AUDIOPHONICS MPA-S250NC XLR Power Amplifier Class D Stereo Ncore NC252MP 2x250W 4 Ohm
The Audiophonics MPA-S250NC XLR is a stereo amplifier based on an amplification module Hypex Ncore NC252MP. This solution is ideal for anyone who wants to have a large power reserve (2x250W) without sacrificing sound reproduction quality.
By buying this product you get 47 loyalty points
Reference : 14185
479,00 €tax incl.
399,17 € tax excl.
Shipping date: 09-07-2025.
Audiophonics Workshop amplifiers range
Class D Stereo Amplifier Ncore NC252MP 2x250W 4 Ohm
Audiophonics MPA-S252NC XLR Amplificateur Stéréo Class D Ncore 2x150W 8 Ohm
The Audiophonics MPA-S250NC XLR is a stereo amplifier based on an amplification module Hypex Ncore NC252MP. This solution is ideal for anyone who wants to have a large power reserve (2x150W) without sacrificing sound reproduction quality. This amplifier block will be suitable for example to accompany demanding speakers, to sound large listening rooms or for studio applications requiring a large headroom without compromising the accuracy and richness of the audio message.
All components are integrated in a simple and robust 100% Aluminium housing with openings to facilitate heat dissipation. Its design also allows it to limit the impact of interference on the signal.
Hypex Ncore NC252MP Amplification Board
The amplification circuit uses a module Hypex Ncore NC252MP. It is a versatile, high-performance Class D amplifier. It offers a very comfortable power of 2x150W at 8Ω while taking advantage of the high efficiency of Class D amplifiers.
Its main characteristics are its flat frequency response regardless of load impedance, its almost frequency-independent level of distortion and its ability to reject EMI interference. Its operation is based on a self-oscillating loop controlled by phase shift and taking into account feedback only at the speaker output.
SMPS Power Supply
The NC252MP module also integrates the amplification stage. This consists of a regulated half-bridge switching power supply (SMPS) with synchronous rectification on the main output rails. Compact, powerful and efficient, this power supply is particularly suitable for supplying a Class D amplifier cleanly.
In addition, to offer complete compatibility with the voltages delivered by the various electrical networks, the power supply is equipped with an automatic input voltage doubler. The NC252MP module also has an overload protection system.
Connectivity
The MPA-S250NC amplifier has a 3-pole stereo XLR input on Neutrik NC3FAV2 sockets. The amplifier output is made on Elecaudio BP-209 24k gold-plated speaker terminals. They also accept banana plugs or forks for quick and easy connections. A 5-12V trigger connector in 3.5mm Jack format allows to control the automatic ignition of the amplifier when integrated in a compatible system. Finally, a bistable button allows the device to be switched on.
This amplifier's trigger needs to be used with a mono trigger cable (sold separately).
Test du Audiophonics MPA-S250NC par AudioScienceReview (Amir)
Audiophonics has produced one adorable stereo amplifier! I just want to sit there and look at it. :) Fortunately beauty goes beyond the skin, sporting a performance Hypex class D amplifier, producing top class results in all the measurements. You get near state of the art performance at bargain prices with scant space needed to dedicate to the amplifier. "
Product typeAmplifier
ClassD
Number of channelStereo (2)
Max. power (@ 1kHz, THD=1%)2x150W @ 8Ω
2x250W @ 4Ω
2x180W @ 2Ω
Input1x Balanced Stereo XLR
OutputSpeaker terminals
Trigger5-12V
THD+N0.0015%
SNR121dB
Output noise30µV
Output impedance1.5mΩ
Frequency response10Hz - 50kHz
Efficiency92%
Input sensitivityMax Power at 1.66V RMS (2x0.83V MRS)
Supply voltage230V / 110V (automatic switch)
Case materialBrushed Aluminium
Total dimensions (WxDxH)145 x 355 x 64mm
Weight1860g
Package1x Audiophonics MPA-S250NC XLR
1x Power cable
InputXLR
Channel2 (Stereo)
Amplifier chipHypex Ncore
Power (W)150.0
40 reviews
très bon raport qualité prix
Cela fait maintenant 3 mois que je vis avec ces amplis je les utilisent en home cinéma avec mon préampli DENON et franchement ces amplis sont très musicaux et quel pêche en home cinéma!
This review has been posted for AUDIOPHONICS MPA-S250NC XLR Power Amplifier Class D Stereo Ncore NC252MP 2x250W 4 Ohm
great!
Very flat, clean and powerful amp. Ideal companion for passive studio monitors. My ATCs came to life with this amplifier. The overall soundstage became more forward, widescreen, direct, firm and uncoloured compared to my previous A/B amp. I was affraid my snobbish and picky speakers would hate it, but the exact opposite happened.
Very good amplifier for the money
It’s a massive difference compared to the Onkyo receiver I had previously. Much more detail and dynamic range driving some B&W CDM7 SE’s. Very happy with the amp, especially at this price point.
qualité - prix
commander lundi livré mercredi !!!!!, par rapport à un SMSL AO200 MKII on passe à un niveau suppérieur surtout au niveau contrôle des graves, 38 cm sur mes enceintes,tout plus homogène même si le SMSL ne démérite pas, je confirme , comme beaucoup, Audiophonics nous a fait un ampli d'un excellent rapport qualité/prix, j'ose imaginer si un jour je passe à un "Purifi " peut être ????
Excellent amplifier
Small, lightweight, clean power into any reasonable impedance, at a great price.
The Audiophonics MPA-S250NC XLR is a stereo amplifier based on an amplification module Hypex Ncore NC252MP. This solution is ideal for anyone who...
