DAYTON AUDIO DTA-100LF Subwoofer Amplifier
New
The Dayton Audio DTA-100LF is a compact class D amplifier designed to power a subwoofer or a tactile bass transducer. It delivers 70 W into 8 Ω and up to 100 W into 4 Ω, relying on a highly stable continuous power supply and settings dedicated to bass control.
Reference : 22505
199,90 €tax incl.
166,58 € tax excl.
Shipping date: 11-11-2026.
Grantie 5 ans
DAYTON AUDIO DTA-100LF Subwoofer Amplifier 100W 4 Ohm
Dayton Audio DTA-100LF: Front view
Intended for desktop installations, home theater systems and DIY configurations, it combines a low-pass filter, subsonic filter, parametric equalization and phase adjustment to ease its integration with the main speakers. Its low-profile format, mounting brackets and Auto-On function allow it to be installed discreetly while ensuring standalone everyday use.
Dayton Audio DTA-100LF: 100W amplification
The Dayton Audio DTA-100LF is a class D amplifier designed to power a subwoofer. Its highly stable continuous power supply delivers 70 W into 8 Ω and up to 100 W into 4 Ω, while its compact low-profile format eases its integration into desktop installations, home theater systems or DIY projects. The included brackets also allow it to be mounted under a desk, table or shelf when available space is limited.
Dayton Audio DTA-100LF: Inside view
Dayton Audio DTA-100LF: Adjustment
Dayton Audio DTA-100LF: Filtering and acoustic integration
The DTA-100LF combines several settings that allow the bass to be precisely tailored to the system used. The low-pass filter eases the connection with the main speakers, while the subsonic filter limits frequencies likely to cause excessive driver excursion. The single-band parametric equalizer allows independent adjustment of frequency, bandwidth and level to reduce the influence of room modes, while the variable phase adjustment fine-tunes the coherence between the subwoofer and the other channels. The RCA inputs and outputs complete this versatility by allowing simple insertion into various audio configurations.
Dayton Audio DTA-100LF: Standalone operation
The Auto-On function automatically detects the presence of a signal to activate the amplifier, then returns it to standby when playback stops. The DTA-100LF can thus operate without daily intervention, with either a subwoofer or a bass shaker intended for home theater or simulation.
Technical specifications
Product typeSubwoofer amplifier
Inputs1x RCA stereo
Outputs1x RCA stereo
Speaker terminals
SNR95dB
Frequency response20Hz-180Hz (±3dB)
Power70W @8Ω
100W @4Ω
Input sensitivity200mV
Total harmonic distortion (THD)0.26%
Input impedance22kΩ
Line output impedance4kΩ
Low-pass filter30Hz-200Hz
Phase setting0°-180°
Supply voltage100-240V AC, 50/60Hz
Dimensions190 x 50 x 140mm
Weight1.5kg
Package1x Dayton Audio DTA-100LF
2x Mounting bracket
1x Power cable
OutputSpeaker terminal
Channel1 (Mono)
Amplifier chipN/A
Power (W)100.0
The Dayton Audio DTA-100LF is a compact class D amplifier designed to power a subwoofer or a tactile bass transducer. It delivers 70 W into 8...
