This high quality Oyaide Tunami GPXe power cable is equipped with a Schuko and an IEC C13 connectors, with 24k gold and palladium plated contacts. The conductors of the cable are made of high purity PC-OCC-A copper with a cross section of 5.5mm², ensuring perfect electrical conductivity. The cable can withstand voltages up to 600V and currents up to 30A. This makes the Oyaide Tunami GPXe suitable for transmitting high power signals.
It is also protected against noise and interference by a triple layer shielding. Its structure rejects not only internal and external noise, but also parasitic noise due to vibrations.
PC-OCC-A copper is a very pure material, allowing any signal to pass through without hindrance or distortion. It is the combination of high technology and Japanese craftsmanship that gives it an extremely pure structure, ensuring optimum performance.
This Tunami GPXe cable has a triple shielding. The first layer converts electromagnetic waves into thermal energy through an electromagnetic insulator. The second layer is a semi-conductive carbon layer that allows to discharge static electricity without affecting the main conductor. The last layer uses a copper foil that offers two advantages: it protects the conductor from external noise and it allows a grounding.
The insulation chosen here by Oyaide for its Tunami GPXe cable has the effect of eliminating the negative effects of vibrations thanks to a different degree of internal and external hardness.
The connectors (P-046Re and C-046Re) present on this 1.8m cable have been specially designed for this cable. Their 24k gold and palladium plated contacts make them high quality connectors, ensuring both a very good conductivity and resistance to oxidation.
| Specifications | |
| Product type | Power cable |
| Length | 1.8m |
| Outer diameter | Ø11mm |
| Cable conductors material | PC-OCC-A copper |
| Connectors | P-046Re C-046Re |
| Connectors contacts plating | 24k gold Palladium |
| Rated voltage/current | 125V / 15A CE |
| General | |
| Color | Cable: Black Connectors: Red |
| Quantity | 1* Oyaide Tunami GPXe cable |
| Length (m) | 1.8 |
| Shielding | Yes |
| Section (mm²) | N/A |
| Connector | Schuko |
| Connector | IEC C13 |
| Conductors Plating (Cable) | None |
