By buying this product you get 499 loyalty points
The Burson Audio Timekeeper GT4 is a pair of Class AB monoblocks designed to deliver stable and controlled amplification in demanding configurations. Each module delivers 200W into 4Ω, utilizing a power section with EXICON MOSFET transistors biased at high quiescent current to reduce distortion. The integrated power supply, provided by two dedicated Fusion Core blocks, allows for pure Class A operation up to 30W, offering increased linearity at typical listening levels.
Designed for high-fidelity systems requiring significant power reserves without sacrificing signal quality, this design combines Silent Power 2 modules for reduced background noise, a Class A buffer stage to ensure compatibility with any preamplifier or direct source, and a dual-mono architecture to ensure complete physical separation of the channels.
The amplification section of the Timekeeper GT4 follows Burson's traditional philosophy: power, stability, and class AB. Each device is built around EXICON MOSFET transistors, operating at a high quiescent current to minimize distortion while delivering 200W of power. In addition, the Fusion Core power supply stage allows for pure Class A operation in the first 30 watts.
Power supply is a key element in the architecture of the Timekeeper GT4. It incorporates Silent Power 2 modules, discrete regulators designed to ensure a particularly clean power supply. Their role is to drastically reduce the background noise generated by the regulation, allowing the analog stages to operate under optimal conditions. The result is a quieter power supply than that obtained with conventional modules, contributing to the stability and transparency of the audio signal.
The Timekeeper GT4 includes a pure Class A input buffer stage to prevent any incompatibility issues. When activated, it adds 6dB of gain to the input signal, ensuring perfect compatibility with any upstream device.
| Specifications | |
| Product type | Power amplifier |
| Inputs | 1x XLR 1x RCA |
| Output | Borniers enceinte |
| Input impedance | XLR : 200kΩ RCA : 100kΩ |
| Frequency response | 20Hz-20kHz |
| Total harmonic distortion (THD) | < 0.03% @ 1kHz |
| Output impedance | < 0.015Ω |
| Output power | 200W @ 4Ω 100W @ 8Ω |
| Signal-to-noise ratio (SNR) | 110dB |
| Buffer | XLR : 12dB RCA : 6dB |
| Gain | 29dB |
| General | |
| Dimension | Timekeeper GT4 : 255 x 270 x 70mm Fusion Core : 210 x 200 x 75mm |
| Weight | Timekeeper GT4 : 5kg Fusion Core : 5kg |
| Color | Silver |
| Package | 2x Burson Audio Timekeeper GT4 2x Burson Audio Fusion Core 2x Power cables |
| Input | XLR |
| Input | RCA |
| Output | Speaker terminal |
| Color | Silver |
| Channel | Dual Mono |
| Class | Class A / AB |
| Amplifier chip | Transistors |
| Power (W) | 200.0 |
| Remote Control | No |
