ARYLIC HA400 Network Amplifier
The Arylic HA400 is a multi-zone network amplifier designed to meet the needs of demanding home and professional audio systems. With a total power output of 400W distributed across 4 independent zones, each zone has a 2x50W amplifier under 8Ω, allowing music to be played in up to four different rooms simultaneously, or playback to be synchronized across all zones. Featuring Class D digital amplification, the HA400 offers high sound quality and great flexibility of use, whether in stereo or bridged mode.
By buying this product you get 209 loyalty points
Reference : 21461
2 099,00 €tax incl.
1 749,17 € tax excl.
Arylic HA400 Network Amplifier 4 Zones DLNA AirPlay 2 50W 8 Ohm
Arylic HA400
This model stands out for its compatibility with major audio streaming services, such as Spotify Connect, Tidal Connect, AirPlay 2, UPnP, and DLNA, as well as its ability to manage local and networked audio sources. With the 4STREAM app, available on iOS and Android, users can easily control each zone, adjust the volume, select audio sources, and customize the equalization to their preferences. The HA400 also offers analog and digital audio inputs (coaxial and optical), as well as an RS232 port for integration into advanced home automation systems.
The HA400 is ideal for creating a high-performance multi-zone audio system, whether for residential or commercial use, offering a complete solution for a centralized and customizable audio experience.
Arylic HA400: Multi-zone amplification and configuration
The HA400 is equipped with 8 channels of Class D digital amplification, delivering 50 watts per channel into 8 ohms. Each zone can operate independently, allowing different audio sources to be played in each room, or playback to be synchronized across all zones. The ability to switch between stereo and bridged modes offers optimal adaptability depending on your needs and speaker configurations.
Arylic HA400: Connectivity for the 4 zones
Arylic HA400: Control via mobile app
Arylic HA400: Connectivity and compatibility
The Arylic HA400 amplifier supports a wide range of streaming protocols, including AirPlay 2, Spotify Connect, Tidal Connect, UPnP, DLNA, and Qplay. It is therefore compatible with most online music services (Spotify, Deezer, Tidal, Amazon Music, Qobuz, Napster, iHeartRadio, etc.) and can also play local audio files via a NAS or DLNA device. Analog and digital audio inputs (coaxial and optical) complete its features, offering a wide variety of possible sources.
Arylic HA400: Control and customization
The 4STREAM app provides intuitive control over the entire system. Users can name each zone, adjust the volume, select audio sources, and apply specific equalization settings for each space. This flexibility makes it a powerful tool for customizing the audio experience according to each user's preferences and needs.
Arylic HA400 : application 4Stream
Logos services de streaming supportés
Arylic HA400 : Port RS232
Arylic HA400: Integration and extensibility
The HA400 is designed to integrate easily into home automation environments thanks to its RS232 port. In addition, the system can be expanded by adding other Arylic devices to create an even more extensive multi-zone audio ecosystem, tailored to users' evolving needs.
Arylic HA400: Exceptional sound quality
The Arylic HA400 features an ESS ES9023P DAC. This allows it to decode audio streams efficiently in order to deliver high-quality, rich, and accurate sound reproduction.
Arylic HA400
Arylic HA400: Rack mounting
Arylic HA400: Rack mountable
The Arylic HA400 has a 2U form factor and comes with rack mounting brackets. It can therefore be placed in a 2U rack for professional integration.
Product typeNetwork multizone amplifier
Inputs per zoneRCA (2V RMS)
USB-A (USB Host, max 1000 tracks)
Optical Toslink (PCM up to 24bit 192kHz)
Master inputsRCA (2V RMS)
1x Coaxial (PCM up to 24bit 192kHz)
1x Optical Toslink (PCM up to 24bit 192kHz)
Outputs per zonePre-out RCA (2V RMS)
Coaxial (16bit 48kHz)
Speaker output (Phoenix connector)
Network1x Ethernet RJ45 input
1x output
Control interface1x RS232 bidirectional
Output power50W per channel @ 8Ω
Bridge mode: 100W per channel @ 4Ω
Supported network protocolsAirPlay 2, DLNA, UPnP, Spotify Connect, QPlay
Supported audio formatsFLAC, MP3, AAC, AAC+, ALAC, APE, WAV
Supported sampling ratesPCM up to 24bit 192kHz
Compatible streaming servicesSpotify, TuneIn, Tidal, Qobuz, Amazon Music, Napster, Pandora, QQMusic, iHeartRadio, webradios, QQ FM
LED indicatorWhite: WiFi and network mode (fast flashing = startup, slow flashing = waiting for WiFi connection, fixed = WiFi connected)
Red: USB mode
Yellow: Master line input
Magenta: Master optical input
Cyan: Master coaxial input
Supply voltage115-230VAC 50/60Hz (switchable)
Dimensions560 x 419 x 128mm
2U rack format
Weight10.5kg
Package1x Arylic HA400
1x Power cable
2x Rack mounting bracket
InputRJ45
InputRS-232
OutputCoaxial SPDIF
OutputPhoenix connector
OutputSpeaker terminal
OutputRJ45
Channel8
Amplifier chipN/A
Power (W)50.0
Remote ControlControl app
ARYLIC HA400 Network Amplifier 4 Zones DLNA AirPlay 2 50W 8 Ohm
The Arylic HA400 is a multi-zone network amplifier designed to meet the needs of demanding home and professional audio systems. With a total power...
