargate II
OutputJack 3.5mm
DAC / ADC ChipCS43131
Max sampling rateDSD256
Max sampling rate384kHz
ColorSilver
ConnecticMale & Female
ConnectorUSB-C
ConnectorJack 3.5mm
TANCHJIM STARGATE II Portable DAC / Headphone Amplifier CS43131 USB-C Jack 3.5mm 32bit 384kHz DSD256
The Tanchjim Stargate 2 is a portable DAC and headphone amplifier with USB-C male and Jack 3.5mm female connectors. It's ideal for enjoying...
