By buying this product you get 489 loyalty points
LAiV Audio Harmony GaNM power amplifiers represent excellence in power amplification, coming in the form of two mono blocks exploiting gallium nitride (GaN) transistors for 200W of amplification at 8Ω per block, offering uncompromising sound quality. The meticulous attention paid to every aspect of the Harmony GaNM, from its ultra-low-noise power supply to its refined design and signal-processing architecture, makes it the ideal choice for the audiophile demanding a perfect marriage of exceptional sonic performance and elegant aesthetics.
The design of the Harmony GaNM fits harmoniously into the aesthetics of LAiV Audio's Harmony range, with a superb CNC-machined aluminum chassis that combines rare elegance with efficient thermal dissipation.
Integration within the Harmony range goes beyond appearance; the user experience is also designed for perfect synergy between devices. The alignment of screens, the uniformity of controls and the matching of connectors facilitate intuitive and ergonomic installation, reducing visual clutter and reinforcing the cohesion of the system, allowing the listener to concentrate fully on the music.
At the heart of the Harmony GaNM lies GaN Systems technology, using gallium nitride (GaN) transistors for remarkable speed, efficiency and sonic purity, delivering 200W of amplification per mono block. Unlike traditional silicon transistors, GaN transistors switch faster, with significantly reduced energy loss and distortion. This enables the amplifier to react to signals with superior agility, resulting in a dynamic, transparent sound, free from the limitations of conventional power stages.
The adoption of GaN technology enables sharper transient responses, deeper bass and increased richness of detail, particularly in low-level passages. Improved energy efficiency also reduces thermal stress, enabling a more compact chassis design without sacrificing power or performance.
The ultra-low-noise power stage is precision-engineered using the advanced NXP TEA2017AAT controller. This intelligent chip integrates power factor correction (PFC) and LLC resonant topology into a compact package, reducing the number of external components and ensuring cleaner, more efficient power conversion. The result is a stable, precise power supply, the foundation of the Harmony GaNM's outstanding sonic performance.
To ensure maximum efficiency and reliability, the power supply features top-of-the-range components such as Infineon's CoolSiC™ silicon carbide MOSFETs, known for their high switching efficiency, low on-resistance and long life. They are complemented by Rubycon electrolytic capacitors, chosen for their excellent temperature stability and longevity. Together, these components provide a perfectly stable output voltage and current, which is essential for maintaining very low noise levels and minimizing signal interference.
Overvoltage, undervoltage and overcurrent protection ensure safe operation over a voltage range from 90V to 264V AC.
The Harmony GaNM consists of two mono blocks featuring a balanced architecture for optimum sound quality. In each block, the input and output stages operate in phase, with completely isolated signal paths for positive and negative polarities. This design enables effective cancellation of phase noise, resulting in an ultra-clean signal with extended dynamic range and considerably reduced distortion.
The Harmony GaNM prioritizes ease of use without compromising audiophile performance. On the front, a clear OLED display shows real-time information, while subtle LED indicators identify left and right blocks. On the rear, a 12V trigger input and output facilitate integration with other system components. Every detail, from visual feedback to system control, is designed for an intuitive, modern and refined user experience.
| Specifications | |
| Product type | Power amplifier |
| Input | 1x XLR |
| Input sensitivity | 1.4 Vrms |
| Output | Speaker terminals |
| Gain | 29dB |
| Output power | 200W @ 8Ω |
| Damping factor | 500 @ 1kHz, 8Ω |
| Frequency response | 20Hz-22kHz (±3dB) |
| Harmonic distortion plus noise (THD+N) | < 0.8% @ 200W, 8Ω |
| Signal-to-noise ratio (SNR) | ≥ 95dB |
| Dynamic range | ≥ 95dB |
| Trigger | Input and output 12V |
| General | |
| Power supply | 100-260V AC, 50 / 60Hz |
| Fuse | 5A, Slow-blow, 5 x 20mm |
| Consumption | Standby: ≤ 0.3 W Max power: ≤ 250W |
| Dimensions | 260 x 128 x 119mm |
| Weight | 3.9kg / bloc |
| Color | Silver |
| Package | 2x LAiV Harmony GaNM mono blocks 6x Decoupling spikes 2x Power cables |
| Input | XLR |
| Output | Speaker terminal |
| Color | Silver |
| Channel | Dual Mono |
| Class | N/A |
| Amplifier chip | Transistors |
| Power (W) | 200.0 |
| Remote Control | No |
