FOSI AUDIO V3 MONO Class D Amplifier TPA3255 240W 4 Ohm
The Fosi Audio V3 MONO is a compact, powerful but still affordable 1-way amplifier. Based on a TI TPA3255 amplifier chip, it can deliver 240W at 4Ω. Furthermore, this amplifier is equipped with a host of audiophile components such as Japanese and German Elna and Wima capacitors, respectively, or a duo of DIP8-mounted TI NE5532 OPAs, giving you the option of replacing them if you want a specific sound coloration. Regarding connectors, the Fosi Ausio V3 offers balanced XLR and RCA inputs, and a speaker terminal on the output.
Reference : 19171
149,00 €tax incl.
124,17 € tax excl.
Shipping date: 10-06-2025.
FOSI AUDIO V3 MonoMono Class D Amplifier TPA3255 240W 4 Ohm
FOSI AUDIO V3 Mono Class D Amplifier TPA3255 240W 4 Ohm : 3/4 view
The Fosi Audio V3 MONO is a compact, powerful but still affordable 1-way amplifier. Based on a TI TPA3255 amplifier chip, it can deliver 240W at 4Ω. Furthermore, this amplifier is equipped with a host of audiophile components such as Japanese and German Elna and Wima capacitors, respectively, or a duo of DIP8-mounted TI NE5532 OPAs, giving you the option of replacing them if you want a specific sound coloration. Regarding connectors, the Fosi Ausio V3 offers a balanced XLR/jack 6.35mm combo input, an RCA input and a speaker terminal block for the output.
A DC48V 5A power supply is supplied, but for dual Mono installation a DC 48V 10A power supply and a DC 5.5/2.5 jack doubler are available as accessories.
Fosi Audio V3: Noise and distortion-free amplification
The V3 mono amplifier benefits from PFFB technology, an advanced feedback design that significantly reduces distortion, improves linearity and enhances efficiency. It also remedies a structural problem in Class D amplification by negating the load dependency inherent to this technology. Furthermore, the aluminum enclosure design isolates the power supply from the amplifier section, preventing crosstalk.
Fosi Audio V3: A flexible amplifier
The V3 amplifier is designed to be integrated into multiple configurations, allowing you to switch easily between RCA and XLR inputs using the front panel switch. Furthermore, you can adjust the gain of the RCA input between 19dB and 25dB. Finally, if you wish for a different sound coloration, DIP8 mounting of the TI NE5532 OPAs enables them to be replaced.
OPA assembly in DIP8
FOSI AUDIO V3 : venting system
Fosi Audio V3: A redesigned cooling system
To prevent overheating and thus ensure the longevity of their amplifier, Fosi Audio have developed an innovative ventilation system, in addition to the traditional heat sink system on the amplifier chip. The ventilation system is designed to block any dust infiltration without compromising cooling, ensuring impeccable sound quality coupled with enhanced reliability.
Fosi Audio Mono V3 overview
1On/off button
2Input selector
3RCA input gain (31dB-25dB)
4Mono RCA input
5XLR/Jack 6.35mm balanced mono combo input
6Speaker terminal output
7Power supply jack DC 32-48V
FOSI AUDIO V3 Mono test by Audio Science Review
I can't imagine asking for more from Fosi when it comes to such an amplifier. Everything is as good as you could possibly want. It is my pleasure to recommend Fosi Audio V3 Mono amplifier.
Product typeMono class D Amplifier
Inputs1x Balanced XLR/jack 6.35mm combo
1x RCA (choice of 25dB or 31dB gain)
Output1x Speaker terminals
Amplification chipTI TPA3255
OPA2x TI NE5532
Output power240W @4Ω 48V/5A
160W @6Ω 48V/5A
120W @8Ω 48V/5A
100W @4Ω 32V/5A
65W @6Ω 32V/5A
55W @8Ω 32V/5A
Speaker impedance2Ω - 8Ω
Frequency response10Hz-30kHz(±0.06dB)
SINADXLR: 101dB
RCA: 93dB
Total harmonic distortion (THD)<0.006%
Signal to noise ration (SNR)≥123dB
Gain setting (RCA input)19dB
25dB
Power supply32-48V DC
Product dimensions142x107x41mm
Package1x FOSI AUDIO V3 Mono
1x Power adapter 48V/5A
InputXLR
OutputSpeaker terminal
Channel1 (Mono)
Amplifier chipTPA3255
Power (W)240.0
8 reviews
Presque le sans faute... mais ça Sonne Superbement !
Bon, je commence par la Mise en Service : après avoir vidé un bel emballage très "sécure" mais sans véritable Doc ~ Mode d'emploi... mais la mise en place demande 5 minutes chrono. Branché via câbles XLR depuis un Lecteur Réseau "Eversolo" faisant office de Préamplificateur (modulant ainsi le Volume) en ayant bien pris soin de Baisser à -55 dB le Niveau de Mise en Service . . . car ces Fosi V3 mono poussent fort.
Dès la mise en Écoute, cela sonne déjà correctement, pour un Rodage (-42 dB) de plusieurs Heures sur divers Types de Musiques, sans trop s’inquiéter car j'ai lu partout que ces V3 Mono chauffaient légèrement.
Au bout d'une dizaine d'heures, cela s'ouvre réellement Plus, donnant vraiment l'équivalent de mon SANSUI AU-α 607 NRA II (rendant bientôt l'âme).
Pour l'instant, je n'ai presque jamais dépassé le Niveau -30 dB qui dégage déjà beaucoup de Watts ! ! !
Seul souci rencontré, l'un des deux V3 Mono ne commutait pas en Veille * au bout des 10 minutes (sans aucun signal) avec le Commutateur de Gauche sur Auto, comme c'est prévu.
Ayant lu pas mal de Très Bonnes Analyses & Mesures de ce FOSI V3 mono, sur "audiosciencereview" & ailleurs, le mode veille ne semblerait pas vraiment efficient (économie Wh & repos des puces), donc autant les commuter manuellement sur Off.
Le SON est très Propre, avec ce qu'il faut, tout en Haut ~ en Medium & dans les Graves, ce qui n'est qu'une demi-surprise, ayant déjà acheté un V3 "stéréo" qui chante déjà bien, via de petites Eltax Monitor III sur un système "voyage".
Ces 2 petites boites ont vraiment du Coffre pour driver facilement mes Elipson Prestige 4 recapées, avec Musicalité & Rigueur !
* J'ai contacté FOSI afin de leur signaler, et... ils répondent de suite puis me font livrer une Nouvelle Carte (mère) afin de remédier à ce problème de Mise en Veille Auto ;°)
FOSI me signale aussi qu'ils attendent & analyses Toutes remarques constructives venant de ses Clients, afin de faire progresser, eux ~ leur Matériel & Produits HiFi, ce qui me semble carrément une démarche plus que remarquable.
SAV juste Impeccable & très Professionnel !
(& Je n'ai aucune action dans cette société chinoise...)
This review has been posted for FOSI AUDIO V3 Mono Class D Amplifier TPA3255 240W 4 Ohm
Parfaits
Remplacent mes amplis Mcintosh... Tout est dit et à ce prix c'est une révolution !
Très étonnants !
Pour faire au plus simple, ils remplacent sans discussion mes blocs mono MC30 Mcintosh. Je redécouvre toute ma discothèque.
Pourquoi vouloir plus gros et cher ?
Je suis agréablement surpris par ce tout petit ampli de puissance .
Surpris par sa petite taille et par la taille de l’alimentation 48v/5amp plus imposante que l’ampli.
Surpris par la qualité de fabrication . Un bloc mono à 149€ avec son alim déportée , il faut trouver où placer ces « petits éléments » car le choix est grand du fait de leur taille .
Passons à l’écoute .
Pour son achat je me suis basé sur les mesures Audio science review . Elles sont d’un haut niveau , on est dans le classement des meilleurs amplis mais son prix est ridiculement bas !
On est juste derrière un Nad C298 stéréo, à 2300€ !
J’ai branché mes 2 blocs Fosi V3 mono en XLR avec des câbles Audioquest Red River qui valent aussi chers que mes 2 Fosi V3 mono . C’est disproportionné voire idiot mais je n’ai que ces câbles .
J’ai donc débranché mes blocs mono Purifi Audiophonics pour y mettre les Fosi .
Première remarque , la différence entre les 227 w du Purifi et les 120w du Fosi est nette .
C’est normal , environ -3db à 1 mètre .
Après plusieurs heures de chauffe et d’écoute , je ne suis pas déçu, le son est clair, ciselé , les basses sont sèches et profondes . Ça descend bas . La dynamique est présente .
On écoute sa musique , ses films avec du plaisir .
Par rapport à mes Purifi qui coûtent 4 fois plus chers, je vous assure que la différence de prix n’est pas justifiée .
Le Purifi MPA-M400ET est plus puissant et au final il se dégage un son plus plein et plus équilibré à mon oreille . Cela reste très subjectif .
Si 120 watts /8 ohms( 240w /4 ohms) vous suffisent , alors à ne pas hésiter .
Caractéristique aussi à prendre en compte, cette petite boite tient les 2 ohms !!!
Après des heures d’utilisation, le boitier est un peu chaud mais rien d’alarmant . Beaucoup moins qu’un ampli Nuprime STA9 ou qu’un préampli Marantz av8805 , matériels que j’ai possédés .
Au final je recommande ces blocs mono qui à ce prix sont un véritable cadeau .
Si vous voulez booster un ampli audio vidéo , cela peut être une solution peu coûteuse même en rca . Vous pourrez régler le gain sur 25 ou 31db .
Sur un préampli comme des Marantz AV10 , Anthem av60,70 , Arcam etc…… pas la peine d’allez chercher des 5, 7 ou 16 canaux hors de prix .
Moi je vais alimenter mes LCR avec mes Purifi et mes 12 autres canaux avec les Fosi v3 mono .
Cela en fait beaucoup à empiler mais ils sont petits .
Je suis en salle dédiée en 9.2.6 .
Wow!
Commande reçu rapidement, super service.
Alors que dire de ces blocs mono..... Envoutants, musical et détaillés. Pour l'instant qu'une journée de rodage. En attente de mon préamplificateur, branché directement à la sortie d'un WiiM Pro avec contrôle de volume. Vraiment super simple, beaucoup de réserve. Prenez les 2 alim séparées.
The Fosi Audio V3 MONO is a compact, powerful but still affordable 1-way amplifier. Based on a TI TPA3255 amplifier chip, it can deliver 240W at...
